Everything posted by roaddetective
Kopacek LED interior light upgrades - how to fit??
Sorry I can't help with your install, but I do have some very bright LED bulbs in the roof of my car. as well as the boot. All I fitted were some quality LED bulbs that fitted straight into where the old bulbs came out of. I think mine are as bright as you would need them. I have the same car as you as well.
K&N or cone filter.
The standard hardware works well on my Stage one mapped VRS Octavia. It's making 329bhp without any breathing problems.
Custom Boot and Bonnet badges
I bought my colour coded and all black badges from superskoda. A bit expensive but good quality.
My initial views on Fitting Powerflex red dogbone mount insert
I am sure now after doing around 300 miles it has settled a little with a bit less vibration on tickover. Unless of course it's just that I have got used to it, but I am sure it's better. There is a cut ridge in the road local to me just as you accelerate off a roundabout. Previously it tended to cause that bang if you were on the power at the time you hit the cut in the road. You did not have to accelerate hard either to cause it. The other day I drove up to that roundabout and did the same thing, accelerate off it to the cut in the road, although again nowhere near flat out. This time no bang underneath, so there is some improvement now after the insert has been fitted. Must push it a bit harder next time to see if the banging has been fully cured. Mind you, I am more than happy with the results so far. As for slicker-feeling gear changes, no change there. Could that be as my car has only done 21k miles, everything is still fairly new and still tight anyway?
Boot by Candlelight...
Punch it into Google and quite a lot come up.
I replaced them, along with LED bulbs in the interior roof. I have in the past bought some cheaper ones, but they seem to keep glowing a little even when switched off. I then bought some more expensive ones again from ebay. In 2019 they were £15 for 4. The make was AUXITO and they have been fine ever since. The LED bulbs are far superior to standard bulbs.
Got the good tyres already. Michelin PS4S in 235/35/19. Slightly wider than the standard 225/35/19 to get more rubber to the ground, as well as trying to protect the alloys from pothole damage.
Yes still the original clutch with it so far managing the extra power no problem. Mind you, I am not one for flat out standing starts and use the higher revs when I want good acceleration, rather than use too much torque in the lower revs.
Today I fitted the mount insert. I went for the red one. Usually it's red for diesels and I have a petrol engine, but I wanted as little vibration as possible and the red is a softer one. There is of course a bit of vibration on tickover which is slightly annoying, but I hope it settles down a bit over time. In reverse as expected, again a bit of vibration, but no worse than on tickover and how often do you drive in reverse anyway! The car also had a sound on start up, which was a lower tone than usual. I took it for a good drive up the road, giving it hard acceleration, holding it at 50mph in 6th gear, even holding it in top gear at 30mph. I found once the car got moving there was no real difference to how it was before the insert was fitted. Will have to try to find an uneven road surface to try to create those bangs underneath the car I had before. Maybe now those bangs are a thing of the past. I will update this thread once I get a few miles on the clock, which of course might be a while with the bare few miles I am doing at the moment due to this bloomin virus.
Banging at the front when accelerating and hitting a pot hole.
Hi all Somebody must have had this problem in the past, so I thought I would pick a couple of your brains. It has really started to happen more since the remap, as the extra power seems to upset the car when accelerating and hitting a very rough surface. Get a pothole and there is sometimes a hard bang from the front of the car, usually on the near side. I think it's down to the average shock absorbers fitted to my Octavia VRS, details of car below. It just seems the shocks are either fully extending or compressing that is causing the bang. They can't manage the job they are meant to do. On my previous Octavia VRS, a 2011 fl model, I fitted Bilstein B8 shocks all round, which did a brilliant job of absorbing the bumps and uneven surfaces. Do I really need to spend on new better quality shocks for a car that has only done 20k miles? In normal driving you never get this problem, as the car is smooth and handles quite well.
Does my car have a GPF?
On one of my previous topics a member asked whether my car has a GPF. That got me thinking, as a GPF can affect my intention to get a stage one remap. From a sticker in the engine bay on the left side engine mount, it states a built date of March 2018 and it was registered end of July. So do any well informed members know the answer to this question, or do I need to look underneath the car to find out? All details on my vehicle are as seen below.
