Everything posted by Hamster59
- Your favourite S3 accessories!
Rear Dash Cam DAB Radio Interference Fix
Estate, and I ran the cable along the headlining
I have a dual camera set up, first camera was a BlackVue, now currently a Viofo A129 4k, and never had any issues with the radio signal, the rear camera is below the brake light onto the glass.
Installing spare wheel
I didn’t want any flex on it as the dogs are in there most of the time.
No rattle, and some at leat 10mm ply, a nice solid piece.
I used some plywood cut out the the boot liner template and some packing at the seat end, it is a handy storage space, hidden from sight.
Spare wheel set for 2018 Superb sportline
I’ve got a skinny space saver for sale, it should of said ( surplus to my requirements, as I’ve gone for a full size spare instead)
I’ve got a an 18 inch space saver, because I put a full size 18 inch as a spare instead.
Anyone got a guide to remove centre console trim
Don’t know why you would want to do this.
MY 2016 Estate Sun blinds
Or get a mate in the uk to buy them and then send them to you.
Hi I got some aftermarket ones tailored for the estate, you can even have the windows open and the shades stay put, I put them in during summer and remove them in winter. https://www.carshades.co.uk/shades-skoda-superb-estate-full-rear-p-4498.html
How to synchronise key when changed battery
I ve just changed mine, and nothing was different, it worked as normal without and extra work, I don’t have a keyhole to put it into on the drivers door so don’t know if that made a difference.
Front assist
They only give an audio warning, not physically stopping you unless you are using adaptive cruise control, which will activate the brakes.
Battery voltage low
Funnily enough I found my superb with its windows down as well this morning, but it closed up with the key as per normal. I have found that without a small drive every other day the battery os flat enough not to start, I have the charger like the one from Amazon but only paid a much smaller price from Lidl for a similar item, also a WiFi battery indicator from Lidl, I give it a charge once a fortnight, to top it up, and have a booster pack for when it won’t start. That’s the problem with lockdown,only local trips hardly even gets warmed up.
Superb locks boot on closing - can it be disabled?
Yes I’ve locked my keys in the boot , opened the boot with the remote puts keys down, loaded shopping and pressed the close boot with the boot button, had to go and get the spare from home to open the car and retrieve my keys.
Closing the tailgate / boot with the remote
Just a button press on the tailgate I’m afraid, it won’t close from the remote key fob.
Do all mk3 2.0tdi use adblue
I have a 2016 2ltr 150 sel executive, but no adblue.
Tailgate closed, still got warning lights
Hi community,I m on holiday in Cornwall, and have acquired a problem. The tailgate closes as per normal, but when I lock the car the maxi dot display display flashes boot open in red and the hazard warning light button also flashes inside the car. When I the car is driven then the warning chimes are on for a door open and the display flashes very briefly about the boot, but it is secured and locked in a practical sense, so any ideas?? Don’t want it flattening the battery when parked, as the display doesn’t go out, when it’s parked up. Help from Hayle, Cornwall.
