Everything posted by kkbc
Air Con Compressor
That's helpful thanks, i know little about cars and wouldn't have a clue where to start with what you've mentioned, but certainly food for thought. Think i may take it to a more specialized place to see if it's any of the things you've mentioned. I did have it re-gassed prior to this, they were really helpful. After an hour of whatever they were doing told me it's not working, don't know what's wrong with it. Good old Kwik Fit.
Air Con Compressor
Yeah - £370 all in.
Air Con Compressor
The air con has never worked on this car since i had it 2 years ago - bought it in the winter and didn't think to check... Had it checked out and confirmed that it needs a new compressor (common on these by all accounts..) Quoted £370 all in. Don't fancy paying that amount. Is it worth taking a chance on this you reckon? https://www.ebay.co.uk/itm/114809129436?fits=Cars+Year%3A2012|Model%3AOctavia&hash=item1abb2849dc:g:j2UAAOSwNTxgnAxx
Indicators intermittent
I had this on mine - sprayed some contact cleaner down the indicator stork which fixed it
Skoda Superb Mk1 1.9tdi 130bhp Elegance Saloon
Hi, Failing electrics (lights etc) usually points to water ingress I had the clicking from around the hazard light switch area - i sprayed compressed air down the gap in the indicator stalk which seemed to stop it. Didn't have the non working indicators though. Just the random clicking.
Loss of MPG
It was both. Sounds like something expensive... would there not be an error thrown up on the dash?
Loss of MPG
Thanks for your reply. I did the same test today doing what you suggested to slow/stop the car - which was easy to do so quite conclusive as to what the issue is. Rear brakes were pretty much cold. The front ones very hot - could feel the heat approaching them. Thought it could be engine heat initially but could barely touch them. Wonder what's causing this? Simple to fix? I'm not very mechanical 😁
Loss of MPG
Think they could be sticking? It's always had a slight judder when breaking to a stop. No noises though.
Loss of MPG
Evening all, I have 2012 Octavia 2.0 TDI L&G (FL). I've noticed recently noticed a loss in MPG, i've always been impressed with how high it was. I tested it this morning down the motorway. Purposely Set cruise low to around 65 mph. Normally it would easily achieve 60-70 MPG. It struggled to return 52/53. One thing I have noticed is that when you take your foot off the accelerator (still in gear) it slows down significantly , even when going down hill. No warnings on the dash, no noises, no loss of power. Just seems really strange. Any ideas? TIA.
Locking and Indicator Light problem
Might be the breaklight switch, happened on mine although it was the break lights that stayed on.
Oil service workshop, Reverse lights and other electrics not working..
Evening, driving home on Friday had an awful burning smell in the car - wasn't sure if it was from outside. However after shutting down the engine and then starting it again i got the Oil Service Workshop on the dash (oil levels fine and recently changed). Along with that the reversing lights, parking sensors and dimming rear view mirror have also packed up. Assuming this could be a fuse that needs changing? I have changed the ones on the side of the dash - i read it could be fuse number 4 - 5a, this made no difference... Any guidance would be appreciated.
