What Tork or Spline Size to remove Door Lock Mechanism
Hi,
The passenger side window has failed in the down position on my 2005 Fabia. I have found lots of info on here about replacing the regulator but cant find what bit I need to undo the two main screws that secure the locking mechanism to the door.
I have a T45 Torx but it seems a little loose and I don't want to risk stripping the head if its the wrong size.
Can anyone let me know what I need - Torx or SPline and size?
Jon
If you mean the ones in the door edge that secure the lock unit they are 8mm XZN spline. Using a Torx bit would damage them.
Edited by TMB
An Allen key will work at a push...
Good luck with that.
Animal. Use the correct tools.
Try it and see!!
I even used a big flat blade to remove the one that holds the door mirror in place.
You can buy the spline set from machine mart cheap enough. I have one now as I needed it for the driveshaft bolts on my old mk2 golf.
Great, I'll get the M8, don't want to risk stripping the thead.
Thanks for all replies.
Jon
  • Sponsor
Got a feeling it might be smaller, possibly M6, compare with the one that holds the door check strap on, that's an M8.
Door check strap bolt and the lock bolts are both M8. I tried an M8 bit in them before I posted the info just to be sure.
Edited by TMB
  • Sponsor
Apologies folks; Lee I read your post minus my reading glasses and didn't spot the '8mm'.
Had it in my head that it was a smaller bit.
No probs Pete :)
  • 2 years later...
Just toi hijack thius post sorry does anyone know where I could get a replacement set of these 2 door lock bolts from I just noticed on my passenger side someone has attempted to get mine off in the past and stripped them now I need to get these off at some point as I need to replace the micro switch on this side.
https://www.skoda-parts.com/spare-part/n90846501-screw-with-mushroom-head-skoda-14494.html
Thanks TMB you saved my bacon again :)
Is there anywhere uk i can order from they want 17 euro,s just to deliver them lol.
How about a scrap yard
they all off limits by me at the moment :(
Yeah, I realised after I posted the link that the postage was a bit of a killer.
How about contacting this guy? He deals with briskoda....
Edited by TMB
