fault code 01273 - fabia 1.4tdi
Recommended Posts
Hi all,
I put a post up previously about fans in the car stopping working and climate control unit flashing on ignition. Anyway friend of mine plugged it into his diagnostics machine and came up with above fault code (see pic attached)
Could anyone shed any light on scenarios as been told it could be faulty resistor or as far as faulty climate control unit so in my head costs on this could be relatively small or stupidly high and would ideally want to know worst case before sending into garage then been hit with an almighty bill
thanks in advance
Link to comment
Share on other sites
http://wiki.ross-tech.com/wiki/index.php/0127301273
- Fresh Air Blower (V2)
Possible Causes
  • Fresh Air Blower (V2) defective
Control Module for Fresh Air Blower (J126) defective
Short of open circuit in wiring to Fresh Air Blower (V2)
Climatronic Control Module (J255) malfunctioning
Possible Solutions
  • Check Fresh Air Blower (V2)
    • Perform Output Test (Check Air Vents while Blower is active)
  • Check Meas. Blocks while Blower is active
Check Control Module for Fresh Air Blower (J126)
Check wiring and connectors
Special Notes
  • When found in Audi A4/A5/Q5 (8K/8T/8R) models:
    • North American Market (NAR) vehicles, see TPI 2033596/3 (or newer)
  • RoW vehicles, see TPI 2022372/2 (or newer)
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
