clutch / revving issue on fabia :(
Recommended Posts
Hi,
I have a problem with  fabia that's causing me issues. I've taken it to a garage and they couldn't fix it.
In a nutshell basically sometimes i'm in a gear and I have the accelerator down applying throttle then when i apply the clutch to go up a gear the accelerator flies up right to highest level of acceleration then comes back down again this does not always occur sometimes does it sometimes doesn't does not do it when the car is at standstill (not changing gears).
I did get a scan with a legit vcds cable, and below  is the result of the scan, seems there is something picked up. I did offer this log to the garage but they didn't want it insisting their equipment was better.
The garage told me they replaced the clutch switch and the throttle body, now I'm stuck as that's the first thing I would have changed. Anything else I should look at ? (trying to avoid taking it to a garage as they didnt fix it and i'm £70 out of pocket so far)
Thursday,10,April,2014,12:13:42:35482
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: TMBNY46Y174036527   License Plate:
Chassis Type: 6Y (6Y - Skoda Fabia (1996 > 2008))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBNY46Y174036527   Mileage: 93050km/57818miles
Address 01: Engine        Labels: Redir Fail!
  Part No: 03E 906 023 D
  Component: SIMOS91 1.2l 4V     8884
  Revision: --H04---    Serial number: SKZ7Z0F3667437
  Coding: 0000071
  Shop #: WSC 13765 000 00000
  VCID: 204F2A2BF049791EBB7-5140
1 Fault Found:
17088 - Clutch Switch (F36)
           P0704 - 008 - Implausible Signal - Intermittent
            Freeze Frame:
                   RPM: 2592 /min
                   Mass Air / Rev.: 425.1 mg/str
                   Speed: 78.0 km/h
                   Bin. Bits: 00000100
                   RPM: 2336 /min
                   Mass Air / Rev.: 70.9 mg/str
                   Speed: 71.0 km/h
                   Bin. Bits: 00000100
Readiness: N/A
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.lbl
  Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
  Component: ABS 8.0 front   H05 0002
  Revision: 00000000    Serial number: 00000000000000
  Coding: 0002061
  VCID: 8109CFAFDB831016149-5140
No fault code found.
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
  Part No: 6Y0 820 045
  Component: Klimaanlage        X0840
  VCID: F2EB9063BE253B8E1D3-5122
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
  Part No: 6Q1 937 049 D
  Component: 0000 BN-SG.         1S34
  Coding: 25742
  Shop #: WSC 13765
  VCID: 3C77FE5B2CE13DFE87F-5140
1 Fault Found:
01598 - Drive Battery Voltage
           07-10 - Signal too Low - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
  Part No: 1C0 909 601 A
  Component: 11 AIRBAG VW51      0009
  Coding: 12593
  Shop #: WSC 13765
  VCID: 1E3314D39A3D4FEE89B-5140
1 Fault Found:
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 6Y0-920-xx3-17.lbl
  Part No: 6Y0 920 983 M
  Component: KOMBIINSTRUMENT VDO V04
  Coding: 00402
  Shop #: WSC 17025
  VCID: 4B95AD87794F8A463E5-5140
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
  Part No: 6N0 909 901
  Component: 003M GATEWAY CAN    1S34
  Coding: 00014
  Shop #: WSC 13765
  VCID: F0EF9A6BB029099EEB7-5122
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
  Component: IMMOBILIZER VDO V04
  Coding: 00402
  Shop #: WSC 17025
  TMBNY46Y174036527     SKZ7Z0F3667437
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
  Part No: 6Q0 423 156 AB
  Component: LenkhilfeTRW        V270
  Coding: 10140
  Shop #: WSC 13765
  VCID: 6FED19172D17966672D-5140
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
  Part No: 6Q0 959 433 E
  Component: 2X Komfortger?t     0002
  Coding: 00019
  Shop #: WSC 13765
  VCID: 3D71F35F37FB34F6B01-4B00
Address 56: Radio        Labels: 1U0-035-156.lbl
  Part No: 6Y0 035 156 E
  Component:  Radio YD5          0015
  Coding: 00401
  Shop #: WSC 13765
  VCID: 387FE24B18D911DE637-49D8
End   ---------------------------------------------------------------------
Link to comment
Share on other sites
  • 4 years later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
