driving lights led swap.
hi guys
I'm now sick of replacing my bulbs in the front driving lights , are there any led's that will work without fault light on dash etc ? i bought some off flea bay but only one would work when turned on (both bulbs checked and working when directly connected to battery ) but they where just led bulbs and not can bus ones which i presume they have to be a guess ?.
cheers guys
Stop using them then, they're completely unnecessary in the UK, you won't be able to fool the ECU because it works on current drain and LEDs use a lot less current.
Thanks for replying but not exactly what I needed.
What makes you say that?   Why are driving lights unnecessary in the UK?
Because they're not mandated by law like they are in other European countries where these cars are sold.
That's why.
But still a good visual aid for the many blind idiots on the roads.
  • Sponsor
What year is the car, and does it give you indication of failed bulbs on the instrument cluster?
That's why.
but the poster clearly wants to use them whether they are mandated or not - perhaps to illuminate the road (bearing in mind he's said driving lights not DRLs).
I was simply pointing out that the current sensing circuitry is very tricky to overcome and that if he was fed up with replacing bulbs that he didn't need to use them.
Ok.
So it is DRL's being asked about.
As in Daytime / Daylight running lights.   On with the ignition to the front.
Maybe Bright when no Sidelights / Headlights on but not when they are.
Mandatory fitted from the factory in the EU including UK from 2011, but only on new Type Approved cars so even Mk3 from 2014 did not require them as standard.
Edited by roottoot
The car is 2013 mk 2  the lights I'm talking about are the ones that go out when any of the lights are selected,also turned off with the switch in the fuse box . I remember years ago on bikes you had to put a resistor in the wiring to stop em flashing fast. I just wondered if they now make bulbs which have it all built in. Cheers
