nige8021
Everything posted by nige8021
  1. I would keep VCDS far better Needle sweep isn't a tick box option you need to re-write the eeprom data with VagTacho I tried it on my old L&K but it didn't work
  2. On a MK1 there are not that many modules fitted anyway and very limited amount of customisation you can do to those modules that are fitted
  3. Please don't just go replacing the sensors in the hope of a fix, far better to pay £30 to get the codes read at least you will know one way or the other and it'll say what sensor it is, then, If the fault code scan says it's an ABS sensor, they don't require any coding however you'll need to use the same diagnostic kit to clear all the fault messages, Please don't just go replacing the sensors in the hope
  4. You really need to get it connected to VCDS and do the basic settings, with the car correctly ballasted, you put the system into "level/adjust mode" and then adjust the beam settings. Those sensors and the general install look OEM
  5. All sounds very similar to my Touareg, and another guy's on the Treg forum, when scanned it showed an ABS sensor (rear left in my case) and I believe the same sensors are used on the Superb, So you need to get it properly scanned with a VAG based reader preferably VCDS and take it from there, FYI the sensors are around £90 from the stealerships I did find copies on eBay for as little as £10 but I hate think what quality they are ??
