Help - Injector seats and O'ring seals 1.8t VRS
Recommended Posts
Hi guys!
I've been experiencing running issues with my VRS ever since I bought it. It's typically hesitant under load and is a hell of alot more noticeable with more passengers in the car.
I've had the beast to bits many a time now checking all the typical areas prone to boost leaks. I've carried out the vacuum simplifiction, fitted a catch tank, TIP, Ect.....However the problem still persists. Now I have noticed that around the injector seals I'm seeing moisture. I've cleaned this off and it comes back so one can only presume the seats are cracked (apparently a very common issue) or the injector O'rings have perished.
I've tried searching this forum for a while now and all I seem to ever find is comments on the issue and people saying that they have replaced them. My local TPS dealer is useless and they require part numbers. Does anyone on here know of the required part numbers for the items I required? As thus far I've 9nky been able to source billet aluminium items for the good old USA.
Thanks for any help in advance.
Link to comment
Share on other sites
Ah Liverpool lad your a legand cheers :) so that's the o rings sorted now what about the plastic seats that sit inside of the inlet manifold? Can anyone help me with these?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
