imart143
Everything posted by imart143
  1. greeting. I have a Karoq 1.5 tsi 2019 with 85,000 km and today I cleaned the carbon buildup on the intake. I cleaned 3 intakes and the fourth remained. I was thinking of turning the crankshaft pulley to close that valve, but I didn't have that key. maybe it's a 23 mm 12 angle wrench or something special. alternatively, I wanted to turn the engine a little by putting the manual transmission in 4th gear, but turning the wheel that was on my jack and the support, the engine did not turn. as if it is in reverse, with a little more resistance, as if the clutch is slipping. I tried all speeds and the same thing, the clutch works when pressed. but I didn't touch anything with the clutch, it works normally, yesterday I came home from work and this morning I lifted one wheel in the air and put a support so that I can remove the engine protection from below. before that I unlocked the car, pulled the manual (electric) and disconnected the battery. maybe it doesn't work if the battery is not connected or similar?
  2. I cannot influence how many greenhouse gases there will be in 30 years and what the consequences will be. there is not only Co2, but also Methane, etc. I have already written several posts about toxic gases coming out of, for example, Euro 5 or 6 cars with disabled exhaust cleaning systems, how cars with an "operated" exhaust system directly endanger the health of people in their immediate vicinity. everyone in this part of the world has the right to clean air and water, this distinguishes us from the inhabitants of Africa and similar countries where there are no standards for air cleanliness. no new egr, dpf or src is worth a person's health. ask yourself: would you have the same attitude if you fell ill with some disease of the respiratory system due to the fact that people disabled the exhaust cleaning systems in order to avoid adequate maintenance and repairs, but instead disabled the broken components to return the car to Euro 4 with its exhaust.
  3. I did not dispute the chemical significance, but the removal of ecological systems from cars does not endanger the health of some people on the other side of the planet. nitrogen oxides and soot particles affect the immediate environment, in contrast to CO2 emissions that are dispersed in the atmosphere and have no local impact.
  4. Not for driver but all those people around him. Yeah cars without without egrs were on streets 1970-1980. We are in 2025. almost. Nowadays gasoline cars have catalisators, egrs, diesels have few more. That is life. All antipoisoning systems (EGR, DPF, SRC, GPF, etc) are mounted on cars because other people, walking or cycling around drivers to minimize inhaling poisons from exhaust. You are probably one of people that doesnt care about other people. I had egr on my tsi i i will clean its depozits but not remove system. I think about people around me, pedestrians, older, children. Behind my vehicle nobody needs to breath poison. Aldough i understand you. You are thinking about yourself, and all yourself, nobody else, no neighbours, nobody, just you and your car. You driving gasoline car, ok, but how can you tell orher driving diesels: blank it of, erase. It doesnt matter.
  5. if you know the purpose of EGR system, you will define it by yourself. EGR systems are meant to be cleaned and maintained, not removed and disabled.
  6. she want thank you but children playing nearby deserve cleaner air than yours exhaust. will you do the same to your children too? probably.. clean that intake completely, new egr valve and drive honestly.
  7. you have 12v/21W daylight? if it is legal in your country (in mine is not) https://www.powerbulbs.com/product/philips-x-tremeultinon-led-gen2-p21w-6000k-twin
  8. Use Philips or Osram. Not some chinese crap from aliexpress.
  9. I buyed 2 pairs. Originally bulbs are Philips WhiteVision Ultra W5W T10 12V/5W. I paid 2 bulbs 6€ https://hr.intercars.com/proizvod/g0pkh8-zarulja-w5w-pomocna-whitevision-ultra-blister-2-kom-12v-5w-tip-gedore-w2-1x9-5d-phi-12961wvub2
  10. Hi. I have TKN gearbox on my Karoq 1.5 tsi 2019, and I want to change the oil in the manual 6sp transmission. the gearbox has two holes for draining / adding oil, I already have oil. 75w G052. the plugs have an Allen key of 17. I read and looked that it fits 2.1 liters of oil, but people change it and it fits far less. there is a trick to block the gearbox with a feeler near the gear selector and to drain more oil on one of the smaller holes. Does anyone have experience to tell me if this is okay? And to unscrew the reverse sensor and pour oil through it, because it starts leaking through the filler cap already at 1.7 liters. Look
  11. Taking off inlet mainfold, and mechanical scraping and dissolvent.. i prepared most of things 😆
  12. However i can tell i have not any type of lag.. DPCA all original. 83000 kms. After cleaning intake ports which are full of carbon, i am second owner, i will remap it to 175 hp and 300 Nm. Look
  13. DPCA is 1.5 tsi evo. Also have variable turbo. I have that. Also is is called hibrid turbo. I dont know meaning of that.
  14. charger cooler have to be cleaned, but its temporarly fix. only solution is new chargercooler and secondary egr off..
  15. Can oil catch can be mounted od doca engine? And vhere to connect? On this hose on valve cover and another hose where?
  16. VAG didnt know kow it will work either. Owners are test drivers, last 10 yrs.
  17. Where to download that manual? I didnt get it with car. Thanks.
  18. Yeah sometimes it fails but i was seen engines with 250000 kms without belt or timing tensioners failure. VAG was sure that stretching belt over time maybe 1-3% will impact to ACT system. Because timing for this belt is specific, tolerance between shaft is about 2%? But there is obviously not impact. Not serious. So they agreed to prolongue timing change interval to lifetime, same like on tdi, so you drive it till something else fails and you need to get belt off, camshaft or crankshaft seals, or have issues with ACT system, otherwise no action needed..
  19. That what you see 50 miles 5 yrs cars for sale it is because companies have 5 yrs leasing deal and they return car to leasing group. That way i bought mine, but not for that little mone, but as it have price on market + taxes in my country: Above 20000€ https://www.autoscout24.com/lst/skoda/karoq/bc_grey?atype=C&cy=D%2CA%2CB%2CE%2CF%2CI%2CL%2CNL&damaged_listing=exclude&desc=0&eq=53&fregfrom=2019&fregto=2020&fuel=B&gear=M&powerfrom=103&powertype=hp&search_id=4eblosxp8u&sort=standard&source=detailsearch&ustate=A%2CN%2CU
  20. What is different between toothed belt on diesel engine and petrol one? My brother is car mechanic. All brands had that long interval. We didnt see broken belt or blocked tensioner 20 yrs or more. Only water pump which is on side of distribution, driven ba crankshaft and same toothed belt had failed earlier. It is often on many cars. Rarely on Japan cars, or korean. Betwee diesel and gasoline car? No difference, same stuff. Made of same composite material. Same measurement. In past belts were thinnier. Now are much stronger. Think Conti for 1.5 tsi act is even reinforced. And is double in dimendions, stronger than belts were in 1990 and 2000- yrs. My fiat punto gasoline car had belt dimensions like 1.5 tsi belt for water pump. Stress and working condition on diesel are more intence. 15 yrs ago for tdi was interval 5 yrs or 100000 kms but last 10 years is 10 yrs and 210000 kms. VAG had no make gasoline car engine since 20 yrs and it were N/A. Logically, timing belt from same company, same engine maker can be made with same technique, same quality, maybe even more. Conclusion that no belt change on 50000 kms had to be done, not even 5 yrs. In beginning it has to be same as on tdi, double. At least 150000 kms or 8 yrs old. ..
