Colin170CR
Everything posted by Colin170CR
  1. Maybe Germany doesn't have potholes? They look good but I too would question the ride quality. So what rubber band profile tyres have you got fitted?
  2. I have an old TomTom unit. The original bow back CRT TV shape but I'm not sure if it still works because I've not used it for years. It was dam expensive when new £500+ if I recall). I also have a more recent Garmin with free map updates for life. I don't really need it for our current cars both of which have sat nav but, it is useful to take on on holiday if we are hiring a car without Sat Nav (in the EU at least). I have taken it abroad in my own car as a backup because the factory fitted Sat Nav's in both our cars can go AWAL sometimes & post code location is a bit of a lottery sometimes. My wife's Karoq has a newer version of the Skoda / VW system. My sat nav does not display road speed limits unless the sat nav / maps is turn on. I believe it can be coded to show the road speed limits when not in sat nav / map mode but I have never got around to having it done. There are quite a few other code changes I'd like to have done (e.g. Skandi rear DRL's) so if there's anyone out there in the Bucks area that has the gizmo that can re-code stuff I would be interested in a "Tinker day".
  3. Yearly oil change / inspection coming up. I just hope it doesn't mushroom into another expensive one like last year - replacement water pump / thermostat & new discs & pads 🤞
  4. Spooky. Got a message today from my Indi VAG garage to say that I'm due for an Oil & service interval service. Got into my car this evening & hey presto I go a "oil & service notification in 27 days" message on my ODI. They are on the case or what! Trouble is I need to sell my wife's Karoq & replace it with an EV before I book mine in for a service otherwise we have no transport while mine is in for service! Anyone need a 2019 Karoq Edition 1.5 4x4 with pano roof, gas bonnet struts, rear bumper protector, door cill protectors etc etc.
  5. That's quite a large investment. I assume you plan to keep the car for some time? Did you ask the garage to change the DCC Normal & Comfort settings or have they done this on their own? Also, how did they change the Comfort & Normal settings for the stock adjustable damper settings? I know this can be done on aftermarket replacement adjustable shock systems but I was not aware it could be done with the OEM shocks. I'm interested because I also find the Comfort & Normal DCC settings rather "soft" which is why I drive mine in DCC Sport mode most of the time.
  6. I cleaned my roof bars the other week with some Meguiars compound which was semi successful so I'd be interested to see how you get on get on with this product.
  7. I'd go independent Skoda, VW, Sear, Audi specialist. Worth seeking one out local to you. If you let us know where you are located others here may be able to make some suggestions. E.g. I use https://www.inde-tech.co.uk/ for my general servicing.
  8. Sounds suspicious. New cat at such low mileage & emissions issues? Might be worth having a diagnostic done on it to see if there are any hidden / historical faults.
  9. E mode is pretty pointless on a 272 / 280 &, as you say, the coasting is really annoying. 99Ron fuel does make a difference (more power) & smoother running. I have Start Stop turned off as well.
  10. Heavy right foot?😉. Excess use of Sport mode or manual / paddle changes? I run mine in D mode 95% of the time & S mode only when needed or to get engine braking when approaching red lights or roundabouts. What fuel & you putting in it? I only use 99 Ron Momentum from Tesco where possible. Mine is also a 6 speed so 7 speeders should get better mpg on a run or on the motorway. Others on here may have some extra ideas.
  11. In eco mode perhaps, but I doubt if anyone fitting a Throttle Pedal is going to run it in Eco mode. As always it's down to how the car is driven. I don't rag mine but I do like to get up to the road speed limit quickly & then cruise along in top gear as much as possible. Originally I had the XLR set for R+ mode but found it too aggressive so backed it off to R then S+ then S where it is now. As I suspected my wife has not said anything since I took the XLR out of her Karoq & put it into my Superb.
  12. Likewise. I'm averaging 27.5mpg currently. I used to get over 65mpg from my old MkII 2.0 TDi 170 DSG when I was commuting up & down the M1. Thankfully I don't have to do that trip anymore.
  13. I got a low coolant alarm on my dash first. Went looking for the leak & couldn't find it. Topped it up & forgot about it until it went in for a routine service which is when I got the call to saw the pump was leaking. I guess they new what to look for at that age & mileage. As you say it is a common problem on that engine.
  14. I know. Some silly prices out there but I think there are some bargains out there if your not too picky - which is where I will come unstuck. Of course it depends on what your budget is but I would have thought there would be plenty of previous gen Fabia's out there.
  15. Been there & done that with the water pump & thermostat change. In my case some discs & pads were needed at the same time. Bill was around £1k at my independent. It hurts when its an out of the blue necessity. I'm seriously looking at a used Electric car now for my wife & I to use as a daily driver & keep the 280 for long distance / holidays.
  16. Early days yet but so far I've not seen any change in mpg. After the Stg 1 remap the mpg stayed pretty much the same as the stock engine at 25 around town & up to 36-38mpg on a run.
  17. I believe there is an "Audi Throttle" setting that can be activated / adjusted with VCDS / HEX software which sharpens up the throttle response. Some reports say it works & others say it doesn't make any difference. Worth a try if you have software (I don't). In fact I would be interested in a group "software change day" if within reasonable distance of my home & be prepared to pay a reasonable fee for the privilege of having some settings tweaked / activated e.g. Scandi rear DRLs, speed sign recognition & other hidden features.
  18. I have a Revo Stage 1 remap. Nothing else. Revo
  19. Not really. Before the remap there was always a bit of a "dead spot" between idle & the first bit of pedal travel. After the remap it was still there albeit reduced. Personally I think it's the lag on the turbo spooling up more than anything else. Now with the RC XLR on S+ setting it does sharpen it up in D mode which now feels more like the old DSG S mode but there is still a tiny bit of hesitation. TBF I am spitting hairs here because once it gets off the line the pick up is very fast. What I have noticed is that in D mode it changes up lower in the rev range & uses the increased Torque (from the remap) to gain rapid forward motion. I have a K&N air filter fitted & you can hear the roar of the air being sucked into the engine just after each gearchange. Put the XLR into R or R+ (Race) mode & with S mode selected on the DSG it becomes a Hooligan. Very rapid. Almost too rapid & the gearchanges become quite savage. Don't think I'll be using that mode unless I take down the Santa Pod 1/4 mile. 🏎️
  20. Well no sooner said than done. Yanked the Racechip XLR out my wife's Karoq (while she was out) & fitted to my Superb. I wonder if she will notice it's gone? Exact same connections & pedal layout. It does make a difference in the Superb. I'm not sure that N (normal) mode on the Racechip adds anything in D mode but S & S+ mode on the Racechip certainly do. R (Race) mode is a bit bonkers in D so I won't be using that setting. If I want bonkers acceleration I'll put the DSG in Sport mode & listen to the wailing of the twin flap assisted exhausts as the engine races up to just over the redline before gear changes. Its early days using it in my car so I'll see how I get on with it. Certainly better to re-use it than to let it go with the Karoq when we sell it.
  21. Even with a remap mine still has a bit of lag taking off in D. Not a problem if its in S mode but that can mean rather savage acceleration which isn't always needed. As mentioned elsewhere I have a Racechip XLR on my wifes' Karoq which we are selling soon so I think I'll switch it over to my Superb & see what it can do.
  22. To recover the gas you will need an approved refrigerant recovery cylinder like this one. Yes, different recovered refrigerants (and the hoses used) are kept separate from each to avoid contamination. E.g. R22 uses mineral oil for lubrication whereas all newer refrigerants us POE synthetics so cannot be mixed together unless the refrigerants are going to be destroyed in which cas different refrigerants can be mixed together in one cylinder & labeled accordingly e.g. R12 from old car systems with R22 or R407c. Brazing pipes without nitrogen is the main cause of 4-way valves getting stuck & internal filters & cappilliary tubes getting block from the scale that is formed inside the pipes. It's worth checking out the 4-way solenoid because this could be an easy / cheap fix. Also, tapping the valve if the solenoid istests OK. If you have a A/C engineer as a neighbour I would buy him a big dinner & see what he can do for you. New modern systems don't cost that much & your neighbour could probably get equipment from his normal wholesaler / supplier & install it for you with your help at "mates rates". I'm not sure what the situation is in France but in the UK Refrigeration / A/C wholesalers "should" ask to see your certification cards (FGAS, REFCOM etc) before they sell anyone any refrigerant or A/C equipment containing refrigerant. This it to prevent unauthorised persons handling, transporting or installing refrigerant based systems. It's a tightly regulated industry over here but like all things there are ways of getting around the rules. Hope this helps.
  23. My system is a heat pump so it can heat & cool. If your system works in cooling but not in heating the problem is either:- 1. Stuck slider inside the 4-way valve. 2. Burnt out / open circuit Solenoid on the 4-way valve. 3. Combination of 1 & 2. 4. No signal from control board to the 4-way valve solenoid. If you have an electrical tester with a continuity / ohms setting test the solenoid on the 4-way valve. If it’s open circuit, then a new valve assembly or just the solenoid (if removable type) will be needed. If the solenoid checks out OK then it’s either a stuck slider inside the valve or no signal from the control board for heat mode. Check for signal from board when heat mode is selected. If signal & solenoid check out OK it’s a stuck slider inside the valve. Gentle tapping with a soft faced hammer can free up a stuck slider but if it’s really stuck & cannot be shifted then a new valve assembly will be required which will require all the system gas to be removed into a suitable refrigerant cylinder, the old 4-way valve un-brazed & the new 4-way valve brazed back in with nitrogen flowing through the pipes during brazing to prevent any oxidisation on the inside of the pipes. After fitting a new 4-way valve the pipework must be pressure & leak tested. After that a vacuum pulled on the whole system to 1,000micron & held for 30mins to remove all oxygen, moisture & other contaminants from the system before adding any refrigerant back in. Below is a picture of a 4-way valve with a removable solenoid valve & below that how a 4-way valve works in an A/C system. If the slider is stuck & new valve is required, it will probably be better to replace the system with a new one rather than spend time & money on trying to fix it. A new system will be more efficient & come with a minimum 3 year warranty. The existing system is 16 years old so has lasted reasonably well. However, if you do go for a new system note that the pipework will have to be replaced as well because old R407c system pipe sizes are two large for the latest R32 gas systems which generally use pipe sizes as least one size smaller. If you let me know the make & model of your system, I may be able to find a service manual for it which may help you diagnose the problem further. Interesting info on the flaring tool name in French & history. Fun fact, pipe-work flaring tools for R410a & R32 pipework systems are different than for older R407c & R22 systems. The angles of the flare are different & the tool forms the flare concentrically & not by just crushing the copper all in one go. Also, all modern flared joint nuts must now be tightened with a torque spanner to the manufacturers recommended setting. In the old days we just used two spanners until we thought it was about right or, until the cheeks of your backside touched together 😂. Invariably this meant that most flare nuts were overtightened which was the reason after some time many flared joints sheared off or split which caused refrigerant leaks. I hope this helps.
  24. To be fair most engineers will charge at least £350 for a P&L test + whatever it takes to repair the leak & recharge the system. You could be looking at £400-800. Might be worth considering replacing the indoor / outdoor units with a more modern versions. Most new models can re-use existing pipework if its the correct size which needs to be flushed to remove any existing oil or contaminants before recharging with R32 refrigerant which is what most new small capacity systems are using now. Good luck with your search.
  25. As per JR. If installed correctly a house A/C installation should never leak unless the flared pipe joints on the outdoor / indoor unit have become weakened or the pipework itself has been damaged. Of course there's also the possibility of leaking pipes inside the outdoor / indoor unit due to corrosion or damage. If that nameplate is anything to go by it hasn't been serviced for a very long time. It should be checked & cleaned at least once a year by an A/C engineer. I did mine just last week & the outdoor coil was full of leaves & debris which would reduce its efficiency. The indoor unit is also a breeding ground for bacteria so should be checked & cleaned with anti-bacterial spray every 6 months. The condensate pipe to outside or via a pump also needs to be cleaned & flushed. I think I can just make out the refrigerant type as R410a which is an HFC refrigerant. While still available R410a is being phased out as higher global warming refrigerant. If the outdoor fan is not coming on & the compressor not running then it is probably a low pressure issue due to loss of gas. It needs a pressure & leak test by an FGAS certified A/C / refrigeration engineer. By law no gas gas can be put into the system until the leak has been found / repaired & a vacuum pulled on the system to remove any moisture or non-condensibles that may have got into the system. The service manual for your 2.5kW outdoor unit can be found here http://mitsubi****ech.co.uk/Data/M-Series/MSC(H)/2007/MUH-GA-VB/MUH-GA25[35]VB_SM.pdf This indicates your system is circa 2006 vintage. Hope this helps.
