sealover1
Everything posted by sealover1
  1. here ya go guys... my post was done 6 years ago hence why the link runs out it would help if other members helped out instead of just taking and upload a link and share as I have done for 6 years I have no ideal how long this link will last for (Thankyou) https://ln5.sync.com/dl/8673aab60#r8wyjq5v-hcatcf9d-g5p4tztn-c4wgksu7
  2. share the link to the same manual then as I cant find what I uploaded on there, ManualsLib is for PDF files mine is software based
  3. I really dont know mate all I know is that since the new battery 2 years ago I've not had 1 warning light
  4. believe it or not I bought a new battery and charge it every few months and all the problems went away, been told the low battery is a common fault on these cars
  5. Valid for 30 days if you want a download https://easyupload.io/ldd156 Valid for 30 days if you want a download https://easyupload.io/ldd156
  6. Here you go guys a video of where the Horn is .
  7. Has anyone found out the best way to get to the scout 4x4 horns? mines gone again, can you take out the round fog light and get your hand inside to the horn rather then taking out all the lining ??
  8. dont know why they put them there tbh
  9. Dont believe this my bloody horn is gone again only replaced 1 of them, this time i,m going to move it to somewhere easy to get to and run the wires to it as cant remember now how the hell i got to it the last time
  10. I do need to know by the morning if anyone can help me please?
  11. can anyone tell me how to find the SPC code please I do have an Hex-V2 duel k & can Flashing key light, this warning is illuminated as someone has previously tried adapting the immobiliser/key without the 7 digit SPC. Unfortunately without this code I'm unable to access the immobiliser at all, you may be able to find the code in the handbook if the car has one.
  12. Is there a way to know if a car has been remapped? I have have a ross tech up to date scanner though I'm no expert at using it yet, When I bought my scout and was told it had been remapped but never had any receipt of proof, mind you it does feel quite nippy for a large car
  13. got find it 1st lol do they both run off 1 switch MicMac?
  14. Guys does the reversing switch work the rear parking sensors as well, one person on here said it does and one said it dont so unsure really and both my reversing light and sensor's are not working, it dont beep anymore when put into reverse
  15. is there any photos of where it is and what it looks like how to get it out?
  16. Is this on top the engine or under it?? I dont recognize any of it
  17. Hi guys my reversing lights and reversing sensors stopped working at the same time are they connected to the same fuse or switch and where is the fuse or switch located please? any tests I can do? manual FWD Scout 2007 estate
  18. . Could you or anyone upload a copy of the Haynes manual PDF please or dont it work that way??
  19. the thread is 4 years old mate when I done it U have run out of free places to upload it too
  20. is it a PDF mate? seems the Link to download it has been taken off
  21. Guys I come across this video what do you think?
  22. guess what 2 years working fine then got the same problem again. have searched internet then come across a thread saying bash it on the dash and by the key. just asked my mate who knows his stuff he has a guy that knows the cars he said this Never known a car like it for wiring faults my tech guy says, and i kid you not, "try slapping the dash on top and the bit by the key". dodgy connections are common! Hi guys cant get my car to start well it starts but then says immobilizer active on the dash changed the key battery no joy I have a code reader can it be turned off from there? any advice please as car wont start code scan same old faults again Friday,09,December,2022,11:41:33:35642 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: TMBKE21Z788009343 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1Z (1K0) Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76 VIN: TMBKE21Z788009343 Mileage: 316120km-196427miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-021-BMM.clb Part No SW: 03G 906 021 SS HW: 03G 906 021 AB Component: R4 2,0L EDC G000SG 1302 Revision: --H07--- Serial number: SKZ7Z0G4311023 Coding: 0000172 Shop #: WSC 66565 257 00032 VCID: 025C73D48807A2BBFD6-8056 VINID: 91D49B54206A1C82000090C40CA30CE1EB 5 Faults Found: 005658 - Glowplug for Cylinder 1 (Q10) P161A - 000 - Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 313015 km Time Indication: 0 Date: 2000.00.00 Time: 11:45:24 Freeze Frame: RPM: 840 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101100 Temperature: 17.1°C Bin. Bits: 10110000 005659 - Glowplug for Cylinder 2 (Q11) P161B - 000 - Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 313015 km Time Indication: 0 Date: 2000.00.00 Time: 11:45:24 Freeze Frame: RPM: 840 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101100 Temperature: 17.1°C Bin. Bits: 10110000 005660 - Glowplug for Cylinder 3 (Q12) P161C - 000 - Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 313015 km Time Indication: 0 Date: 2000.00.00 Time: 11:45:24 Freeze Frame: RPM: 840 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101100 Temperature: 17.1°C Bin. Bits: 10110000 005661 - Glowplug for Cylinder 4 (Q13) P161D - 000 - Open Circuit Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 313015 km Time Indication: 0 Date: 2000.00.00 Time: 11:45:24 Freeze Frame: RPM: 840 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 00101100 Temperature: 17.1°C Bin. Bits: 10110000 005488 - Engine Start Blocked by Immobilizer P1570 - 000 - - MIL ON Freeze Frame: Fault Status: 11110000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 316125 km Time Indication: 0 Date: 2000.00.00 Time: 20:43:25 Freeze Frame: RPM: 1134 /min Speed: 0.0 km/h Load: 6.7 % Voltage: 11.63 V Bin. Bits: 00101100 Bin. Bits: 11000000 (no units): 33.0 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels:. 1K0-614-517-MK60AT.clb Part No SW: 1K0 614 517 AD HW: 1K0 614 517 AD Component: ESP 4MOTION MK60-AT 0102 Revision: 00H14001 Coding: 0023170 Shop #: WSC 73430 790 00000 VCID: 698E4478957151E35CC-803C No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R Component: ClimatronicPQ35 110 0402 Revision: 00110021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 45D6A8C8D9A95583984-8010 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000005018991 Coding: E18A0F130004100000110D000000000000087F065C000000000000000000 Shop #: WSC 07894 067 57207 VCID: 71BE2C18BDA1A92314C-8024 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 060607 022 0601 Coding: 00055223 Shop #: WSC 07894 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 250607 046 0204 Coding: 00471077 Shop #: WSC 07894 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q4 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1A3RTX Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43C04-8068 Subsystem 1 - Serial number: 6332MSME184A620EG Subsystem 2 - Serial number: 6342MSME1C044D46G No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ Component: J0527 036 0070 Coding: 0002042 Shop #: WSC 73430 790 00000 VCID: 015E7CD88D01B9A3E4C-8054 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Coding: 0007402 Shop #: WSC 11111 067 57207 VCID: 392ED438A5512163ECC-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 160607F2000472 Coding: E9837F0E0002022303 Shop #: WSC 73430 790 00000 VCID: 3038E91C762BE02B5B2-8064 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: 1K0-907-554.lbl Part No: 1K0 907 554 L Component: Haldex 4Motion 0116 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 3634DF04944FCE1B01E-8062 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1612 Revision: V1612036 Serial number: SKZ7Z0G4311023 Shop #: WSC 00000 000 00000 VCID: 392ED438A5512163ECC-806C 1 Fault Found: 01176 - Key 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 144 Mileage: 316125 km Time Indication: 0 Date: 2000.00.00 Time: 11:38:28 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 D HW: 1T0 959 701 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3828D13C9E5B386B132-806C No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3430E50C8233DC0B3FA-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 81801A085283007F3F02050FC0085F96907C00 Shop #: WSC 73430 790 00000 VCID: 035276D0971DABB3F60-8056 Subsystem 1 - Part No: 1K0 951 605 D Component: LIN BACKUP HORN H07 9001 Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE No Answer 1 Fault Found: 01135 - Interior Monitoring Sensors 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 144 Mileage: 316125 km Time Indication: 0 Date: 2000.00.00 Time: 11:38:34 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb Part No SW: 1T0 959 702 D HW: 1T0 959 702 D Component: Tuer-SG 006 1204 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 392ED438A5512163ECC-806C No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 1T0-907-357.lbl Part No: 1T0 907 357 Component: Dynamische LWR 0003 Coding: 0000008 Shop #: WSC 73430 790 00000 VCID: 74B0250CC2B39C0BFFA-8020 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.clb Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0040 Revision: 00019000 Serial number: SKZ7Z3G0019189 Coding: 0000402 Shop #: WSC 73430 790 00000 VCID: 2E04F7646C1FF6DB49E-807A No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb Part No SW: 1K0 959 703 J HW: 1K0 959 703 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 372AD200934537131A8-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb Part No SW: 1K0 959 704 J HW: 1K0 959 704 J Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 73430 790 1012544 VCID: 3828D13C9E5B386B132-806C No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 1Z0-919-283.lbl Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B Component: Parkhilfe 4-Kan H04 0020 Coding: 0000001 Shop #: WSC 73430 790 00000 VCID: 3D26C028B1791D43C04-8068 No fault code found. End----------(Elapsed Time: 01:16, VBatt start/end: 12.2V/12.2V)-----------
  23. I just leave mine plugged in both winter and summer and I know the battery is always full cuz I have checked it with my battery tester so they do keep the battery in good nick
