briscaF1
Everything posted by briscaF1
  1. Any recommendations for an underseal brand? Would prefer it to not to be obvious that it's been repaired there so I guess brush on would be best to keep the area covered (presumably be black against silver black) down?
  2. Hello Caught the sill dropping off a high kerb today. Doh. What's the best approach to repairing this, please? Cheers
  3. Hello I've noticed that, after starting my 1.2 TSI (4 cyl) on warm days, the engine runs lumpily for a short while. It feels like the engine is hesitating, like in the old days if mechanical points were worn out or plugs/leads needed replacing etc. I've seen elsewhere on here that the engine may be running in a special mode for 30s after start (ironically for fast warm up) - does this apply to this engine and could it be responsible? If this is responsible, since I imagine there is an ambient temperature sensor, why does the fast warm up cycle need to run on hot/warm days? Cheers
  4. I've but tried any apart from the main dealers. I've tried a number of local independents but they never quite did anything right hence looking for an independent 'specialist.' I'll take a look at your link - thanks.
  5. Thanks. I'll take a look. I have sprayed them with silicone before but maybe that was just covering up the problem.
  6. Getting a consistent creak over speed bumps on our MK2 combi. Sounds like it is coming from the passenger side footwell so I guess it is a suspension bush. What are the options if this is the case? On smaller Ford's with chocolate bushes, I used to replace the entire track control arm but is this necessary on the Fabia? Thanks in advance.
  7. Can anyone recommend a decent independent near to Stoke/Stafford, please? Friend of mine who used to look after bigger jobs on our cars no longer available ☹️
  8. Hi, Can anyone recommend some lockable roof bars for 2014/2017 combos? Both cars have raised "open" rails. Also, anyone know if VW Touran bars will fit on the Fabia estate. They're both open rails. The Touran is a 2007 model. Cheers
  9. "Skoda: 1.2 litre 3-cylinder petrol engine, 1.6 litre FSI, 1.2TSI and 1.4 litre TSI 4-cylinder up to 2012 when replaced by belt cam EA211 (though some Yeti 1.2TSIs remained chain cam up to 2015)..." The above text is from that linked site but is it correct? As I understood it: 1.2TSI (8V) are all chain cam, which covers MK2 fabias & engines prior to 2012 may have issues with their chains. These engines ran up to 2015 (?) 1.2 tsi after (in fabia MK3) are 16V and have belt driven cam. 1.0 tsi (2017 on?) are all belt. Is the above correct?
  10. That's what I thought. Bosch generally don't make any rubbish and I half expected Bosch to be standard supplier for VAG.
  11. When you say, "that's that", you can reset the stereo by holding the power button for a while. Does that recover it?
  12. Hi, Noticed the window seal rubber on my 2017 car looked like it was about 10 years old with it being cracked/hard/perishing. Is this expected? Are these easy to change? Thanks in advance
  13. Anyone use Bosch plugs in this engine? With my wife's mk 2 8V 1.2 TSI, I used Bosch (they were cheaper) and it has been fine. I was planning on doing the same with mine when the time comes.
  14. I've had this recently, too. What's your memory card formatted to? I had a 32GB sd card plugged in for ages (over 12 months) and that was formatted to exfat or FAT32 (can't remember which) with no problems. I then formatted a usb stick for NTFS and put some music on that. Everything played fine but I (once) had a warning about unplayable files that required a stereo "reboot" to resolve. I then swapped the SD card for a 64GB micro SD (in an adaptor) formatted for NTFS (and unplugged the usb stick) and have had a few more warnings from time to time but these resolved themselves without a reboot. It has been cold recently but it (Bolero) seems less tolerant of NTFS than other formats in my opinion.
  15. Can't comment on the 1.0 TSI but I have a 2017 1.2tsi Fabia estate (90HP) and missus has a MK2 1.2 TSI estate (86 HP). They're both 4 cyl Neither feel underpowered, in my opinion, even when loaded up and the roof box is on. They certainly feel sprightly compared to my old 1.6 Focus and are a lot better on MPG. They've all got pretty good torque so they're easy to get along with and you don't really have to rev beyond 3000 RPM. I did test drive a non turbo mk3 (either 60 or 70bhp?) and that was pretty flat but ok, I reckon, for doddering about without having to worry about a turbo etc. If you like tear-arseing around, you might have a problem but for general driving and motorway use, they're perfectly usable.
  16. Just for the benefit of others. This video talks about the "old o-ring left in" problem that can occur. https://youtu.be/FtosVQJBjtw?t=1008
  17. That's what I got - a carbon Mann filter. It was about £12.
  18. Didn't realize it that was easy. That's great and thanks for the quick reply. By "new seal", I presume that means the one already attached to the new filter and that the old filter should come off completely with no parts of it left behind. I.e. new filter seal goes to the metal oil filter housing that the filter screws on to? I've generally ordered a kit from Opie and this just contained the oil filter and oil without any other items.
  19. Hi all, I'm just about to do an oil change / replace the cabin filter. I read elsewhere about oil filters not being replaced properly in cbza engines - something about the old oil seal not being replaced. Is this referring to the rubber seal of the oil filter (pictured) being left behind when the old filter is removed and the new one screwing down on top of this? https://static.onlinetrade.ru/img/fullreviews/24772/16_big.jpg Also, is there a guide on replacing the cabin filter? Is this straightforward? Thanks in advance
  20. Hi, Thought I'd silence my Mrs' complaining about not having the same stereo as in my Mk3 model by getting a Pure Highway 600 for DAB and handsfree. I did look into getting an upgrade Skoda stereo unit to replace the Swing but the Pure is only £64 and seems to do everything that she wants. Does anyone have one of these in a Mk2 Fabia? Any problems? Any hints on best location/wire routing etc for installation? I presume you get a dual output USB adaptor in the box and that it should be easy to disconnect the unit to throw it into the glovebox when parking in ropey locations? Any advice greatly appreciated.
  21. They're relatively like for like as it had Bridgestone Turanza on the rear and Hankook K435 on the front which were changed for the same fronts and some Maxxis rears. I do brim to brim from time to time and find the dashboard optimistic (on both cars) but it's pretty consistent so I do treat it as a reasonable reference. Hers is an 86PS from memory whereas mine is 90. They're both 4 pot TSI 1.2 but mine is 16V and hers is 8. I think the point I'm making is that mine has always been better on mpg than hers but I'd say that hers was now noticeably worse (I noticed it after all!) and I just wondered if it might be an indication of something amiss.
  22. It was zeroed as it auto zeroes. The car is well maintained with recent tyres (pressures checked regularly), air filter and plugs (all about 10 months ago). The weather was colder and wetter since the last time I remember the mpg from on a dual carriageway run but the weather was similar in the two consecutive days that I drove both.
  23. I drove my Mrs' combi yesterday and was surprised at the fuel consumption (as reported on the dash). Running the same routes as I would in my 1.2 TSI 90HP (4 cyl) 2017 Combi, it was 10 MPG short driving it pretty much in the same way. I used to drive the car a lot and I remember it being 'better' on MPG than it is now. On a run on a flat dual carriageway, doing about 56, it could usually get 55+ MPG but it seems worse now with only one occupant. So, I can guess that either they changed the MPG calculation (although this doesn't account for the difference from now to then) or something is amiss ? Anything I should look for / possible causes ?
  24. Hi, I read that this engine (1.2 TSI) has a 3.9l oil capacity. So, when I order some oil from Opie, I receive 4l of oil but this never actually reaches the top mark when I change the oil myself, even when it has all gone in. Does the 3.9l not include the oil filter? It's not a particular problem since the oil level is 3/4 of the way up the stick - I'm just curious. Cheers
