Everything posted by mumpsim
Tyre rotation
Some tyres, not all, must rotate in one direction only. If yours are of that kind you can rule out side-to-side rotation. I avoid it even if it is possible, since tyres wear in a bit to one direction of rotation, depending on toe-in and other settings in the geometry. So it's front to back for me, if at all. My 2026 Sportline is on factory-fit summer tyres. Later this month they will come off and get replaced by four of the best all-season tyres, then the factory-fit tyres will get sold. I've done this often and they do sell eventually.
Considering a Sportline
Having owned two Sportlines and driven a few others, I take the view that the two best options are: - Dynamic Chassis Control. It makes a real contribution to taming the appalling road surfaces that are so common now; - LED matrix headlights. Magical technology at its best. All headlights should be like this and one day maybe they all will be.
Talk to me about brake discs please. Front drivers disc replaced at 8k miles
“30% worn” is not a valid reason to replace brake discs. It also does not mean braking efficiency has fallen by 30%. Disc thickness has relatively little effect on the braking torque available in an ordinary stop. That is determined mainly by hydraulic pressure, caliper clamping force, pad friction, disc radius and tyre grip. A disc can therefore continue to produce normal braking force while substantially worn. Manufacturers specify an absolute minimum thickness. For example: new disc: 25.0 mm minimum thickness: 23.0 mm measured thickness: 24.4 mm Such a disc has lost only 0.6 mm, but it has used 30% of its permitted wear allowance. It still has 70% of its usable wear remaining. Replacing it solely on that basis would be premature. In such a case I would ask the garage to provide three figures: the original nominal thickness; the manufacturer’s minimum thickness; the actual measured thickness of each disc.
3rd Year Service Musings……
On Trustpilot EMaC has a 4-star rating from around 7,000 reviews — decent for the sector, though the negative reviews tend to cluster around cosmetic/warranty product claim disputes rather than the core service plans. Real-world user feedback on forums is broadly that the plans are a reasonable budgeting tool, sometimes with modest savings versus paying as you go and no interest charged, but that you're tied to the dealer network, there's a risk if your dealer loses its franchise, and cancellation fees can apply after 60 days.
1.5 Tsi Power Cutting Out
Welcome to the club that we would all rather not be members of.
Ordering New Karoq for Sept Delivery - What Options ?
See this from May: https://www.briskoda.net/forums/topic/539119-demise-of-the-karoq/ A hybrid seems possible, but there may be more recent or more definite information,
The one we just bought (as per my post above) lost £13k in six months. Fortunately we bought it after that.
LED matrix headlights are very useful and impressive. Dynamic Chassis Control, when in Comfort mode, helps tame the UK's dreadful potholes. To me and my wife (on her second Karoq) these are the outstanding features. We do not miss the variable boot floor. We bought a Sportline last month, six months old with 2,500 miles, from a Skoda dealer. We paid £13,000 less than list price. If you can raise the money elsewhere, discounts like that make it hard to justify a brand-new car or a PCP deal on one. Conversations with dealers have confirmed that new and nearly-new cars sell on almost wholly separate sales streams. I'm told that 90% of new Skoda buyers take PCP, while 90% of nearly-new buyers pay cash and get a far lower price. One reason list prices are huge these days is that many PCP buyers are not much concerned with list price, only with deposit and monthly payment. Skoda will of course be delighted to sell a new car, but they can't sell enough of them and have to provide the alternative nearly-new stream to run alongside it.
MySkoda App - ACCESSING VEHICLE DATA TRANSMITTED TO VAG..
Very interesting. Thanks.
build spec
There used to be several VIN decoders online that would list all the build codes free of charge. So far as I know, they all now cost a bit and require a 'membership'. If anyone finds a free one, please post it. A couple of weeks ago I asked a Skoda dealer to print me the build sheet of a car I was looking at. He didn't know what I was talking about. When I explained, he showed me his computer screen, with the car's spec listed in a folder-tree format so it was necessary to click and expand numerous categories to hunt for items. He thought there was no way of printing or exporting that in full. As with the lack of a downloadable manual for several years now, it isn't helpful.
Front Castor Alignment
I guess you are right. As you say, caster is non-adjustable on the MQB platform. The angle of the MacPherson struts is primarily determined by the fixed geometry of the subframe, lower control arms, and top strut mounts. So something is either bent or worn. But since you know it was in spec after the car was abused and repaired and now it isn't, that suggests wear now occurring rapidly as a result of the earlier damage. Someone who knows more than I do says it could be various things: lower control arm bushes, with the rear bush (the large one closer to the subframe) most susceptible to wear; the top mounts, which include a bearing that can start to disintegrate; and also ball joints, drop links, and subframe bushes. However, you already had the subframe dropped and re-fitted. I'm not sure which of the other items is most likely to mess up caster angle, but it does seem that a full suspension check is again needed. Many of these items, when worn, produce clunks, rattles, or creaks, which is a clear sign of a problem.
Well done for persisting with this and not being fobbed off as so many people have been (including me). It is a victory to have got Skoda to admit to the cause of the problem. Let's hope DVSA will recognise it is a real safety issue. Let us know if there is any benefit in getting several people to back up your story to DVSA.
Demise of the Karoq?
A successor may be coming not very soon, or perhaps not at all: https://www.autoexpress.co.uk/skoda/karoq/368846/exclusive-new-generation-skoda-karoq-cards-hybrid-power And another report: AutocarA new Skoda Karoq may be on the way... | AutocarSUV was launched in 2017 and has racked up more than 100,000 UK sales since
Adaptive Cruise Control (ACC)
Yes. Don't know. They don't. Skoda sells in over 100 countries but not in the USA since 1967.
- Software update, which software?
A cautionary tale - Speed Bumps Vs Karoq suspension
Rim protection is now usual on quality tyres of 50 profile or lower. But one does still need to check. Thr budget generics often lack it, but there are also exceptions from the better brands, even among ultra-low profiles tyres. For example, the Uniroyal RainSport 3 275/40R20 and the Michelin Primacy 4ST variants in low profiles lack rim protection. Descriptors such as FP, RFP, FR, MFS, or FSL mean that rim protection is present.
We have the Turanza All Season 6 on our Karoq and they still have loads of life left after 20,000 miles. 25,000 should be easy. And the ride comfort, unexpectedly, seems better than it was when the tyres were new. On another car I have the Pirelli Cinturato All-Season SF3 which is a more recent design and usually now beats the Turanza in the objective tests, though not by very much. I'd probably choose that to replace the Turanzas, though road noise on the particular car I have them on is not good. Any casual readers should note that the Turanza All Season 6 is as unlike the Turanza T005 summer tyre as it possibly could be. The T005 is what many Karoqs get at the factory and it's one of the nastiest tyres around from the premium brands.
That is a cautionary tale indeed. Thanks for writing. It's a reminder that the Karoq is a highway car, not some robust off-roader. Just out of curiosity, who was the culprit? (Not expecting anyone to be named, but was it someone in the motor trade, or what?) And how did you get evidence of the speed over the humps? Dash cam?
Ebay spare wheel kits Vs ordering from dealer/Caffyn's etc?
Yes. Our 2023 Sportline (2WD) has a factory-supplied spare wheel and 215/60 R16 tyre.
New Karoq 2026
Since you read it, you will already know that that decision has not yet been made - or at least not made public.
New Karoq 2026
See this which I posted on Wednesday: https://www.briskoda.net/forums/topic/537518-karoq-hybrid-maybe
Karoq hybrid .. maybe!
Coming not very soon, or perhaps not: https://www.autoexpress.co.uk/skoda/karoq/368846/exclusive-new-generation-skoda-karoq-cards-hybrid-power
Advice needed! 2025 Karoq 1.5 TSI DSG juddering when pulling away - Only 5,000 miles on it.
I too would be walking away. Though my last word to the sales staff before leaving would be that if they put the car through the workshop, find the fault, and fix it, they'd be welcome to invite you back for another test drive. I certainly wouldn't be committing to buy the car on the understanding that any faults can be fixed after you take ownership.
Fuel Consumption stats- accuracy
If anyone can be bothered to check the accuracy of an odometer, one method would be to see how closely its readings correspond to the distance marker posts (the small posts at 100 m intervals) on the motorways. However, you'd need to check over several km, as individual distance marker posts are not guaranteed to be precisely placed. They are intended to allow people to refer to their location (after breaking down or coming upon an accident, for example) and are not to be taken as survey-grade positioning.
