Everything posted by sealover1
Scan Results Help please
Apologies not been in touch guys I had more ill-health and been in and out of hospital, due to go back into hospital Thursday 20th may, Deep Joy. my car problems all of a sudden stopped and so I got a new MOT and carried on driving but I think I knew it would not be for to long, glow plugs light and Traction control light came back on again, but think some other faults are there as well, think 1 is the Rain and Light Recognition Sensor of which I had no idea it had one. done a scan and these came up so as like I did last time I deleted them all and put the battery back on charge, a lot of it is due to I dont drive much and the car could be parked up for a while are I only drive it for a mile or so, what with covid and everything I have had nowhere to go apart from the hospital appointments. got two more this week I hope the car makes it. could you take a look please see what you think? says all the glow plugs are faulty just seems strange they would all go at once maybe I should just change them there not that expensive are they? . Monday,17,May,2021,14:56:07:35642 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4 Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: TMBKE21Z788009343 License Plate: NX57GHB Mileage: 312250km-194023mi Repair Order: 1 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76 VIN: TMBKE21Z788009343 Mileage: 312250km-194023miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 SS HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 1302 Revision: --H07--- Serial number: SKZ7Z0G4311023 Coding: 0000172 Shop #: WSC 66565 257 00032 VCID: 025C73D48807A2BB997-8056 5 Faults Found: 005658 - Glowplug for Cylinder 1 (Q10) P161A - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 005659 - Glowplug for Cylinder 2 (Q11) P161B - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 005660 - Glowplug for Cylinder 3 (Q12) P161C - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 005661 - Glowplug for Cylinder 4 (Q13) P161D - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 000801 - Engine Speed Sensor (G28) P0321 - 000 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 312251 km Time Indication: 0 Date: 2000.00.00 Time: 02:08:39 Freeze Frame: RPM: 1764 /min Speed: 41.0 km/h Load: 26.3 % Voltage: 14.52 V Bin. Bits: 00101000 Idle Stabilization: 0.0°KW RPM: 882 /min Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD Component: ESP 4MOTION MK60-AT 0102 Revision: 00H14001 Coding: 0023170 Shop #: WSC 73430 790 00000 VCID: 698E4478957151E338D-803C 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 45D6A8C8D9A95583FC5-8010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005018991 Coding: E18A0F130004100000110D000000000000087F065C000000000000000000 Shop #: WSC 07894 067 57207 VCID: 71BE2C18BDA1A92370D-8024 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 060607 022 0601 Coding: 00055223 Shop #: WSC 07894 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 250607 046 0204 Coding: 00471077 Shop #: WSC 07894 1 Fault Found: 01520 - Rain and Light Recognition Sensor (G397) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 215 Mileage: 311954 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: OFF Voltage: 12.70 V OFF ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1A3RTX Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 Subsystem 1 - Serial number: 6332MSME184A620EG Subsystem 2 - Serial number: 6342MSME1C044D46G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 015E7CD88D01B9A380D-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Coding: 0007402 Shop #: WSC 11111 067 57207 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 160607F2000472 Coding: E9837F0E0002022303 Shop #: WSC 73430 790 00000 VCID: 3038E91C762BE02B3F3-8064 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 L Component: Haldex 4Motion 0116 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 3634DF04944FCE1B65F-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Shop #: WSC 00000 000 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3828D13C9E5B386B773-806C 1 Fault Found: 00943 - Heated Exterior Mirror; Driver Side (Z4) 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3430E50C8233DC0B5BB-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 81801A085283007F3F02050FC0085F96907C00 Shop #: WSC 73430 790 00000 VCID: 035276D0971DABB3921-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 4801 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Component: Sounder No Answer Subsystem 7 - Component: NGS n.mounted 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 32 Reset counter: 181 Mileage: 311813 km Time Indication: 0 Date: 2000.00.00 Time: 00:00:10 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 392ED438A551216388D-806C 2 Faults Found: 00121 - Outside Warning Light/Door exit Light Passenger Side 012 - Electrical Fault in Circuit 00944 - Heated Exterior Mirror; Passenger Side (Z5) 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000008 Shop #: WSC 73430 790 00000 VCID: 74B0250CC2B39C0B9BB-8020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0040 Revision: 00019000 Serial number: SKZ7Z3G0019189 Coding: 0000402 Shop #: WSC 73430 790 00000 VCID: 2E04F7646C1FF6DB2DF-807A No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 372AD200934537137E9-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 No fault code found. End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.4V)----------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- VCDS Release 21.3.0: SRI Reset Control Module Part Number: 1Z0 920 942 D Labels: 1K0-920-xxx-17.lbl Component:KOMBIINSTRUMENT VD1 1612, Coding:0007402 Operation: Please select an operation ************************************************************************************************************************ Channel Description Unit Current val. New val. 02 Service Reminder Status 1 --- 40 Distance since Service miles x100 14 --- 41 Time since Service Days 355 --- 42 Minimum Distance to Service --- --- --- 43 Maximum Distance to Service --- --- --- 44 Maximum Time to Service --- --- --- 45 Oil Quality 1 --- 47 Soot Quantity km x100 64 --- 48 Thermal Load km x100 22 --- 49 Minimum Time to Service --- --- --- 50 Basic Distance Value for Oil Change miles x100 93 --- 51 Basic Time Value for Oil Change Days 372 --- ************************************************************************************************************************ -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- VCDS Release 21.3.0: SRI Reset Control Module Part Number: 1Z0 920 942 D Labels: 1K0-920-xxx-17.lbl Component:KOMBIINSTRUMENT VD1 1612, Coding:0007402 Operation: General Service Reset ************************************************************************************************************************ Channel Description Unit Current val. New val. 02 Service Reminder Status 1 0 40 Distance since Service miles x100 14 --- 41 Time since Service Days 355 --- 42 Minimum Distance to Service --- --- --- 43 Maximum Distance to Service --- --- --- 44 Maximum Time to Service --- --- --- 45 Oil Quality 1 --- 47 Soot Quantity km x100 64 --- 48 Thermal Load km x100 22 --- 49 Minimum Time to Service --- --- --- 50 Basic Distance Value for Oil Change miles x100 93 --- 51 Basic Time Value for Oil Change Days 372 --- ************************************************************************************************************************ -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 17,1Z0 920 942 D,channel 2,adapted from,1,to,00000,
been looking it all up and found these photos and the vid on how to change the haldex oil and filter, nothing in the service book to say if it has been done or not, I could maybe let a few drops out and see how clean or dark it is? No Ideal what Gen my Haldex would be also take a look at this for corrosion https://www.audi-sport.net/xf/threads/haldex-not-working-no-communication-etc-look-inside.142194/ .
. I will have to check the service history, it had a full service history when I bought it and I dont do a lot of miles and had it nearly 2 years
thanks mate, yea I know there is a module below the battery tray somewhere, I will get to it soon as I'm feeling with it a bit more, haldex? never heard of that before, it sure is a learning curve owning a skoda Octavia but its nice when you get it right and fix something yourself, if I had to pay a garage for every job I dont think I'd be able to have a car or my bike
Hi guys thanks for the Info sorry for the late replay I have some disabilities and been pretty much bed ridden for a while but up and kicking again. when I cleaned all the fuses and relays as in my last thread I never cleared all the faults so maybe start there? Langers2k do you know where the AWD module or the ABS module is and fuse number? I will go clean all of it as it does seem to help, I think my car has lots of bad connections cuz as I clean them things do seem to work better apologies I have fibromyalgia and brain fog can be a pain at times
true but in a bit the traction control light will show up as well it was coming on before it cut out then all of a sudden after not doing anything and leaving it the car broke down with the same fault numbers 0010 i,m just worried about it breaking down again 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 22-AWD -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010
cheers MicMac do you know where the relay for them are maybe a good spray of contact cleaner might help
Hi guys kept getting traction control light coming on but it did not today infect I had no warning lights on but thought I would do a scan anyways and come up with some faults, had a lot of faults come up to do with the comfort module l got some contact cleaners and cleaned all the fuses relays and all the warning lights went out and it then started up fine again. anyways still seem to have faults even though no warning lights on the dash. scan below if anyone can help please, car is running great at the moment so dont understand the faults Monday,05,April,2021,15:45:33:35642 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4 Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: TMBKE21Z788009343 License Plate: Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76 VIN: TMBKE21Z788009343 Mileage: 311870km-193787miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 SS HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 1302 Revision: --H07--- Serial number: SKZ7Z0G4311023 Coding: 0000172 Shop #: WSC 66565 257 00032 VCID: 025C73D48807A2BB997-8056 4 Faults Found: 005658 - Glowplug for Cylinder 1 (Q10) P161A - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 005659 - Glowplug for Cylinder 2 (Q11) P161B - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 005660 - Glowplug for Cylinder 3 (Q12) P161C - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 005661 - Glowplug for Cylinder 4 (Q13) P161D - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311829 km Time Indication: 0 Date: 2000.00.00 Time: 01:11:10 Freeze Frame: RPM: 819 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.52 V Bin. Bits: 00101100 Temperature: 5.4°C Bin. Bits: 10110000 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD Component: ESP 4MOTION MK60-AT 0102 Revision: 00H14001 Coding: 0023170 Shop #: WSC 73430 790 00000 VCID: 698E4478957151E338D-803C 1 Fault Found: 01324 - Control Module for All Wheel Drive (J492) 013 - Check DTC Memory - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 45D6A8C8D9A95583FC5-8010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005018991 Coding: E18A0F130004100000110D000000000000087F065C000000000000000000 Shop #: WSC 07894 067 57207 VCID: 71BE2C18BDA1A92370D-8024 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 060607 022 0601 Coding: 00055223 Shop #: WSC 07894 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 250607 046 0204 Coding: 00471077 Shop #: WSC 07894 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1A3RTX Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 Subsystem 1 - Serial number: 6332MSME184A620EG Subsystem 2 - Serial number: 6342MSME1C044D46G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 015E7CD88D01B9A380D-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Coding: 0007402 Shop #: WSC 11111 067 57207 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 160607F2000472 Coding: E9837F0E0002022303 Shop #: WSC 73430 790 00000 VCID: 3038E91C762BE02B3F3-8064 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 L Component: Haldex 4Motion 0116 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 3634DF04944FCE1B65F-8062 2 Faults Found: 00003 - Control Module 014 - Defective - Intermittent 02248 - Valve for Controlling Clutch Operating Angle (N373) 014 - Defective - Intermittent ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Shop #: WSC 00000 000 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3430E50C8233DC0B5BB-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 81801A085283007F3F02050FC0085F96907C00 Shop #: WSC 73430 790 00000 VCID: 035276D0971DABB3921-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 4801 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Part No: 1K0 951 605 D Component: LIN BACKUP HORN H07 9001 Subsystem 7 - Component: NGS n.mounted 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 20 Reset counter: 209 Mileage: 311813 km Time Indication: 0 Date: 2000.00.00 Time: 00:00:10 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 392ED438A551216388D-806C 1 Fault Found: 00121 - Outside Warning Light/Door exit Light Passenger Side 012 - Electrical Fault in Circuit ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000008 Shop #: WSC 73430 790 00000 VCID: 74B0250CC2B39C0B9BB-8020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0040 Revision: 00019000 Serial number: SKZ7Z3G0019189 Coding: 0000402 Shop #: WSC 73430 790 00000 VCID: 2E04F7646C1FF6DB2DF-807A No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 372AD200934537137E9-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 No fault code found. End----------(Elapsed Time: 01:20, VBatt start/end: 12.8V/12.6V)-----------
Octavia Mk2 Workshop Manual free download
here ya go mate...welcome to the world of Octavia wiring problems lol 1st things 1st buy a good quality contact cleaner I bought WD-40 Specialist Fast Drying Contact Cleaner with Smart Straw 400ml (link below) this stuff rocks, goes without saying make sure the battery is unplugged https://www.amazon.co.uk/gp/product/B006UCJ5WQ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 Manuel download link below https://mega.nz/file/h1dkiaQZ#yhdd--xrkMGjNMEMslkXjLo4VgNzqtHzG1jumO6PsIU
Electrical relay problems (Help & Advice Please)
(update )Sorry guys it does help when you push all 10 the engine management fuses and relays back in correctly
Hi Guys after charging the battery as advised its now showing a good voltage after 2 days of leaving it on charge, put all the dash back together this morning and went for a drive and the abs lights and steering lights have gone out but now it started beeping engine fault take to a garage. this is a new scan I done a few mins ago any ideals what it could be? I dont think its the horn? the car still starts up though or should I start a new scan thread?? Friday,02,April,2021,12:43:42:35642 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4 Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: TMBKE21Z788009343 License Plate: Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76 VIN: TMBKE21Z788009343 Mileage: 311810km-193749miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 SS HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 1302 Revision: --H07--- Serial number: SKZ7Z0G4311023 Coding: 0000172 Shop #: WSC 66565 257 00032 VCID: 025C73D48807A2BB997-8056 8 Faults Found: 005658 - Glowplug for Cylinder 1 (Q10) P161A - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 14:06:19 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 10.64 V Bin. Bits: 00101100 Temperature: 9.0°C Bin. Bits: 00110000 005659 - Glowplug for Cylinder 2 (Q11) P161B - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 14:06:19 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 10.64 V Bin. Bits: 00101100 Temperature: 9.0°C Bin. Bits: 00110000 005660 - Glowplug for Cylinder 3 (Q12) P161C - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 14:06:19 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 10.64 V Bin. Bits: 00101100 Temperature: 9.0°C Bin. Bits: 00110000 005661 - Glowplug for Cylinder 4 (Q13) P161D - 000 - Open Circuit Freeze Frame: Fault Status: 01110000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 14:06:19 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 10.64 V Bin. Bits: 00101100 Temperature: 9.0°C Bin. Bits: 00110000 000579 - Solenoid Valve for Boost Pressure Control (N75) P0243 - 000 - Malfunction - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 1 Fault Frequency: 2 Reset counter: 255 Time Indication: 0 Freeze Frame: RPM: 777 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.55 V Bin. Bits: 00101100 Absolute Pres.: 1224.0 mbar Absolute Pres.: 999.6 mbar 005269 - Switch-Over Valve for EGR Cooler (N345) P1495 - 000 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 2 Fault Frequency: 9 Reset counter: 255 Mileage: 311813 km Time Indication: 0 Date: 2000.00.00 Time: 21:21:19 Freeze Frame: RPM: 882 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.69 V Bin. Bits: 00101100 Mass Air / Rev.: 795.0 mg/str Mass Air / Rev.: 470.0 mg/str 000581 - Solenoid Valve for Boost Pressure Control (N75) P0245 - 000 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 6 Reset counter: 255 Mileage: 311813 km Time Indication: 0 Date: 2000.00.00 Time: 21:21:19 Freeze Frame: RPM: 882 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.92 V Bin. Bits: 00101100 Absolute Pres.: 1122.0 mbar Absolute Pres.: 999.6 mbar 000258 - Mass Air Flow Sensor (G70) P0102 - 000 - Signal too Low - MIL ON Freeze Frame: Fault Status: 11110000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 311813 km Time Indication: 0 Date: 2000.00.00 Time: 22:07:35 Freeze Frame: RPM: 924 /min Speed: 0.0 km/h Load: 0.0 % Duty Cycle: 100.6 % Bin. Bits: 00101100 Mass Air / Rev.: 635.0 mg/str Mass Air / Rev.: 0.0 mg/str Readiness: 1 4 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD Component: ESP 4MOTION MK60-AT 0102 Revision: 00H14001 Coding: 0023170 Shop #: WSC 73430 790 00000 VCID: 698E4478957151E338D-803C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 45D6A8C8D9A95583FC5-8010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005018991 Coding: E18A0F130004100000110D000000000000087F065C000000000000000000 Shop #: WSC 07894 067 57207 VCID: 71BE2C18BDA1A92370D-8024 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 060607 022 0601 Coding: 00055223 Shop #: WSC 07894 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 250607 046 0204 Coding: 00471077 Shop #: WSC 07894 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1A3RTX Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 Subsystem 1 - Serial number: 6332MSME184A620EG Subsystem 2 - Serial number: 6342MSME1C044D46G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 015E7CD88D01B9A380D-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Coding: 0007402 Shop #: WSC 11111 067 57207 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 160607F2000472 Coding: E9837F0E0002022303 Shop #: WSC 73430 790 00000 VCID: 3038E91C762BE02B3F3-8064 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 L Component: Haldex 4Motion 0116 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 3634DF04944FCE1B65F-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Shop #: WSC 00000 000 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3430E50C8233DC0B5BB-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 81801A085283007F3F02050FC0085F96907C00 Shop #: WSC 73430 790 00000 VCID: 035276D0971DABB3921-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Component: Sounder No Answer Subsystem 7 - Component: NGS n.mounted 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 8 Reset counter: 167 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 15:26:06 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000008 Shop #: WSC 73430 790 00000 VCID: 74B0250CC2B39C0B9BB-8020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0040 Revision: 00019000 Serial number: SKZ7Z3G0019189 Coding: 0000402 Shop #: WSC 73430 790 00000 VCID: 2E04F7646C1FF6DB2DF-807A No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 372AD200934537137E9-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 No fault code found. End----------(Elapsed Time: 01:20, VBatt start/end: 12.9V/12.8V)-----------
Ok just a quick update I went out with my trusty caravan battery fully charged and hooked that up with thick jump leads and no start though did turn over a lot better, tested the battery it come up good battery needs charging, then I found out how to get that module out and got my contact cleaner and took out every fuse every relay I could see even ones under the bonnet and driver side fuses, got behind the Module and gave it a dam good spray and wiggled all the wires and plugs, then sprays every single fuse and relay and pulled them in and out a couple of times. Connected the battery up and it started 1st turn got it connected to the smart battery charger now and will leave it to charge for 24 hours and then hopefully put all the dash back together. you dont undo the torx screws to get the module out there are 2 clips on the sides and it drops down with a wiggle and a pull, thought i,d put this in case anyone else dont know how they come out like me. I did have the steering wheel warning light lit up and the traction control light but sometimes they go out after a drive so I seen before, its a new steering rack so wont be that at least and all the brakes i have been done 2 years ago, will update you all tomorrow or after the car is put back together. thank you all for your help I'm disabled and on low income so its a huge help when you guys step in and help us save garage fees.. Alan
Just went out and tried that MicMac and nothing happens, only get the warning lights now when I turn the engine over and it beeps (not the horn) do you know how that relay box comes out I found 2 torx screws but cant see anything else holding it in place
it says number 46 twice: 46-Central Conv. -- Status: Malfunction 0010 not sure what that means as lots of conflicting things coming up on a google search . . Tuesday,30,March,2021,15:49:02:35642 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4 Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: TMBKE21Z788009343 License Plate: Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76 VIN: TMBKE21Z788009343 Mileage: 311810km-193749miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 SS HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 1302 Revision: --H07--- Serial number: SKZ7Z0G4311023 Coding: 0000172 Shop #: WSC 66565 257 00032 VCID: 025C73D48807A2BB997-8056 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD Component: ESP 4MOTION MK60-AT 0102 Revision: 00H14001 Coding: 0023170 Shop #: WSC 73430 790 00000 VCID: 698E4478957151E338D-803C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 45D6A8C8D9A95583FC5-8010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005018991 Coding: E18A0F130004100000110D000000000000087F065C000000000000000000 Shop #: WSC 07894 067 57207 VCID: 71BE2C18BDA1A92370D-8024 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 060607 022 0601 Coding: 00055223 Shop #: WSC 07894 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 250607 046 0204 Coding: 00471077 Shop #: WSC 07894 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1A3RTX Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 Subsystem 1 - Serial number: 6332MSME184A620EG Subsystem 2 - Serial number: 6342MSME1C044D46G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 015E7CD88D01B9A380D-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Coding: 0007402 Shop #: WSC 11111 067 57207 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 160607F2000472 Coding: E9837F0E0002022303 Shop #: WSC 73430 790 00000 VCID: 3038E91C762BE02B3F3-8064 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 L Component: Haldex 4Motion 0116 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 3634DF04944FCE1B65F-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Shop #: WSC 00000 000 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3430E50C8233DC0B5BB-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 81801A085283007F3F02050FC0085F96907C00 Shop #: WSC 73430 790 00000 VCID: 035276D0971DABB3921-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Component: Sounder No Answer Subsystem 7 - Component: NGS n.mounted 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 167 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 15:26:06 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000008 Shop #: WSC 73430 790 00000 VCID: 74B0250CC2B39C0B9BB-8020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0040 Revision: 00019000 Serial number: SKZ7Z3G0019189 Coding: 0000402 Shop #: WSC 73430 790 00000 VCID: 2E04F7646C1FF6DB2DF-807A No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 372AD200934537137E9-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 No fault code found. End----(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
think there's 2 faults now but cant find what they mean have you have a chance to look them up?
Tuesday,30,March,2021,15:51:57:35642 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4 Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: TMBKE21Z License Plate: Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76 VIN: TMBKE21Z Mileage: 311810km-193749miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 SS HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 1302 Revision: --H07--- Serial number: SKZ7Z0G4311023 Coding: 0000172 Shop #: WSC 66565 257 00032 VCID: 025C73D48807A2BB997-8056 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD Component: ESP 4MOTION MK60-AT 0102 Revision: 00H14001 Coding: 0023170 Shop #: WSC 73430 790 00000 VCID: 698E4478957151E338D-803C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 45D6A8C8D9A95583FC5-8010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005018991 Coding: E18A0F130004100000110D000000000000087F065C000000000000000000 Shop #: WSC 07894 067 57207 VCID: 71BE2C18BDA1A92370D-8024 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 060607 022 0601 Coding: 00055223 Shop #: WSC 07894 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 250607 046 0204 Coding: 00471077 Shop #: WSC 07894 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1A3RTX Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 Subsystem 1 - Serial number: 6332MSME184A620EG Subsystem 2 - Serial number: 6342MSME1C044D46G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 015E7CD88D01B9A380D-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Coding: 0007402 Shop #: WSC 11111 067 57207 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 160607F2000472 Coding: E9837F0E0002022303 Shop #: WSC 73430 790 00000 VCID: 3038E91C762BE02B3F3-8064 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 L Component: Haldex 4Motion 0116 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 3634DF04944FCE1B65F-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Shop #: WSC 00000 000 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3430E50C8233DC0B5BB-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 81801A085283007F3F02050FC0085F96907C00 Shop #: WSC 73430 790 00000 VCID: 035276D0971DABB3921-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Component: Sounder No Answer Subsystem 7 - Component: NGS n.mounted 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 167 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 15:26:06 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000008 Shop #: WSC 73430 790 00000 VCID: 74B0250CC2B39C0B9BB-8020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0040 Revision: 00019000 Serial number: SKZ7Z3G0019189 Coding: 0000402 Shop #: WSC 73430 790 00000 VCID: 2E04F7646C1FF6DB2DF-807A No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 372AD200934537137E9-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 No fault code found. End----(Elapsed Time: 01:16, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
ok will do that now
yes the codes were cleared will they not show up on another scan if i go try and start it?
was there no fault codes then Eddie?
Here you go Eddie the RAC guy said it was intermittent though . Tuesday,30,March,2021,13:49:49:35642 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4 Data version: 20210226 DS325.0 www.Ross-Tech.com VIN: TMBKE21Z License Plate: Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76 VIN: TMBKE21Z Mileage: 311810km-193749miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 SS HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 1302 Revision: --H07--- Serial number: SKZ7Z0G4311023 Coding: 0000172 Shop #: WSC 66565 257 00032 VCID: 025C73D48807A2BB997-8056 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD Component: ESP 4MOTION MK60-AT 0102 Revision: 00H14001 Coding: 0023170 Shop #: WSC 73430 790 00000 VCID: 698E4478957151E338D-803C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 45D6A8C8D9A95583FC5-8010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005018991 Coding: E18A0F130004100000110D000000000000087F065C000000000000000000 Shop #: WSC 07894 067 57207 VCID: 71BE2C18BDA1A92370D-8024 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 060607 022 0601 Coding: 00055223 Shop #: WSC 07894 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 250607 046 0204 Coding: 00471077 Shop #: WSC 07894 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1A3RTX Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 Subsystem 1 - Serial number: 6332MSME184A620EG Subsystem 2 - Serial number: 6342MSME1C044D46G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 015E7CD88D01B9A380D-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Coding: 0007402 Shop #: WSC 11111 067 57207 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 160607F2000472 Coding: E9837F0E0002022303 Shop #: WSC 73430 790 00000 VCID: 3038E91C762BE02B3F3-8064 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 L Component: Haldex 4Motion 0116 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 3634DF04944FCE1B65F-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Shop #: WSC 00000 000 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3430E50C8233DC0B5BB-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 81801A085283007F3F02050FC0085F96907C00 Shop #: WSC 73430 790 00000 VCID: 035276D0971DABB3921-8056 Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 Coding: 00000000 Shop #: WSC 73430 Subsystem 6 - Component: Sounder No Answer Subsystem 7 - Component: NGS n.mounted 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 167 Mileage: 311812 km Time Indication: 0 Date: 2000.00.00 Time: 15:26:06 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 392ED438A551216388D-806C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000008 Shop #: WSC 73430 790 00000 VCID: 74B0250CC2B39C0B9BB-8020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0040 Revision: 00019000 Serial number: SKZ7Z3G0019189 Coding: 0000402 Shop #: WSC 73430 790 00000 VCID: 2E04F7646C1FF6DB2DF-807A No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 372AD200934537137E9-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 3828D13C9E5B386B773-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43A45-8068 No fault code found. End----(Elapsed Time: 01:17, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Hi Eddie can you advise me please mate? I cleaned all the relays and ports off with the contact cleaner but when I pulled the 395 relays off the relay covers come off so I pushed them both back on and wiggled them out, if the covers come off does that break the relays? car still wont start and i,m really stuck, do you think replacing all the relays might help as I could not see how the relay box comes out so I dont know the part number as its on the back or I would buy another one on ebay, or if you know what one it is could you give me an ebay link please and will get my mate in the garage to fit it as I dont know how to set it up hope you can help mate as really stuck now I wish I had the money to just take it to a garage and say just fix it (how the other half live A)
. I have a Hex V2 Duel-K & CAN but I'm new to using it so no ideal how to copy and paste stuff, I do know what copy and paste is as I repair computers might have to go onto the ross-tec forums and ask how to do it
. Thanks for that Eddi, the RAC guy did a scan on it and wrote these notes so he said replace the box but I was going to use contact spray and give it all a clean, do you think I should try and source a used one as it does say its intermittent so it may not show on a scan? any advice would be really helpful please Eddi . .
Hi Guys been doing a bit of research and found 1 that looks the same as mine though it dont seem to include the top relays so might be 2 separate boxes. They seem to be plug and play what do you guys think? New ones are nearly £600 used from ebay about £20-30 but going to try using contact cleaner 1st Posting photos of them so if anyone else has to replace them you will know what to look for at least lol The names that it seems to identify the main relay box is : ONBOARD SUPPLY CONTROL MODULE or Skoda Octavia Mk2 1Z 2007 Comfort convenience module. Photos
