Warm starting problem
Recommended Posts
This is not really a problem (or at least I hope it isn't), but my car starts first time every time when cold with no fuss. However, if you have been for a run, and it has warmed up, then it seems to be a different matter.
My cold starting routine - key in ignition, car out of gear, depress clutch and start car, without using the gas pedal.
When starting from warm, the car will not fire unless I press the gas pedal, and then seems to start with a "clonk" despite the fact that the car is out of gear and the clutch pedal depressed.
Is this normal for the 1.9 TDi models?
Andy
  • Like 1
Link to comment
Share on other sites
This has been covered numerous times on here, and is a known problem.
Mine was cured with a new battery, others have had to replace the starter motor.
Mike
Cheers Mike, but the starter seems to be working fine, whirring over nicely, and starts the car when cold. I was wondering if there was a problem with fuel evaporation in the injection system (I had an Alfa and BMW which suffered from that) when the car was warm, and also, why there should be a big "clonk" on starting when warm, but not when cold.
Andy
Link to comment
There have been quite a few threads on this of late - try the search function.
If I remember correctly there have been other members with what appear to be perfectly working batteries and starter motors complaining of hot starting issues. They go around the houses then as a last resort change the battery/starter motor and hey presto - all fixed!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
