Everything posted by nickalto
Retrofit footwell leds
Reverse camera retrofit Skoda Fabia IV
Ok solution find! equipment automatic transmition-not installed EPB-not installed AHK-not installed ARA-not installed
Well for my car the difference was in : Leuchte31AMBL 1C65-Type_of_Load_31 I checked the option LED_Kleinleistung_ohne_OL_mitUeberspg_absch and the lights are working without any error message.
Ok no further need for help! I d like to thank you for your help!!I managed to code everything right and now footwell lights work great!
Which diagnostic you use?i have OBD eleven and i am thinking to buy ODIS
Hi I did all these steps of OBD11 coding to a skoda fabia 4 2023 model! It worked to a point but I keep receiving an error message for internal lighting. Did you have the same problem?thanks
Hi I have installed an oem reverse camera low line to a skoda fabia IV 1.0 TSI Ambition and i would like some help in coding.I have image but the guidelines are missing. Does anyone have any information which could help? Thanks
Navigation Activation
Pretty much the same! I did a research and I saw that the unit I have in my car support navigation but the screen installed does not show that option !
Hello I would like to ask if it is possible to install and activate navigation to a Skoda Karoq Ambition 2019 model with MIB STD2 +NAVI 5Q0035840C TECHNISTAR unit. I bought the car without that option. Thanks
Skoda Fabia Mk4 (2022-2023) Workshop Manuals
Ok thanks !
Does anyone have the Skoda Fabia Mk4 (2022-2023) Workshop Manuals to download?
Front passenger door module upgrade
Update!problem solved by adding a pin in position n1 in door module! Works perfectly!
For retrofitting exterior mirror's area light. The pin is missing on 5Q4959392F.
Upgrade from 5Q4959392F to 5Q4959592F
Hello Could anyone tell me if it is possible to upgrade the front passenger door module and what should I look?thanks in advance
Technical help
Hello I have a skoda fabia mk4 ambition edition hatchback 95hp and i d like to ask if anyone can help me providing the pin diagram of on-board electronic module!!I want to retrofit footwell lights and I must connect the power supply pin on J519 in order to make it work! The earth connection is already done. Thanks in advance
Retrofitting Rear + Front OPS parking sensors
Hi i have same problem and i d like to ask which pins did you connect in 17b connector?thanks
Help needed
My thought was if it is possible to retrofit electric heated mirrors in my car with all hardware and software needed.And if anyone has already done it and can give me all the information I need. I read some articles saying it is very difficult and I gave an alternative thought in order to avoid all this complexity if it is possible to have heated mirrors by wiring them to the RHW cables.
Help needed
I first thought that this edition ,active, maybe comes with manualy controlled mirrors and heat function which is activated with HRW.I tried with no results!No luck!So probably it will need new wiring.My thought was if it is less complicated to wire the heating function with the HRW. I don't know if it is difficult nearly impossible to retrofit electric positioning mirrors with heat function that s why I am asking any help - diagrams ,wires ,connections. I have some experience with retrofitting infotainment system in my car which works perfectly even with hands free function. But retrofitting electric heated mirrors should be possible somehow.
Help needed
Has anyone wired the rear window defrosting function with the heat function of door mirrors?I have a skoda citigo 2017 5door 1.0 petrol Active edition and the door mirrors doesn't have any heat function.They are manually controlled with no heat.Is it possible to wire them to rear window defrosting function?
Citigo radio pin outs 2017 onwards
Hello i followed your instructions and everything worked perfect!!all functions are activated and working without any issue!! the only problem we saw on my local vw dealer is that on diagnostics there are some bytes or codes which is not programed because my BCM unit was factory programed for a poor model version which didnt include an infotainment system.So i would like to ask if you have update already the BCM unit in your car and which codes or what coding did you do?i have obdeleven and vcds if i need to recode but i dont know anything about codes!!! thanks
hello again and thanks for the reply i did remove all plastic panels the only job that seems difficult is to remove the whole fuse box to have a better access but i think i will get it done without any problems!!!for the new cables i have to install i saw in the pictures a 0.35 diameter and some special metalic ends in order to put it inside the connector. Anyway i will come back with some photos of my work!! thanks again and if you have more useful tips to give me please do!!
Hello again after a good look to my car i realised that i dont have any connection between 20 21 pins of J533 and radio CAN H/L and also obd2 socket pins 8/9.So i must to put them myself but the problem is how to release fuse box obd2 socket and J533 support in order to have access to J533 connectors.I tried and i stopped cause i couldnt release obd2 socket.Any suggestions of experience?
thank you a lot!!!i will try it and see my results!!thanks again for your great help
