Satnav
Hi I am about to receive my new Roomster SE, and I wish I had payed the extra and had Satnav factory fitted.
Has anyone done the same as me but have fitted it themselves. Any help Thank You.
AJ
not sure what the cost is for the spec and factory fitting, however there is someone selling on ebay - item 140926538591 - and according to that it's a diy simple replacement procedure with no wiring changes needed?
Columbus unit will work fine but may require some coding. :)
I believe you need one designed for a Superb, rather than the model fitted to the Octavia. I discovered this to my cost when I attempted to install a Bolero into my 2012 Roomster SE+.
Hi Pinkpanther Have you fitted a satnav in your Roomster yet if so which model
Hi Has anyone fitted one of the DVD Radio Sat Nav units you can buy on Ebay which are not Skoda or VW make.
AJ
