Bexhillian
Everything posted by Bexhillian
  1. Time for wee Jimmy Crankie to close playgroups in Scotland?
  2. There is an option DRL Disable/Enable within MAXIDOT Settings (Manual page 65) if this is what you are after, but as logiclee queries, what is behind your initial enquiry?
  3. Triangle issue has been raised previously on 'the light side'. I and others have since painted inside the triangle indents with white paint. Easily draws attention (including to the fitter who replaced 4 tyres for me this week using a pair of trolley jacks rather than a full four-post lift.
  4. Had same earlier this year. On diagnostic plug-in, root cause was failed NSR ABS sensor. Caused cascade of other lights. Until replaced, sometimes 3 lights, sometimes 6, sometimes no lights. Advised that not unknown across certain VAG models. Since replacement (under extended warranty), no issues.
  5. No official new Amundsen2 units anywhere in UK or whole of Europe and unlikely in the future. (source: Skoda UK) I have been waiting for mine to be replaced under a warranty claim or a Kenwood? alternative to be offered. (perhaps it's an inside job as Skoda UK must be fed up with my and my dealership's constant chasing)
  6. Has anyone replaced their Amundsen 2 Infotainment system with another integrated system? Either by choice or by necessity. It was standard equipment on my 2016 L&K. Has anyone installed the Kenwood system that was offered as a Skoda Accessory per 2016 brochure and advertised subsequently in dealerships? Must have satnav (plus linking with maxi dot), dab/fm, music player, phone connectivity, compatible with parking sensors....so not a big ask!
  7. A sheet of newspaper or length of kitchen towel laid in the footwell and checked frequently might identify a drip/leak from above and, if no evidence, suggest that the water is coming in/up from behind the side/floor trims/carpet. Incidentally, when my original heated screen was replaced (stone damage) the fitter commented on how poorly he thought the original sealing had been carried out. Certainly not the 'robot perfect' that you see on videos. That said, it had never leaked.
  8. If 'back open a bit' is a trick, I have missed it since 2016. Mine opens fully and closes fully (and stays closed) and will stop partway when I take my finger off the button. I think you must have a really special edition! Under waranty - back to dealer?
  9. Might your first contact be with a Skoda dealer in Romania or with Skoda Romania www.skoda.ro ? Your 2013 left hand drive Yeti might have 'Mainland Europe' characteristics which were not transferred to UK models. The dealer would be likely to offer more accurate advice than us UK Yeti owners. You might also look through the offerings on www.superskoda.com, although beware of the effect it might have on your wallet !! Anyway - good luck !
  10. French motorway lane discipline is some of the best in Europe (evidence: many European miles annually except 2020 unfortunately). You will be tailgated if you stay in an outside lane unnecessarily but no different to here. OK, parking in some cities is sometimes 'shunt and squeeze in' but no different to here. And yes, the Aires are delightful.
  11. Continuous for me but hopefully only temporary indigestion for your system and it is now (somehow, best known to itself) back to normal.
  12. I have had this (Amundsen 2 Infotainment System). Vehicle purchased new in April 2016 with extended 5 year warranty. Zooming in and out on satnav screen, screen unresponsive, PLUS (on SD Card) bouncing between tracks and albums and the DAB radio bouncing between preset stations. Two visits to supplying main dealer. After first 4 hours investigation (17 September) first checks showed a failed ability to focus on the identified available satellites. Following diagnosis via a TIS (technical information sheet) from Skoda UK to the dealership, it was concluded to be a faulty signal focusser/translator(?) aerial at the rear of the unit. Subsequently (1 October) this was replaced but after a couple of hours, the dealership concluded that this had not resolved the problems. Dealership agreed a complete replacement Amundsen2 unit to be supplied and fitted under warranty (placed on backorder 7 October) and appointment booked for 22 October.
