Everything posted by 2stroke
Rear half of the car without electricity/communication... ?
VCDS fault code reading: 2013 Skoda Octavia SCOUT 2.0 TDI .pdf
No it is not.
( 2013 ) Skoda Octavia 2.0 TDI SCOUT with 6-speed manual transmission. My friend's car suddenly had a major electrical fault. Suddenly—and without any prior issues—there is no power to the entire rear section of the car, along with a few other likely related faults. No tail lights. No brake lights. No turn signals. No reverse lights. No license plate light. The tailgate lock solenoid remains in the closed position. The engine doesn't stop when the key is turned to the OFF position, instead it keeps running perfectly. If the key is removed from the OFF position, the entire dashboard starts flashing frantically yet the engine keeps running—though now very, very poorly and unevenly.. I’ve attached a VCDS fault code scan I performed. ...Can anyone draw any conclusions from it ? 🤔 Has anyone experienced a similar electrical fault on an Octavia-II ? 🤔 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - EDIT 🤔 For some reason unknown to me, I cannot upload the VCDS fault code reading 🤔
Exhaust drone ( 2950~3350 Rpm ) during highway use... ?
Have been on a 15000 Km ( 9400 Miles ) summer trip with the car. Have discovered a very annoying and clear exhaust drone in a narrow rev range ( 2950~3350 Rpm. ) The car has a 100% stock Skoda OEM exhaust system. 🤔 Anyone else here at Briskoda who has or had similar exhaust drone on their Octavia-II FL 1.8 TSI / 2.0 TSI equipped car ? 🤔 .
Rns 510 Columbus 5238 firmware
🤔 What is European Josi Modified 5238 version ? 🤔
Coolant pump belt change
edited
⚠️ That bolt is LEFT-hand threaded ! ⚠️ You can't break anything internally. You must hold/lock the pump gear when attempting to loosen the screw by turning it clockwise. .
Engine oil
Make sure you always use motor oil that is fully synthetic ! 502.00 → is for PETROL engines, with a maximum service interval of 15000 Km between filter and oil changes ! 504.00 → is for PETROL engines, with a maximum service interval of 30000 Km between filter and oil changes ! - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 505.00 → is for DIESEL engines ! ( does not apply to your car ) .
Fabia-III 1.2 TSI , Buying advice... ?
Inside the fuel tank before the fuel pump you have a 'mesh screen' filter which has 30 micron filtration rate. Outside the fuel tank after the fuel pump you have combined inline fuel filter and fuel pressure regulator which has 10 Micron filtration rate. ( It is this Outside fuel filter that is regularly changed in accordance to the VAG-service plan. ) VAG-part # 1K0 201 051 K
Yes, the spark plugs have been changed as well as the brake fluid and fuel filter and cabin filter. All according to the regular service plan at fixed mileage.
Apparently the service book seems to contain much more here in Sweden that must be carried out for warranties etc. to apply compared to the UK. Wagon / Estate / Combi / Kombi → Different names in different parts of the world meaning the same thing. Engine code is: CJZD
I have owned lots of different VAG cars since the 70's and one thing that has definitely gotten worse in quality on the cars that are produced today is the paint and the rust protection. It is really, really bad! Both the paint and rust protection of the sheet metal were at their best in the mid-80s and early 90s, since then it has only gotten worse. On the other hand, the electrical systems have been getting better all the time. There are several different VAG cars that suffer from the same disease that water leaks through the door panels onto the floor of the cars, which leads to a lot of trouble getting it dry and sealing the door panels. This is because the doors have exactly the same construction regardless of whether it is a VW Lupo or an Audi A8
What engine do you have ? Thank you for sharing your experiences with Fabia-3.
Good to know.
I always change the Oil and Filter with a maximum interval of 15000 Km / 9300 Miles on all cars in the family. Where I live it can get extremely cold and I therefore always use 100% fully synthetic oil with 0w-40 viscosity. I always use MAHLE or PURFLUX filters.
I will never buy an Asian car. ( it's a matter of principle ) Yes, I will change all the fluids in the car if it is purchased. Car has a 6-speed manual gearbox. Nice to know your experiences with Fabia-3, thanks.
All service has been done according to the VAG-workshops' service plan at the local SKODA-workshop. The car has only had one owner since new and has never been in a crash. The car runs well and sounds mechanically fine. I would like to get more information about typical faults on this particular generation of Skoda Fabia Both bodywork and mechanical. ( Fabia-3 , 2015-2020 , Platform: PQ26 , Type: NJ )
Background... One of my daughters owns a (2007) Skoda Fabia-1 Wagon since many years and it has worked without the slightest problem. Mechanically the car works perfectly and she is extremely happy and satisfied with it. Now it is time to replace it because the rust disease has hit too hard. I thought then that a Fabia-3 Wagon should be bought instead. We have 10 different VAG-cars in the family right now, but I have no experience with the Fabia-3 generation nor with the 1.2 TSI engine.
🤔 I would need some buying advice ! Skoda Fabia-III Wagon 1.2 TSI ( 110 Hp. ) with 6-speed manual transmission. Model year: 2016 VIN # TMBJN6NJ8GZ184197 Mileage: 131 000 Km. / 81400 Miles. What would be good to know about the 1.2 TSI engine ? 🤔 Anything special to check before buying a Fabia-III ? 🤔
( 2009-2013 ) Octavia-II 'FL' 1,8 TSI & 2,0 TSI - Waterpump
😵 Really stupid question, but.... Where is the water pump mounted on these engines ? Can someone describe and preferably with pictures ?
Octavia Mk2 Workshop Manual free download
Lower front wishbone... ?
As English is not my native language, it is a bit difficult to understand abbreviations. ( It's been more than 30 years since I sat in a school desk and tried to learn English. ) I don't know what NVH means !?!? 🤔
If you think about the propagation of sound/noise, the cast aluminum wishbone should be the best at arbsorbing sound/noise so that it does not propagate into the passenger compartment as disturbing noise. ...But this still does not feel like the primary reason why 3 identical lower front wishbone arms are available in 3 different materials 🤔 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - PQ35 platform cars: Audi A3 Mk2 (8P) Audi TT Mk2 (8J) Audi Q3 Mk1 (8U) SEAT León Mk2 (1P) SEAT Toledo Mk3 (5P) SEAT Altea (5P) Škoda Octavia Mk2 (1Z) Škoda Yeti (5L) Volkswagen Touran (1T) Volkswagen Caddy Mk3 (2K) Volkswagen Golf Mk5 (1K) Volkswagen Golf Mk6 (5K) Volkswagen Jetta Mk5 (1K) Volkswagen Scirocco Mk3 (1K8) Volkswagen Jetta Mk6 (1K) Volkswagen Beetle A5 (16) Volkswagen Eos (1F)
Rebuilt my 1.8 TSI, after 14y and 200k km.
Do you have any info about the chain tensioner recall ? What parts and what brand did you use to replace the piston rings, chain and associated parts ?
Why are there 3 identical lower front wishbone arms but made of 3 different materials for all PQ35 cars ( eg Skoda Octavia-II ) ? 🤔 ( Of course they have different VW/Skoda part # ) There must be some underlying thought/reason here !?!? 🤔 * Pressed sheet metal. * Cast steel. * Cast aluminium.
