MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. @Tell my apologies, can you please simplify your English? mine is so often too limited to read your posts 😒
  2. @aslan14 MQB3_OI_JND_Europe_v1.31.50.zip 1.4 Gb
  3. all reports which i have seen were about Mk3 not Mk3.FL 2020+ if Monro's shocks are ok, what is rare, and programming instruction is clear, then 15 profiles mod is an option in other cases Bilstein shocks + stiffer Eibach Pro springs without programming (only optional adaptation)
  4. @travs that's not true 🥲 I just wrote some scripts to guess the file names of the next releases in last years scripts becomes useless, because VW has closed down their offline maps download server
  5. DNFE 2023. i'm skeptical about long intervals, especially with my urban 22 kmh average speed replacing on ~ 7.5 kKM 0w30 Liqui Moly TOP TEC 4210 LL3 replace interval calculator by avg speed: motor hours * avg speed = replace interval (km) 300 * 20 = 6 000 300 * 50 = 15 000 300 * 80 = 24 000
  6. Bilstein B6 + Eibach Pro springs (from Kodiaq), version without lowering -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
  7. in most cases 0w30 will be better instead 5w30, due higher percentage of true synthetic additives i can recommend 0w30 Liqui Moly TOP TEC 4210 LL3 DNFE 280ps 2023.
  8. What happens when you try to change the section?
  9. in my previous 2016. Mk3 i have preventively replaced 5Q0 121 407 G to 5Q0 121 407 M ~ 30 euros -> https://www.briskoda.net/forums/topic/490705-silikat-bag-in-coolant-resorvoir-diesel-engines/?do=findComment&comment=5515679 -> https://www.briskoda.net/forums/topic/475223-expansion-bottle-replacement/page/8/#comment-5435158
  10. interested, interested, just have been adopted to that during 10 years with this body🙂 7y 2016. Mk3 220ps FWD and third with 2023. Mk3.FL 280ps AWD and upgrade seem costly with no guarantee of success also, if touch this position, then logical addition will be aluminum arms, which for non lowered? have you add lot cheaper things, like additional rubber sealants? before vs after ( profile D ) profile Z
  11. @DrAvalanche dominates front bottom, around the legs, but what interesting, it's less annoying when i'm on passenger(right) seat
  12. added -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/2/#findComment-5760901 dominates now front bottom, maybe have a connection to unfound "ventilation" holes -> https://www.briskoda.net/forums/topic/530346-cold-air-breeze-in-obd-socket-area/#findComment-5924870 it's now better than A6 from factory, but still far away from BMW5
  13. Bilstein B6 Damptronic + Eibach Pro -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
  14. @Tell OTA and unit firmware updates come with logos base included Phonostar's base contains only logos, stronger(beat previous) will be last installed version I don't expect to receive OTA updates on mine, due i didn't extend online maps subscription and left only online remote access for Webasto
  15. try also other two links, they all are Mib3, just different devices devices type classification after Mib, Mib2, Mib2.5 isn't clear at all :( OTA and dealer Mib3 Amundsen(2023 Mk3.FL Å koda Superb) firmware updates gave downgrade if compare to Phonostar releases, but "upgrade" if compare to factory flashed version Radio database version: 1.30.36 (factory 2023.01) 1.31.48 (user 2024.01, downloaded from Phonostar.de) 1.30.36 (dealer 2024.01) 1.31.44 (OTA 2024.03.18) 1.31.50 (user 2024.11, downloaded from Phonostar.de) 1.31.56 (user 2025.05, downloaded from Phonostar.de) 1.31.58 failed
  16. downloaded compilation from Å koda portal is useless because Mib3 units have lost option of manual upload for particular stations try https://www.phonostar.de/download/vw/MQB3_OI_JND_Europe_v1.31.58.zip https://www.phonostar.de/download/vw/MQB3_LGe_Europe_v1.31.58.zip https://www.phonostar.de/download/vw/ICAS3_LGe_Europe_v1.31.58.zip and report result, on my 2023 Mk3.FL Å S it stopped work MQB3_OI_JND_Europe_v1.31.56 - OK MQB3_OI_JND_Europe_v1.31.58 - NOK :( -> https://www.briskoda.net/forums/topic/520105-radio-stations-logos-database-updates/page/7/#findComment-5950044
  17. interesting, got knocking sound with new Bilstein 12-281459 rear Top Strut Mounting, returned back to one year used OEM 5Q0 513 353 E -> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/page/3/#findComment-5854160
  18. @Ootohere 0w20 bottle in your picture is 508/509 280 sticker says 504/507 -> 0w30
  19. after i saw they put 5w30, to the next services i came with my own 0w30 Liqui Moly TOP TEC 4210 LL3 @Ootohere i can't see connection between 280 and IV
  20. -> https://www.briskoda.net/forums/topic/532458-columbus-map-update-2025-2026-mib2-high/
  21. VW's offline maps dowload server has been switched down several months ago :(
  22. @djukak link under picture in the head post
  23. 17" are ok on 280ps 4x4, i use for winter set on 17" can be also installed custom size of tire 225/55r17 in compare to OE 215/55r17 they give: +10 mm in with +5 mm in height and closer to real life speedometer values, due +1.5% in circumference
  24. @fila_superb find some download program which have resume option on linux parameter c helps with command wget
