Low flying aircraft
The automatic levelling/cornering lamps are persistently in the habit of attempting to spot low flying aircraft! This particularly occurs when turning right and when going uphill. The lights adjust upwards when going uphill but take a good while to come down when reaching the flat or downhill. This obviously has the effect of dazzling oncoming traffic. On cornering (particularly right) the lights bend appropriately but don't always return when the manoeuvre is finished, unless you "jiggle" the steering wheel. :doh:
It has been into D.W.Keiths twice for this but they cannot find any fault. :(
Any suggestions gratefully appreciated.
I have observed this as a passenger, mainly because Libby doesn't let me drive it! :peek:
Cheers all
I presume either this topic is very important to you or you're expecting an immense response hence the need to duplicate the topic? ;-))
sorted :thumbup:
Has the dealer done a basic settings reset on the lights; a bit like re-ghosting a PC.
Had an occasional issue with mine not moving as they should; dealer in Hull took a couple of goes (not unusual for them) at doing a reset but touching wood been fine since.
TP
Thanks TP, will check with Keith's
sorted :thumbup:
Cheers for that, not sure how I managed to duplicate that!
