mumpsim
Everything posted by mumpsim
  1. Top GearSkoda Karoq Review 2025 | Top GearThe Karoq might be slightly dull, but it's eager to please and will slot seamlessly into your life"We very much like it overall, it's just sometimes a bit tricky to remember exactly why." This and more in their words, not mine.
  2. He can't possibly be using CarPlay with his Pixel phone and it seems from his post that he has not got as far as trying Android Auto. He doesn't need to. His phone can indeed be operated from the Karoq's infotainment screen, whether one uses Android Auto or not. He needs to start by getting Bluetooth working in full and importing his contacts from phone to car. Wi-fi and/or Android Auto had better wait till those first steps have been taken.
  3. As a first step, check Bluetooth permissions: Go to your Pixel 8a's Settings > Connected devices > Bluetooth. Select your Karoq from the list of paired devices. Make sure "Share contacts and call history" is enabled. On the 8a, something above may have a slightly different name but it should be clear enough what setting you want.
  4. You could obtain the VIN (ask MIL to take a photo or write it down), run that through a VIN decoder, and see whether the output includes "4F2 Central locking system 'Keyless Entry'"
  5. I revert to the original topic of this thread: the 1.5 TSi engine cutting out when the car is in motion, usually while changing gear or slowing down at a junction, and then refusing to re-start. The effect is total loss of power and a resulting situation that is often dangerous. If you are lucky, the car may still have enough momentum to bump-start it. If you are unlucky, you come to a standstill in the middle of a busy junction, repeatedly getting a dashboard message to use the start button, but finding that the engine repeatedly cuts out again immediately after it re-starts. To avoid repeating a fuller description of the problem, I refer to my post (above) of 11 January. I set out there, with reasons, why this is not about an operation of a correctly-functioning stop-start system. It is not about coasting mode (on those cars that have it). It is not about some difference between DSGs and manuals, as both have suffered from it. It is not about stalling. It is not about 95 versus 98 octane. It is not about driver error or driving style. When the engine cuts out, it cannot be re-started by dipping the clutch, or releasing the clutch, or touching the throttle. It is a fault in the engine management system allowing the revs to drop too low and then refusing to allow a re-start. I described my attempt to tackle this problem by 'Italian tune-up', as thamestrader aptly called it: that is, working the engine very hard for a while. It has been sixty days now since I first tried it, and I've repeated it a couple of times since. This is a report on what happened. Before the Italian tune-up, our 2023 Karoq Sportline was cutting out every day or two. Since then, in sixty days, it has cut out once while in Normal driving mode and zero times while in Sport mode. So for us, the problem has gone away, after being a serious and dangerous nuisance. I say 'for us' because I do not promise others will have the same results. A trial with a sample size of 1 is not science but anecdote. Correlation is not causation: I am not in a position to prove a causal connection, only to report on the correlation. As I now do: I did the Italian tune up, and subsequently, for whatever reason, the problem has almost completely gone away.
  6. You can just use an adapter. For example: https://thepihut.com/products/usb-c-to-usb-a-adapter?variant=41722082033859
  7. Our Karoq has the DXDB engine and was registered in April 2023.
  8. I agree with everything you say. If I were you, living where you do with plenty of hills, I'd be tempted to take the car up the 4-mile ascent at 1 in 75 from Tebay northwards to Shap Summit, or some similar long climb, working the engine as hard as possible, and see whether it makes any difference in the following weeks.
  9. We nearly always buy V-Power. Someone else (on the T-Roc thread?) thinks switching from E10 to E5 will solve the cutting-out problem. I don't.
  10. That may have been his point. I was addressing the much more prevalent complaints about cutting out, and complete failure to re-start, causing dangerous situations, as reported by many others.
  11. And numerous other people in this thread and the T-Roc thread have posted about the problem on a manual. It happens to both.
  12. Turning off the start-stop system does not get rid of this cutting out. Nor does the cutting-out happen only at low speed. However, I agree with Ootohere on one point: cutting-out can be avoided by keeping the revs up. But as it cuts out when one foot is on the clutch and the other often on the brake approaching a junction, keeping the revs up requires toeing and heeling. OK for me but not for my wife who is the main driver. Skoda documentation says that the start-stop system on a manual Karoq will operate when the car is stopped, the gear lever is in neutral, and the clutch pedal is released. But the engine cut-out that I and others experience meets none of these three conditions. It can happen when the car is moving, the car is not in neutral, and the clutch pedal is pressed down, not released. Therefore the cutting-out is not caused by the correct operation of the start-stop system as described by Skoda, though it might possibly be a malfunction related to that system. Ours is a manual car (2023 1.5 TSi Sportline). As coasting mode is provided only on the DSG, this is not a instance of coasting mode operation in my case. Some people have said that when the engine cuts out they can re-start it by dipping the clutch. That is not my experience, for the simple reason that it cuts out when the clutch is already dipped. As an aside, when I have reported this to a Skoda dealer (who of course said they were unaware of a problem) I have taken care to call it cutting out and avoid the word stalling, for two reasons: as soon as you say stalling they will dismiss it as driver error; and more fundamentally, a driver stalls a car when they raise the clutch pedal, not when they press it down, which is what happens to us. Our car never did this for the first 18 months of its life. Then it happened with increasing frequency over a couple of months in the later part of last year. Again that suggests a developing fault, not normal operation. It happens to both me and my wife. Our driving styles are very different, so driving style is not likely to be the cause either. There is an extensive thread on this from T-Roc owners, linked from page 1 of this thread. Thinking about this, it seemed likely that for whatever reason, the engine management system was allowing revs to drop too low. I first tried to resolve the problem by switching to Sport driving mode which is available on our Sportline. This alters the throttle mapping. Pinkpanther on this thread tried something similar by altering throttle mapping using Carista. For us, Sport mode helped. Cutting out became much less frequent but was not totally eliminated. My next guess was that one of the sensors that feeds data to the engine management system, or some other component related to idle speed (the idle control valve, as a total guess) had started to get sooted up after 18 months of use. My wife and I usually drive the car very gently. It was time to see if hard use would help by clearing something out. Over half an hour or so I worked the engine as hard as possible, so the indicated power output showed 110kW, the engine oil temperature reached 110 degrees, and the revs were at 5000 whenever possible. That was nearly three weeks ago and the cutting-out has not happened since, either in Sport or in Normal mode. Before that, it was happening every day or two. For now, things are much improved. Of course, the problem might re-appear tomorrow. We’ll see.
  13. Steel wheels come with a thin coat of paint. They will probably begin to rust after one Aberdeen winter. If you spray-paint them with a rattle can before you fit the tyres, you'll likely get two winters out of them before they start to look tatty. It's no more than cosmetic and it may or may not concern you. If you are in it for the longer term and want them to stay rust-free, you'll need to have them powder-coated before the tyres go on. That adds to cost, of course. I speak from experience!
  14. A cost-effective solution that gives excellent capabilities is to fit four of the very best all-season tyres and then sell the four summer tyres that the car came with. See https://www.tyrereviews.com/Tyre-Tests/Best-All-Season-Tyres-2024-2025.htm To get the best out of those reviews you should watch the Youtube version (for detailed commentary) and also look at the web page (for the charts and tables). The two complement each other.
  15. If you are thiinking of having winter tyres on the front and the factory-fit summer tyres on the rear, you will end up with a dangerously unstable car.
  16. mumpsim replied to VRSKevv's topic in Skoda Karoq
    Date handling failure at the OS level is not likely. But any software developer can still make a mess of date handling. I have seen many examples in 20 years as a software author.
  17. mumpsim replied to VRSKevv's topic in Skoda Karoq
    I think that is quite likely. If so, software developers show once again they are unable to foresee and eliminate bugs caused by a change of date.
  18. mumpsim replied to VRSKevv's topic in Skoda Karoq
    That happened here yesterday. 2023 Sportline 1.5
  19. As reliability is your concern (it would be for me too in your situation), why not just buy the official Skoda UK extended warranty? On our cars the cost has often repaid itself several times over. Take the first car in Ootohere's post as an example, a white Karoq, SY67 YJS, with 71,431 miles. The cost today of the warranty for that car is £295. That is the comprehensive warranty; the version covering only named components is £250. Those prices would rise somewhat if you chose a different excess or intended to do more than 10,000 miles a year. https://insurewithskoda.co.uk/extended-warranty
  20. Not quite. Colewood Automotive, the company behind Asda Tyres, is an intermediary but Camskill are stockholders on a large scale.
  21. That is an outstandingly good all-season tyre. I realise you were just pointing to it as an example, but if anyone is thinking of buying via that link, allow me to mention the following: Camskill is an excellent, reliable supplier with fine customer service and very good pricing if all you want is the tyres and can fit them for next to no cost; but by the time you add delivery and find and pay for a local fitter, it's no longer cheap. For example, buying the Conti 215/55 R17 94v TL from Camskill: £125.20 incl. VAT x 4 = £500.80 + approx. £26 delivery + approx. £80 fitting = total approx. £606. Whereas the price at Asda Tyres, with the current discount code WINTER20, delivered to a local fitter of your choice, fitted by them, so you do not have the bother of receiving them at home and taking them to a fitter, nor do you have to deal with it if the delivery goes wrong somehow: total £538. I have no connection with Asda Tyres or Camskill except as a shopper.
  22. Both of the tyres you have been offered would make a negligible difference to rolling circumference / speedo error. The Falken (assuming it's the Euroall Season AS10) is a tyre of mediocre ability and would be attractive only if the package were considerably cheaper than the CrossClimate deal you have been offered, whereas in fact you say it would cost more. It is no surprise that a good independent is much cheaper for wheels and tyres than a Skoda dealer, who are never competitive. But why is your independent not offering you the right size? Not that the 225/50x17 is in any way unsafe for the car, but why not stick to one of the Skoda-approved sizes? Is he perhaps trying to sell you something he happens to have available? Ask him if he will do you a deal on 215/55x17 CrossClimates. Even better, ask about any of the three all-season tyres that are newer designs than the ageing CrossClimate and have better abilities all round, particularly on cold wet roads (though not on snow, where the CrossClimate still wins -- but you won't care about that in Kent). See https://www.tyrereviews.com/Article/Best-All-Season-Tyres-2024-2025.htm
  23. Over the air it updates only part of the whole European map, which in your case would mean most or all of the UK. However, it is said that if you enter a far-off destination, such as Athens or Seville or Helsinki, and start route guidance, it will update all the mapping needed for the whole journey.
  24. This page, dating from the Karoq's introduction in 2017, refers to its LTE module: https://www.skoda-storyboard.com/en/models/connect-yourself-with-the-karoq/
  25. According to the workshop manual, there is one underneath the console between the front seats, another underneath the area between the spare wheel well and the rear seats, and a third in the rear bumper.
