Everything posted by bspman
Newbie, South East London
You should be sorted then, I hope! It was only a case of replacing due to early versions failing. How long ago did they replace it?
Mot fail.... dpf removal
That may help, but I imagine it won't solve the issue of excessive smoke from a rich map.
Only thing constructive I can say is once it's fixed - make sure you've got the paperwork to say WHY it's been tampered with (for replacement). Excess smoke is a result of no DPF so none of the particulate being caught. A Call to darksidedevelopments might be in order to see if you can get some help and advice.
vRS Petrol Facelift CCZA valve cleaning
I can see you have the same issue as mine. Would be interesting to see if it sorts it out for you!
Saying Hello...from County Durham
Welcome. I actually quite prefer the mk1 over the mk2 (aside from the lack of rear leg room!). They're brill cars
Without us, they would be nothing!
Love the alloys on that!
- Hello!
Hi from jbs
Welcome @jbs is it a petrol or diesel? If it's petrol please please make sure your timing chain and tensioner have been replaced!
Newbie - well returning after a long while!
That looks gorgeous!
Skoda newbie
Welcome to the forums. Not sure how you managed to accidentally buy it, but a stage1 remap is a great starting place.
Hello all form London UK
Welcome. Nice pick! Which side of London are you on?
Hi there 🤗
Welcome Ali - Nice Engine!
Welcome @CarlyonVRS - Is it a petrol or diesel? If it's petrol - please please please make sure your chain and tensioner have been replaced or get it done ASAP.
MK2 FL TSI Octavia VRS (2010) Misfire issues
Hi, so I've got a 2010 VRS (petrol) with misfire issues (engine code CCZA). Breakdown: I've checked engine blocks whilst driving. Cyl 2 misfires under gentle accelleration when cold (as in - engine not at operating temp). NO EML I've swapped 2 and 3 coilpacks - still misfiring cyl 2 as above. New spark plugs were fitted a while back by an indie, but original coilpacks An injector (not sure which one) had a new seal applied to it whilst at the indie for my chain/turbo issues. Have been told compression looks fine on all cyclinders by above indie I've fitted new coilpacks (r8s) but the problem still persists. VCDS scan showed below error around evap. Address 01: Engine Labels: 06J-907-115-CCZ.clb Control Module Part Number: 1Z0 907 115 AF HW: 1Z0 907 115 F Component and/or Version: 2.0l R4/4V TFSI 0010 Software Coding: 0203000C1C070160 Work Shop Code: WSC 73430 790 00999 VCID: 79FE6174307CCD87E0-802C 1 Fault Found: 001089 - EVAP Emission Control Sys P0441 - 000 - Incorrect Flow - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 190354 km Time Indication: 0 Date: 2044.14.06 Time: 21:58:08 Freeze Frame: RPM: 835 /min Load: 20.4 % Speed: 0.0 km/h Temperature: 89.0°C Temperature: 18.0°C Absolute Pres.: 1010.0 mbar Voltage: 14.224 V Readiness: 0000 0000 Fuel cap seals look like they're cracked so maybe a new fuel cap needed. Thoughts on where to go from here?
