Everything posted by Robbo12
2025 Map update
- 2025 Map update
I've had the same continued problems and the zipped folder is only 15GB so something is missing.. Think Skoda portal need to sort things out..- 2025 Map update
Many thanks for that i had exactly the same problems as you have described Zip download only 15 GB .. Don't think I will be wasting any more money on the map updates.- 2025 Map update
Thanks all but if you go on the Skoda update portal site you will find the zipped download to be 15gb which is normally about 26gb in previous years. Thank you all for the comments this forum has certainly helped me with several things. https://updateportal.skoda-auto.com/en-GB/Updates- 2025 Map update
Hi think you could be absolutely right I've just been on the Skoda update portal and seen the same only 15gb download when its normally about 26gb, why would they put the download there if it doesn't work. now thinking of getting a TOM TOM.- 2025 Map update
I have been trying to get the 2025 map update for my Skoda, from the Skoda update portal. Have managed to download the zipped file but when extracting it to an SD Card it only reaches 10% then get error and unable to complete wondering if anyone else is have the same problems, for the Columbus infotainment system.- Battery Change Superb mk3
Many thanks, it's just that I have read so much about these memory savers I did want to give myself any problems, never had to use them on my previous cars. thanks again I won't use one and will just register the new battery once I've changed it.- Battery Change Superb mk3
Many thanks for that very well explained.- Battery Change Superb mk3
Thanks all that's a great help, gone are the days when you could just disconnect it and replace.. now coding battery to car needs to be done. won't bother with the memory saver now.. Thanks all- Battery Change Superb mk3
I have moved it to the Superb mk3 section.. Thanks- Battery Change Superb mk3
Looking at changing my battery and realize that i need to use a memory saver is it ok to plug into the OBD port and put 12v to it ? or would it be safer to connect to the positive & Negative cables under the bonnet ? If anyone has done this any advise would be appreciated. I do know a new battery has to be coded to the car and can do this with my Vaws 3.0 reader.- Battery Change Superb mk3
Thanks if this could be moved posted in the wrong section.- Battery Change Superb mk3
It supplies current to the car while you disconnect the battery saves you loosing settings in the cars computer such as radio settings.. you can view them on Amazon. Just not sure if its safe to supply 12volts into the OBD Port- Battery Change Superb mk3
Looking at changing my battery and realize that i need to use a memory saver is it ok to plug into the OBD port and put 12v to it ? or would it be safer to connect to the positive & Negative cables under the bonnet ? If anyone has done this any advise would be appreciated. I do know a new battery has to be coded to the car and can do this with my Vaws 3.0 reader.- Superb MK3 Rear Brakes
That's good advice thanks, think a lot on here have been getting confused with the EPB and the piston, I have the superb MK3 L&K 2018 and i was unsure if the piston on the rear brakes were to be pushed or screwed in because looking at the piston face with the two cut out bits i was thinking screwed in, but you have made it clear to be pushed in. Thanks for the advice.- Rear caliper torque settings
Thats handy to know nicknorman , Plan on doing my back pads and recently got the Vaws 3.0 to release the parking brake anyone else use the Vaws 3.0- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
Many Thanks, Downloaded and all worked fine this time. Merry Christmas to all on this Forum.- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
Still no Skoda map update for 2024 on the Skoda web portal, the one they did have has been taken off.- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
downloaded on PC- windows 11 ... and had done a full format of SD Card, all unpacked to the card but once putting in the car it only done the update to 82%. then got error message and reverted back to to 23/24 map- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
oh well, Downloaded the update ok, and un-packed it to a 64gb sd Card.. Then put it into the car to update found the card ok and got to 82% then failed with an error 🙁 I've never had any problems like this before.- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
Many thanks all, everything working well now.- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
Hope Skoda get this new map update sorted otherwise its not worth the time and effort downloading something that don't work.- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
I'm having exactly the same problems getting error messages when un -zipping. I never had any problems before.- Map Update Errors Unzipping New updated CW 45/2023 HIGH12_P350_EU_202345
- Wind back tool for front brakes
Just a quick update I have managed to change my front Disc's and pads with no issues, thanks for all the advice you all gave me. Would be nice to change back pads but it will probably be issues releasing the electric brake. - 2025 Map update
