Everything posted by DAVEEVO
2013 fabia 1.6 tdi p256300
ok guys thought id let you know the fault came back again , it lasted about 2 weeks been messing since then with setting on actuator etc etc had every vac hose off again blah blah blah and the eventually vac tested my new oem n75 (valve which id peviously ruled out as it was 80 quid and not 12 quid on ebay ) and boom it was only letting 15 inches of mercury through at idle when it should be at least 20/22 or preferably more .it must have been just coping until certain conditions were met which i found to be more often than not low rpm in gear just letting the torque pull the car without any throttle input normally when crawling in traffic etc ,the boost should be max at this point but without the correct amount of vacuum it was reading the discrepancy between expected and actual boost on the actuator . i then bought another oem n75 and the car woke up ,boost bact at approx 1200rpm and not 2500 ish where it was when not in limp mode . anyway it was a big learing process(id never done a turbo actuator and set it up before but now can do with my eyes shut lol ) and the car now fixed at last .. i really hope somebody can get something out of the post if the same happens to them and they wont have to go down the same n75 rabbit hole as me,i wouldnt mind but i never bought a cheap one .just goes to show dont trust any parts without testing .. dave .. ps the n75 that was faulty was a meat and doria product from euro car parts which is billed as being equivalent oem .. it now has a pierburg n75 which is oem........
- VCDS Adaptations. How do I ..........
ok im back ,the fault came back but it was needing setting up with vcds to learn its endpoints . i tweaked it after some confusion with info in internet stating the voltage without vacuum applied should be around 3.5 ish volts on vcds and with vacuum should be 0.7v ish ,both my old and new actuator behaved the reverse without vacuum was lower than with but it never got near 0.7 the lowest it would go was 1.4 but fully vaccumed i could get it to 3.5 ish . dont know if my system is different but after tightening the nuts to that setting of 3.5v fully vacuumed and running the set up in vcds it said test complete ok and its been fine for 2 days now with multiple use motorway and town . hopefully its sorted now . hope this points somebody in the right direction . dave .
mine had a new n75 about 3 mnonths ago at 80 quid from euro car parts ,i alway try to avoid ebay after market stuff as its normally cheap nasty crap. but as you said you got an oem one so all good . ive found darkside website what are their parts like ?
i used to deliver flowers for intaflora in a bedford rascal van ,suzuki 1000cc as i remember . brilliant vans , no air bags and sat right at the crash zone when driving lol . love em .
ok i now have it solved ,time will tell but its looking good . it was doing it more when getting off throttle so the code was being thrown by the low boost end of the actuator which needed setting . as per the vid below i set the actuator with key on engine off ,back probed the middle wire on actuator with multi meter and had a vacuum pump on the pipe which feeds actuator from solenoid as my vac pump pipe was to big for the actuator fitting . loosened the nuts on actuator rod and pumped vac pump until meter read 0.7 volts dc (neg side of multi meter was on car battery neg terminal) then tightened the top nut down to that position ,i then released the vacuum and the arm came up to read 3.3v . i think the fault triggers under 3.3v and below 0.7v at the other end . i did have to mess a little with the settings after tightening up and ended up with 3.35v and 0.78v which seems to be fine now .. if it comes back i'll follow up this post . hope this helps somebody .. thanks for the input .. Dave ...
ok alasdair ive changed the actuator only one i could get was ebay unfortunately as skoda didnt have any. i counted old threads to top nut and did same on new one but i realise that could be way out between the 2 sensors . the arm on the turbo moves really freely (loose),the wiring looks good on all sensors and checked for green corrosion inside plugs etc. im getting good ohm reading across the solenoid (75) and its clicking when i unplug and plug back in . the vacuum from the pump is strong , all pipes inspected and all seems well including the check valve which i can only blow through one way. im a bit lost now . could it just be a calibration thing on the new one showing the same fault as the old possibly faulty one ? my mate has vcds but im not sure how to calibrate it on there and the voltages required to make it happy. thanks bud dave .
hi guys hope you can help me and my beloved fabia 1.6 tdi (105hp). I'm getting a p256300 fault with coil and engine mils on dash in amber also down on power on motorway 70mph in 4th max. i found that the vet hose from rocker cover to intake had 2 small holes where it had worn through and one of the clips was broken which secure it to the rocker cover so its not seated correctly,ive taped it up until new one arrives but not sure if its sealing correctly on cover without the clip. im guessing the thing it connects to is the pcv but not sure . ive also recently replaced the turbo boost control solenoid with a reputable one from euro car parts 80 quid not ebay one . checked all the small hoses and cant see any damage etc . would this cause the fault or do i need to look somewhere else please .. thanks guys dave .
1.6tdi judder when cold
Thanks guys .no white smoke at all.
Hi guys as above ,not a big judder but noticeable when cold .I've used some injector cleaner and cleaned throttle body . Is it just a case of Asda diesel or something else to look for. It starts and runs great in every other way with no lights on dash . It's done 120,000 miles and gets new oil and filter every 5000 miles . Thanks. Dave.
annoying rattle solved
Hi Guys Just thought I'd post this incase anyone else has it , I have had a knocking noise at the rear of my 2013 fabia that sounded like the shocks were loose or something loose around that area on both sides . I have had the boot empty inc spare wheel,rear wheel liners out to check shocks ,new exhaust rubbers blah blah blah . Anyway I was sat in the back seat last night while on the move and had my arm accross the rear seats as the noise started and its the bloody back seats rattling on the fold down clips/catches .. I have been chasing this for 2 years on and off lol . Think im gonna adjust the steel brackets that the seats latch to(big hammer) or get some sticky felt pads or similar to dampen them ... Hope this saves someones sanity ;-). Dave.
Manual gearbox oil type, amount.
Hi guys I'm going to change above as car now has 100k on it . I have searched for oil type and amount but there are so many different answers it's left me confused. What do I look for on eBay please and how much will I need. 1.6tdi 2013 mk2 105hp Thanks Dave
Just fitted new anti roll bar bushes
I always stick with OEM stuff it's worked for 9 years up to changing them so that's good enough for me.
Not really just get both front wheels off and unbolt em from the bulk head at the bottom . It's all pretty easy stuff just nuts and bolts
I had a clunk noise on the nearside front prob down to the sorry state of the roads , Anyway I took wheel off and got pry bar out nothing really obvious with drop link/ball joints etc ,All I could find was a very small amount of play in the anti roll bar bush so I ordered a set and did em today (both sides) and the clunk is no more 😉 . They didn't look perished or worn to be honest but but you can see the difference on the noisy one ,The flat side is thinner and softer. Only posting this incase it helps others for a cheap fix (£8)
coolant level dropped
thanks guys i will monitor it and if it drops again its time to get under it and have a look firstly ...
thanks for replying , im now monitoring the level and checking when cold in the mornings to get a true reading every time . when cars coolant drops and there is no leaks where does it go ???
hi guys ,i got the red warning on dash and checked coolant to find it had dropped below low level but not empty , my missus drives it now and a couple of days ago she reported a noise which sounded like a washing machine pump , im guessing its the electric coolant (B) pump . ive not had a chance to look under it yet to check for leaks etc . anybody else had a similar issue and do you think they might be connected ? the coolant droped about an inch in the expansion bottle and once topped up the light went out and it drives normally .. 1.6 tdi 105hp thanks dave
driving lights led swap.
The car is 2013 mk 2 the lights I'm talking about are the ones that go out when any of the lights are selected,also turned off with the switch in the fuse box . I remember years ago on bikes you had to put a resistor in the wiring to stop em flashing fast. I just wondered if they now make bulbs which have it all built in. Cheers
But still a good visual aid for the many blind idiots on the roads.
Thanks for replying but not exactly what I needed.
hi guys I'm now sick of replacing my bulbs in the front driving lights , are there any led's that will work without fault light on dash etc ? i bought some off flea bay but only one would work when turned on (both bulbs checked and working when directly connected to battery ) but they where just led bulbs and not can bus ones which i presume they have to be a guess ?. cheers guys
flashing coil light on dash fault code p0101
It's the carista app and Bluetooth obd dongle .
yeah just wondered if anybody else had had this code .. cheers anyway ..
it did say dealer specific code ?
