Fabia RS 6y Glow Plug
chelsea19052
Recommended Posts
Hello,
First sorry for my bad english !
I have a problem with glow plugs.
I have Skoda Fabia  1,9 101 hp 2007 year.Before 1 year i've changed all nozzles, MAP sensor,turbo. I upload the FLASH with the Flash for BLT (RS engine) but don''t change the ECU only software. Now i link all cables for glow plugs with the original scheme i put the relay. Everything is ok, When I test with vag com the relay and glow plugs are working, but now the problem. When the temperature is 0 degrees they dont work. OK I disassembled and try to find a problem. No problem found, but I found when I start the engine the glow plugs is worked (not before I start the engine). In real conditions the situation is the same .
So do you how to make my glow plugs to heat before I start the engine.
Thanks in advance
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
