Still having electrical failure to the twin boot
Recommended Posts
Hi all,
After replacing the old 70AH battery with a new 75AH car battery in a 2009 tdi greenline, my twin boot failed to open once again.  Having read all the posts on weak car batteries on this web site I headed out to buy a new one to solve this ongoinig problem.
got a VCDS plugged in approx 2 weeks ago and one error came up for a glo plug, got that sorted, but no other errors showing.
The only way I get the boot motors working again is to disconnect the car battery for a minute then reconnect again and away we go, the boot operates normally,  until another few weeks when to me it looks like a reset is needed (hence disconnecting the battery).
Can anyone figure out why a reset is needed every time the motors fail to operate and once done they work fine,  and if anyone has a solution as I know it will happen with the wife some day and she will not know where to start to fix it.
Is it a higher powered battery needed or is there something that the vechicle diagnostics can sort.
your advice and opinions on this would be greatly appricated.  Thanks.
Link to comment
Share on other sites
Might not be from battery: there is a known problem with the electrical cables to the twindoor: in time, because of the opening/closing, the electrical cables tend to sever and this causes failures in opening.
This issue is well known with the dealers/services - they replace the wirings to the boot.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
