• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
Removing the battery
Sign in to follow this
Followers 0
12 posts in this topic
Despite being quite mechanically minded, I cannot work out how to remove the plastic cover....... with all the wires attached........ that goes on top of the battery. My battery needs replacing but I'm stuck!! I'd imagine it clips on somehow but can't work out how..... any help much appreciated.
Share this post
Link to post
Share on other sites
If it is like an Octavia, you pull back and upwards at the rear, it is fastened by 2 lugs which slide under 2 very small letter box style slots either side :thumbup:
Share this post
Link to post
....and if i am not wrong always take the negative poll first off and then the potive.........
Share this post
Link to post
[quote name='john123' timestamp='1322501977' post='2593729']
[/quote]
Or positive even :giggle:
Share this post
Link to post
[quote name='bluevrs2' timestamp='1322496287' post='2593587']
[/quote]
It seems to be fastened at the rear and sides....... tried pulling as directed but no joy!! Any further suggestions welcomed!
Share this post
Link to post
[/quote]
Always take the positive off first then the negative. If you take the negative off first you still got the load going through the vehicle from the positive and if u touch the negative end and accidentally touch the metal work of the car you will have the full load going through your body. We get this alot on electrical installations where neutrals have been "borrowed" and believe me I rather touch a live cable rather than neutral under load
Share this post
Link to post
Take the negative off first because it is connected to the chassis anyway so no big sparks if you touch any metalwork with your spanner. Then take the positive off as now with no negative connection it doesn't matter if you touch anything metal.
For the same reasons when refitting connect and fully tighten the positive before connecting the negative.
I've looked at mine and wondered how to remove the positive as and when I need to. Edited by delta925
Share this post
Link to post
Negative off 1st then positive, heres why, one of a thousand posts saying why! [url="http://7faq.com/owbase/ow.asp?GoodEngineeringPractice%2FBatteries%2FDisconnectingTheBattery"]http://7faq.com/owba...ctingTheBattery[/url]
As for the original post will look at Father-in laws car when I see him, he has a fabia M2 trim model 3
Share this post
Link to post
[quote name='bluevrs2' timestamp='1322526089' post='2594263']
It is interesting reading and I can see the logic behind it but that's probably why the motor industry and the electrical industry differ. I will never use an uninsulated tool to undo any sort of live connection( a neutral/negative earth is classed as a live cable) so I can see the logic of positive 1st using a metal spanner/ratchet in a confined space
[/quote]
Share this post
Link to post
Never removed the battery.
But when I look at the top of the battery there are a number of wires going into a plastic housing.
If you are trying to remove the top of the housing then I have done that.
The plastic top is held on with two lugs at the front and I think two at the back.
I pushed the plastic back as far as I could then took a small screw driver and carefully leavered the top off the plastic housing.
Share this post
Link to post
I concur with bluvrs, always remove the NEGATIVE first! That's how it's done in the workshop.
Edit: just to be clear, put the positive back first when replacing the battery. :yes: Edited by Estate Man
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
