Stewartasb
Everything posted by Stewartasb
  1. All sorted thanks tmb you were right about that bowden cable cheers
  2. Ok so there is an issue the window etc works fine but now I cannot open the drivers door from the inside or the outside if i use my key it still locks everything and unlocks it but when i try the inner and outer door handle the door wont open any ideas please as I cannot now use drivers door lol ???
  3. Is there anywhere uk i can order from they want 17 euro,s just to deliver them lol.
  4. Just toi hijack thius post sorry does anyone know where I could get a replacement set of these 2 door lock bolts from I just noticed on my passenger side someone has attempted to get mine off in the past and stripped them now I need to get these off at some point as I need to replace the micro switch on this side.
  5. Sorry mate I missed that im going to try that then as it can't be pump thats pretty much ruled out now so guess strip the wheel off time and check out the stslk thanks tmb 👍
  6. could this ongoing issue be related to the wiper stalk in any way ???
  7. Brought complete new panel and issue all fixed now thanks for all the advice guys
  8. nice one cheers mate for that I was concerned about the riveting thing worst part is ive got to order the regulator so somehow need to get the window up or the local smack heads will strip my car bare by the morning lol.
  9. Hi was just out this morning driving suddenly my front drivers window went all the way down by itself even past the stop mark and heard it drop now wont go back up just hear a scrunching noise I take it this is the window regulator screwed maybe and if so any advice on fixing this issue please ???
  10. Lol he means he changed the drivers switch ad fid I and the replacements they now send out are red not green im after a passenger window switch in red to match it looks better than the original green.
  11. well put another new pump in just in case the other new one had a fault and still getting the same issue will squirt out front but once ive squirted out back they will only squirt out back until I restart car ???
  12. Jack the back of car up whilst adjusting via the nut until you have about 4 clicks and check rear wheels by hand to ensure they are not binding when you release handbrake off.
  13. tech1e is correct as I had exactly same issues as you so I changed the thermostat and housing and also the temp sensor this resolved the issue im pretty sure its your temp sensor if the thermostat has been changed and possibly they may have air locked your system when changing the thermostat as air in the system will cause the issues your describing.
  14. Hi thanks for the ideas I have a spare battery so will give that a try as it is looking like a pump issue as you say guess there must a fault at it even though it was brand new when I fitted it. Thanks for the help 👍
  15. The original pump was leaking so I was loosing all my fluid but worked fine jet wise.
  16. Ok so I just popped to the shops gave them a squirt and working correctly came out shop driving home tried them again and squirt out back 🙄
  17. do you think maybe there might be a blockage at some point and its forcing the water to go down the rear jet pipe ???
  18. Yes they were fine upto 2 days ago weird or what.
  19. Ok so got a strange one all of a sudden when I squirt my front washer jets it makes it come out the back window jet and when i squirt the rear one it still comes out the rear jet now I changed the pump on these about 6 months ago so its plumbed in the correct way any ideas ???
  20. yep you were right mine is 1N2
  21. Ahhhh right I will get my book out and make sure first thanks for your help mate 👍
  22. That tallies up with a set I've just found thanks again TMB you've put my mind at rest there I think the other company I asked at were guessing tbh left me not trusting to order but youve sorted it now cheers bud 👍
  23. Hmmm I'm a bit concerned as I'm being told that this is a different wheel bearing compared to mine but I cant even see the difference and thanks for clarification on the roof trims 👌
