Everything posted by Carlston
Flat Tyre Because Of No Valve Stem Cap?
Pump the tyre up and see if air is leaking out of the valve. You can put a bit of soapy water on the end of the valve to check for air bubbles, if you can't hear or feel air coming out of the valve. It's the valve core that is designed to stop the air leaking, not the valve cap. The valve cap's job is to stop dirt getting into the valve core, although the valve cap does provide a secondary seal.
Superb tyres recommendations
Below 0 degrees Centrigrade, the Kleber Quadraxer 2 outperforms most all-season tyres. Handling in the snow is better than the CrossClimate 2. At under £130 including shipping, it's a lot less than the Michelin. Kleber is a Michelin brand, and should give similar high mileage. Think of the Quadraxer 2 as a winter tyre, that can also be used in the summer...ie, a winterised all-season tyre, so like the Nokian all-season tyres that are also winter focused. 245/45R18 is a good alternative to the standard 235/45R18 tyre size on the Superb MK3's 8J rims. The sidewalls on 245/45R18 will bulge out a little more than the 235/45R18 size, thereby giving a little more rim protection from kerbing damage. The ride should be slightly improved too. 245/45R18 is a more common and cheaper size than 235/45R18. Kleber Quadraxer 2 245/45R18 All-Season Tyre (only about 1% bigger outside diameter than the standard 235/45R18 size) https://www.mytyres.co.uk/rshop/tyre/Kleber/Quadraxer-2/245-45-R18-100W-XL/R-388833
Octavia Scout Mk3 Rear Suspension
Octavia MK2 4x4 Scout Rear Springs (1) 1K0 511 115 CR coil spring 1 paint mark 2 paint marks red green 2 PR-1JB+0YK (1) 1K0 511 115 CS coil spring 1 paint mark 3 paint marks red green 2 PR-1JB+0YL (1) 1K0 511 115 CT coil spring 1 paint mark 1 paint mark rear red brown 2 PR-1JB+0YM https://skoda.7zap.com/en/cz/octavia/oct/2012-663/5/511-511012/ Octavia MK3 4x4 Scout Rear Springs 1 5Q0 511 115 AL coil spring 2 PR-1JB+0YC (1) 5Q0 511 115 AM coil spring 2 PR-1JB,0YD (1) 5Q0 511 115 AN coil spring 2 PR-1JB+0YE https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/#1 1K0511115CR is the same as 5Q0511115AL 1K0511115CS is the same as 5Q0511115AM 1K0511115CT is the same as 5Q0511115AN Octavia MK2 4x4 Scout rear springs are usually cheaper than Octavia MK3 4x4 Scout rear springs. Here's proof that 1K0511115CS is interchangeable with 5Q0511115AM (notice these Kilen and Lesjofors springs are sold to replace both OEM part numbers) https://www.autodoc.co.uk/car-parts/oem/1k0511115cs?search=OEN+1K0511115CS&supplier[0]=246&supplier[1]=253 KYB RH6426 1K0511115CT https://www.ebay.co.uk/itm/174956646233?hash=item28bc3a8f59:g:lgIAAOSwljlhUrTF There aren't many aftermarket shock absorbers sold to replace Scout shock absorbers. Scout models use +15mm springs. Therefore you could use standard ride height shock absorbers, as +15mm isn't much for the standard shock absorbers to cope with. Or use original Skoda Scout shock absorbers. Below are your front and rear springs and shock absorbers, for your Octavia MK3 4x4 Scout. 5Q0411105HS front springs L31 (1) 5Q0 411 105 HS coil spring 1 paint mark 1 paint mark grey blue 2 PR-L31 https://skoda.7zap.com/en/cz/octavia/oct/2013-753/4/411-411030/ 5Q0511115AL rear springs 1JB+0YC 1 5Q0 511 115 AL coil spring 2 PR-1JB+0YC https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/#1 5Q0413023GB front shock absorbers G09 (8) 5Q0 413 023 GB gas shock absorber 49,6MM 2 PR-G09 https://skoda.7zap.com/en/cz/octavia/oct/2013-753/4/411-411002/ 5E0513029C rear shock absorbers 1JB+K8D 7 5E0 513 029 C gas shock absorber rear 2 PR-1JB+K8D https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/#7
OEM part number 1K0511115BH could be used instead of 5Q0511115H as they appear to be the same springs. 1K0511115BH is from the Octavia MK2, whereas 5Q0511115H is from the Octavia MK3. If you look on autodoc you will see that there is more choice for 1K0511115BH rear springs than 5Q0511115H rear springs. 1K0511115BH https://www.autodoc.co.uk/car-parts/oem/1k0511115bh?search=OEN+1K0511115BH KYB RA7103 1K0511115BH https://www.ebay.co.uk/itm/234261311747?epid=25029981017&hash=item368b0ff103:g:LkkAAOSwQPthe9Vv
Mk II Octy Estate - Variable rate springs OTHER than Bilstein??
These are standard rear springs for the Octavia MK2 Estate 2.0TDI. Kilen 63118 (OEM part number 1K0511115BG) https://www.ebay.co.uk/itm/323693514969?epid=248980682&hash=item4b5da310d9%3Ag%3AcUIAAOSww35cZE7X&LH_ItemCondition=1000
tyres
It depends what country you order the car in. In Finland, Czech and Gemany, the RS model comes with 18" wheels as standard.
Normal 4x4 springs should be enough lift to the rear. Manual or automatic transmission usually makes a small difference to the front springs. It doesn't affect the rear springs. Lesjofors 4295133 (OEM part number 5Q0511115H) rear springs. Standard ride height, 4x4, with towbar. https://web.tecalliance.net/lesjofors/en/parts/175/4295133/detail?targetType=cars&targetId=59490&typeNumber=59490&targetCountry=AT&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20OCTAVIA%20III%20Combi%20(5E5%2C%205E6)%202.0%20TDI%204x4;targetType:cars;targetId:59490;typeNumber:59490;targetCountry:AT/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:59490;typeNumber:59490;targetCountry:AT;groups:188;brands:175;page:0/detail:4295133;brandId:175;articleNo:4295133;targetType:cars;targetId:59490;typeNumber:59490;targetCountry:AT;groups:188 Lesjofors 4295133 are listed on ebay.de (the German version of ebay) https://www.ebay.de/itm/312961507221?epid=15032759793&hash=item48ddf59f95:g:6I4AAOSwmU9eSbQ3
tyres
There's two versions of the Goodyear Eagle F1 Supersport in size 225/45R18 shown on mytyres. Going by the euro label, the standard load version is the pick of the pair. 225/45R18 91Y (Euro label C A 70dB) 225/45R18 95Y (Euro label D A 72dB) https://www.mytyres.co.uk/search?minPrice=&maxPrice=&season=So&width=225&profile=45&size=18&speedRating=&loadIndex=&brand=Goodyear&priceCategory=recommended&clientReviewsRating=&approvedBy=&isRunflat=&reinforced=&cTire=&rimProtection=&sealLayer=&noiseReduction=&businessReviews=false&homologation=&vehicleTypes=PKW&vehicleTypes=RACE_PKW&vehicleTypes=LLKW&vehicleTypes=VINTAGE_PKW&vehicleTypes=OFF&sortCode=price_asc
Replacement Front Suspension Spring
NAPA NCS1114 matches OEM part number 3C0411105C. If you have a manual gearbox, this part fits your car. The specification of NAPA NCS1114 is identical to KYB RH3559, so it was probably made by KYB and is simply rebranded to NAPA. Sports suspension or lowered suspension means that the suspension is 15mm lower than standard. Increased ride height suspension or heavy-duty suspension, means that the suspension is 15mm higher than standard. OEM part number 3C0411105C is for standard ride height suspension. Your front shock absorbers have OEM part number 3C0413031AS (as shown in your photo). This is a standard ride height shock absorber, so your car has standard ride height. Standard Ride Height Front Shock Absorber (8) 3C0 413 031 AS gas shock absorber 2 PR-G15 https://skoda.7zap.com/en/cz/superb/sup/2012-632/4/411-411001/
tyres
On the Octavia MK4, the 18" wheels have a specification of 225/45R18 fitted to 7.5Jx18 ET48 rims, and that includes the Scout which is 4x4. On the previous Octavia MK3, the Scout which is 4x4 used bigger outside diameter tyres than other cars in the range, eg. 225/50R17 instead of 225/45R17. 225/50R17 has a similar outside diameter to 205/55R17 (the 17" tyre size fitted to the Octavia MK4)...so you could say that all models in the Octavia MK4 range have been Scoutified...at least with reference to the outside diameter of their tyres. I imagine all models including 4x4 are fitted with similar tyres, ie. eco summer tyres for maximum mpg and lowest CO2 emissions. wheel-size.com https://www.wheel-size.com/size/skoda/octavia-scout/2021/
2009 superb front coil spring part number
I bought what was supposed to be a matched pair of springs from autodoc. One weighed about twice as much as the other spring and was massively bigger. This is why it's important to know the specification of the springs that you are buying. I sent the springs back for a refund, but autodoc refused to refund the cost of shipping them back...saying that I hadn't paid the £3 or £4 extra for the free return service...even though they were in breach of contract for supplying me with incorrect goods. For this reason, I prefer to buy from ebay especially as it's often cheaper. On ebay, return shipping is paid for if incorrect goods are sent out.
Sachs 993 061 or sometimes listed as Sachs 993061 (ie. without the space) is sold to replace 3C0411105C. They are no better than KYB RH3559 that also matches 3C0411105C. On ebay, the virtually identical Sachs is about two-and-a-half times the price. It seems like a no-brainer to go for the KYB, or at least something much better value than the Sachs. KYB claim their spring/shocks, etc. are fitted to about 25% of new cars. Whatever the exact percentage, they are certainly very big players. Kilen 25068 is available on ebay for about £26 each, so again much better value than Sachs. I doubt Sachs actually make the springs. I've got some, and they are just plain black springs with a Sachs sticker that someone has stuck on. The Sachs sticker itself is all crinkled, and peels off very easily...and sticks back on very easily. This suggests that Sachs hasn't actually made this spring, as I would have thought they would have marked it more permanently if they had made it. The amount of rebranding in aftermarket parts in on a massive scale. So often the parts that are sold under different brand names seem the same...but there are differences sometimes. Just look how many brands are selling springs to replace 3C0411105C on autodoc. I'm counting 38 different brands. There certainly isn't anything like 38 different factories making this same specification of spring. What's happening, is that there's a lot of rebranding going on...although the springs are unlikely to have come out of just one factory. 38 different brands of 3C0411105C springs listed on autodoc (there's a lot of rebranding going on) https://www.autodoc.co.uk/car-parts/oem/3c0411105c?search=OEN+3C0411105C&supplier[0]=253&supplier[1]=85&supplier[2]=246&awc=12639_1641577297_083478a8bfdbfbc4389cbb77895f0485&supplier[3]=32 With KYB and Kilen/Lesjofors you are more likely to find that these firms have actually made their own springs. I bought some Kilen/Lesjofors springs, and they had manufacturers' codes laser etched onto them, not some dodgy sticker applied as some kind of afterthought.
KYB RH3559 are sold to replace 3C0411105C and are available on ebay for about £20 each. https://www.ebay.co.uk/itm/334250861618?hash=item4dd2e76432:g:d20AAOSwYJ1htI5g 3C0411105C Kilen 25068 Lesjofors 4095086 Kilen/Lesjofors are the same springs, made in the same factory in Sweden. Kilen/Lesjofors don't give the specifications of their springs which can be a disadvantage. 3C0411105C https://www.autodoc.co.uk/car-parts/oem/3c0411105c?search=OEN+3C0411105C&supplier[0]=246&supplier[1]=85&supplier[2]=253
What Generation Ea888 engine do I have please?
Octavia MK2 RS Petrol Engines 2.0 TFSI RS 1984 cc 16v DOHC Turbocharged Fuel Stratified Injection 200 PS (147 kW; 197 bhp) at 5,100–6,000 280 N⋅m (207 lbf⋅ft) at 1,800–5,000 BWA 10.2005– 10.2008 2.0 TSI RS 1984 cc 16v DOHC Turbocharged Fuel Stratified Injection 200 PS (147 kW; 197 bhp) at 5,100–6,000 280 N⋅m (207 lbf⋅ft) at 1,700–5,000 CCZA 11.2008– 2012 There aren't two generations of the CCZA engine. The one before it, as fitted to the Octavia MK2 RS, had engine code BWA. The next 2.0 litre RS petrol engine that was fitted to the Octavia MK3 was called a EA888-Gen3 engine. Comparing the CCZA and CHHB engines, the torque went from 280Nm to 350Nm...that a very big 25% increase in torque. Of course, with just front wheel drive, putting the power down when you've got 220PS of power and 350Nm of torque can sometimes be a problem. Maybe the lower powered 200PS/280Nm engine isn't such a bad idea after all... Octavia MK3 RS 220 Petrol Engines 2.0 TSI RS 162 kW (RS 220) 2013- CHHB (EA888-Gen3) 1984 ccm, I4, 16V DOHC, TSI, turbocharged 162 kW (220 PS; 217 hp) at 4500-6200 rpm 350 Nm. (258 lb•ft) at 1550-4400 rpm 6-speed manual (MQ350), FWD 248 km/h (154 mph) 6.8 6.2 / 45.6 / 37.9 142 2.0 TSI RS 162 kW (RS 220) 2013- CHHB (EA888-Gen3) 1984 ccm, I4, 16V DOHC, TSI, turbocharged 162 kW (220 PS; 217 hp) at 4500-6200 rpm 350 Nm. (258 lb•ft) at 1550-4400 rpm 6-speed DSG (DQ250), FWD 245 km/h (152 mph) 6.9 6.4 / 44.1 / 36.7 149 https://en.wikipedia.org/wiki/Škoda_Octavia 310PS/425Nm 2.0 turbo petrol engine fitted to Seat Leon 2.0 TFSI Cupra 310 Limited Edition 1984 cc 16v DOHC Fuel Stratified Injection 228 kW (310 PS; 306 bhp) at 6,000 rpm 425 N⋅m (313 lbf⋅ft) at 3,000–5,000 rpm N/A (EA113) 2008 – 2009 https://en.wikipedia.org/wiki/SEAT_León#Engine_specifications
17 inch Octavia spiders
7Jx17 ET38 5/100 57.1 16 1U0 601 025 P aluminium rim 7 JX17H2 ET38 4 RS 1U0601025P 7ZS chrome coloured metallic 2012.00 - 2001.06 (16) 1U0 601 025 P aluminium rim 7 JX17H2 ET38 4 RS-WRC 1U0601025P F9E candy white 2008.00 - 2008.03 https://skoda.7zap.com/en/cz/octavia/oct/2003-252/6/601-601050/
If your car has build code L03, it will have front springs with OEM part number 3C0411105C. If your car has build code L04, it will have front springs with OEM part number 1K0411105BP. As you can see, knowing your car's build codes makes it easy to identify what springs you have (and shock absorbers, and brakes, and many other parts on your car). However, if you don't know your build codes, the following should help. If you have a 2009 Superb MK2 2.0TDI 140HP 2WD with manual gearbox and standard ride height (eg. not +15mm increased ride height, or -15mm lowered ride height) you will have front springs with OEM part number, or something similar. If you have a 2009 Superb MK2 2.0TDI 140HP 2WD with automatic DSG gearbox and standard ride height (eg. not +15mm increased ride height, or -15mm lowered ride height) you will have front springs with OEM part number 1K0411105BP, or something similar. You can see in the chart below, that a 3C0411105C front spring has 1 orange dot, 1 green dot, and 2 yellow dots...and a 1K0411105BP front spring has 1 red dot, 1 white dot, and 1 red dot or 2 orange dots and 1 white dot. № part code title note quantity data model information suspension shock absorber (spring cyl.) anti-roll bar front combi 1 3C0 411 105 A coil spring 1 paint mark 1 paint mark 2 paint marks orange green orange 2 PR-L01 (1) 3C0 411 105 B coil spring 1 paint mark 1 paint mark 2 paint marks orange green yellow 2 PR-L02 (1) 3C0 411 105 C coil spring 1 paint mark 1 paint mark 2 paint marks orange green yellow 2 PR-L03 (1) 1K0 411 105 BP coil spring 1 paint mark 1 paint mark 1 paint mark also marked with: 2 paint marks 1 paint mark red white red orange white 2 PR-L30,L04 (1) 1K0 411 105 DK coil spring 3 paint marks orange 2 PR-L31 https://skoda.7zap.com/en/cz/superb/sup/2009-632/4/411-411001/ Specification of front springs with OEM part number 3C0411105C Spring Design Coil spring with constant wire diameter Fitting Position Front Axle Wire Diameter 12.75 mm Length 339 mm Outer diameter 142 mm Weight 2.2 kg Transmission Type Manual Transmission https://web.tecalliance.net/gkn/en/parts/1/86458/detail?targetType=cars&targetId=31965&typeNumber=31965&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20SUPERB%20II%20(3T4)%202.0%20TDI%2016V;targetType:cars;targetId:31965;typeNumber:31965/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:31965;typeNumber:31965;groups:188;brands:1;page:0/detail:86458;brandId:1;articleNo:86458;targetType:cars;targetId:31965;typeNumber:31965;groups:188 Specification of front springs with OEM part number 1K0411105BP Spring Design Coil spring with constant wire diameter Fitting Position Front Axle Colour Coding Orange (2x), White Wire Diameter 13.25 mm Length 342 mm Outer diameter 144 mm Weight 2.35 kg Transmission Type Automatic Transmission https://web.tecalliance.net/gkn/en/parts/1/56674/detail?targetType=cars&targetId=31965&typeNumber=31965&groups=188#@brc/brands:Car;targetType:cars/assem:SKODA%20SUPERB%20II%20(3T4)%202.0%20TDI%2016V;targetType:cars;targetId:31965;typeNumber:31965/lnkparts:Coil%20Springs;targetType:cars;assemblyGroupId:100113;targetId:31965;typeNumber:31965;groups:188;brands:1;page:0/detail:56674;brandId:1;articleNo:56674;targetType:cars;targetId:31965;typeNumber:31965;groups:188
5Q0511121BE is for a front wheel drive car, not a 4x4. You need to use 4x4 springs, if you have a 4x4. You can use 4x4 Scout springs if you want 15mm increased ride height, compared to standard ride height springs. The VRS 4x4 will probably have 15mm lowered ride height, ie. sports suspension. You have three choices of rear Scout springs. They will all give you about the same unladen ride height. The difference is in the compression rate. The 13.00mm version is about 8% stiffer than the 12.50mm version, and the 12.75mm version is about 4% stiffer than the 12.50mm version. As you are towing, I would go for either the 12.75mm or 13.00mm version. Wire Diameter 12.50mm, Weight 2.45kg 1K0511115CR (from Octavia MK2 Scout) 5Q0511115AL (from Octavia MK3 Scout) These two springs appear identical and interchangeable. The MK2 springs are sometime cheaper than the MK3 springs. Wire Diameter 12.75mm, Weight 2.6kg 1K0511115CS (from Octavia MK2 Scout) 5Q0511115AM (from Octavia MK3 Scout) These two springs appear identical and interchangeable. The MK2 springs are sometimes cheaper than the MK3 springs. https://www.autodoc.co.uk/eibach/13828877 Wire Diameter 13.00mm, Weight 2.75kg 1K0511115CT (from Octavia MK2 Scout) 5Q0511115AN (from Octavia MK3 Scout) These two springs appear identical and interchangeable. The MK2 springs are sometimes cheaper than the MK3 springs. https://www.autodoc.co.uk/eibach/13828886 Octavia MK2 4x4 Scout Rear Springs (1) 1K0 511 115 CR coil spring 1 paint mark 2 paint marks red green 2 PR-1JB+0YK (1) 1K0 511 115 CS coil spring 1 paint mark 3 paint marks red green 2 PR-1JB+0YL (1) 1K0 511 115 CT coil spring 1 paint mark 1 paint mark rear red brown 2 PR-1JB+0YM https://skoda.7zap.com/en/cz/octavia/oct/2012-663/5/511-511012/ Octavia MK3 4x4 Scout Rear Springs 1 5Q0 511 115 AL coil spring 2 PR-1JB+0YC (1) 5Q0 511 115 AM coil spring 2 PR-1JB,0YD (1) 5Q0 511 115 AN coil spring 2 PR-1JB+0YE https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511010/
Spare wheel kit
Three spare wheel kits are shown on "skoda eshop cz" for the Octavia MK3, ie. standard version, Scout version, and VRS version. 1036CZK is about £35, so they aren't expensive new...and you should be able to order them from any Skoda dealer. The standard version should be able to take the standard full size wheels, including 195/65R15 fitted to a 6Jx16 ET43 rim, and a 205/55R16 fitted to a 6.5Jx16 ET46 rim. Although do check with the Skoda dealer before any purchase. https://eshop.skoda-auto.cz/cs_CZ/sady-pro-vymenu-kol/c/setsToChangeWheels?q=%3AscoreDesc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29
Yeti questions
Take a look at the engines on wikipedia to see which one you want. https://en.wikipedia.org/wiki/Škoda_Yeti For best fuel economy out of the petrol engines and no problems with DSG gearboxes, I would go for the 2015 onward 1.2 engine with engine code EA211 rather than the earlier EA111 and 6 speed manual gearbox. 16 valve engine, ie. 4 valves per cylinder. DOHC Double Over Head Camshaft. 111mph top speed, 0-62mph in 10.9secs. CO2 emissions 128g/km. 110PS@5,000rpm, 175Nm@1,500-4,000rpm. Fuel consumption 5.5/51.4/42.8 As maximum engine torque comes in from as low as 1,400rpm, it will drive better than even a 1.8 petrol engine without a turbo. These modern turbo engines give you lots of power low down in the rev range. The 0-62mph in just over 10secs and the top speed of over 110mph is plenty for this type of car. The top speed and acceleration is similar to some lower powered sports cars.
Octavia Lift Kit
So go with... Front springs with 15mm increase in ride height 5Q0411105HN https://www.autodoc.co.uk/car-parts/oem/5q0411105hn?search=OEN+5Q0411105HN Kilen 23132 5Q0411105HN https://www.ebay.co.uk/itm/353523621748?epid=249508912&hash=item524fa65f74%3Ag%3A0nAAAOSw-S1guy8P&LH_ItemCondition=3 Rear springs with 15mm increase in ride height 5N0511115C https://www.autodoc.co.uk/car-parts/oem/5n0511115c? Kilen 50239 5N0511115C https://www.ebay.co.uk/itm/334258323087?hash=item4dd3593e8f%3Ag%3AMjkAAOSwwrRhvJsv&LH_ItemCondition=1000 ...and don't forget to change the standard 70mm bump stop to 85mm 85mm front shock absorber bump stop for 15mm raised ride height 5Q0412303 As these springs are quite a bit firmer than standard, the 15mm extra ground clearance could be more like 30mm in use, as the suspension won't compress as much when driving over bumps in the road. Stick to the standard 205/55R16 tyre size for now. They are much cheaper than Scout sizes.
Octavia Lift Kit
The main point is that the aftermarket spring manufacturers (and Skoda) supply stiffer front springs for the DSG automatic gearbox than the manual gearbox. You can check that for Optimal, Sachs, Spidan, and Suplex on autodoc. As you can see in the links below, the standard ride height front springs for the manual gearbox have a wire thickness of 11.5mm, and for the DSG gearbox it's 11.75mm. Optimal https://www.autodoc.co.uk/car-parts/coil-springs-10213/skoda/octavia/octavia-combi-5e5/128420-1-5-tsi?supplier[0]=32&criteria[100][1]=VA Sachs https://www.autodoc.co.uk/car-parts/coil-springs-10213/skoda/octavia/octavia-combi-5e5/128420-1-5-tsi?supplier[0]=129&criteria[100][1]=VA Spidan https://www.autodoc.co.uk/car-parts/coil-springs-10213/skoda/octavia/octavia-combi-5e5/128420-1-5-tsi?supplier[0]=1&criteria[100][1]=VA Suplex https://www.autodoc.co.uk/car-parts/coil-springs-10213/skoda/octavia/octavia-combi-5e5/128420-1-5-tsi?supplier[0]=10708&criteria[100][1]=VA
VRS brake upgrade
The Octavia MK2 uses 5/112 hubs. The Audi TT MK1 uses 5/100 hubs. So the 334mm x 32mm 5/100 front brake discs won't fit. https://audi.7zap.com/en/rdw/audi+tt+tts+coupe+roadster/att/2006-278/6/615-615045/
Spacesaver for Yeti 4x4 17inch wheel
According to "skoda eshop cz" there are two spare wheel kits. The first Yeti spare wheel kit 5L0071108B is for: 4WD Yetis 2WD Yetis made until 22/2010. https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/5L0071108B The second Yeti spare wheel kit 5L0071108C is for: 2WD Yetis made after 22/2010. https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/5L0071108C You should be able to order these at any Skoda dealer using the OEM part numbers given in bold type. A Skoda dealer should also be able to confirm whether it fits your vehicle.
Octavia Lift Kit
Does your car have a manual or DSG automatic gearbox? The DSG automatic gearbox is significantly heavier than the manual gearbox. Therefore different front springs are used.
Octavia Lift Kit
These springs should be about right for an Octavia MK3 1.5 petrol 150HP estate with 2WD to give a 15mm raised ride height. Compare the specifications on autodoc with the standard ride height springs. Stiffer springs won't compress as much, so you need to add about 3mm to the uncompressed spring length for every 0.25mm increase in wire diameter thickness. So if a replacement spring that is 9mm longer when uncompressed and has a 0.75mm increase in wire diameter thickness, will give an increase in unladen ride height of about 15mm. Front springs with 15mm increase in ride height 5Q0411105HN https://www.autodoc.co.uk/car-parts/oem/5q0411105hn?search=OEN+5Q0411105HN Kilen 23132 5Q0411105HN https://www.ebay.co.uk/itm/353523621748?epid=249508912&hash=item524fa65f74%3Ag%3A0nAAAOSw-S1guy8P&LH_ItemCondition=3 Rear springs with 15mm increase in ride height 5Q0511121BG https://www.autodoc.co.uk/car-parts/oem/5q0511121bg?search=OEN+5Q0511121BG Kilen 63541 5Q0511121BG https://www.ebay.co.uk/itm/393537924846?epid=4050207744&hash=item5ba0b02eee:g:aeYAAOSwxwhhKnZH Rear springs with 15mm increase in ride height 5N0511115C https://www.autodoc.co.uk/car-parts/oem/5n0511115c? Kilen 50239 5N0511115C https://www.ebay.co.uk/itm/334258323087?hash=item4dd3593e8f%3Ag%3AMjkAAOSwwrRhvJsv&LH_ItemCondition=1000 5Q0511121BG has an 11.75mm wire diameter, and 5N0511115C has a 12.00mm wire diameter. This makes the 5N0511115C version about 5% stiffer than the 5Q0511121BG version. I would use the softer 5Q0511121BG version rear springs with an Octavia MK3 1.5 petrol 150HP estate with DSG automatic gearbox, and the harder 5N0511115C version rear springs with an Octavia MK3 1.5 petrol 150HP estate with manual gearbox. The ride height should increase by about 20mm on the DSG automatic gearbox car, and about 25mm on the manual gearbox car. As the springs are now about 10% to 15% stiffer the effective ride height should increase by about 50mm when fitted with the bigger outside diameter tyres, as the suspension compresses less, ie. 20mm/25mm + 18mm + 7mm-12mm = 50mm. The standard ride height front bump stops are 70mm thickness. These need to be changed to 85mm if fitting 15mm raised ride height springs. You can see the OEM part number on the Skoda online parts catalogue. 85mm front shock absorber bump stop for 15mm raised ride height 5Q0412303 3 5Q0 412 303 rubber stop for shock absorber 85MM 2 https://skoda.7zap.com/en/cz/octavia/oct/2016-753/4/411-411002/ The rear suspension with 15mm increased ride height uses the the same thickness stop buffer as the standard ride height rear suspension. So unlike the front stop buffer, no change is needed on the rear when changing from standard ride height to 15mm increased ride height. (9) 5Q0 511 357 F stop buffer 133MM 2 PR-UC7,1JA https://skoda.7zap.com/en/cz/octavia/oct/2016-753/5/511-511000/
