Everything posted by ruida_silva
Engine
I too recommend the 1.6tdi, not the most economical on the motorway imo but country roads etc I average 60-70 mpg most days motorway normally 55 mpg
Monte Carlo Headlights Retrofit
I’ll be sorting them out so everything works perfectly and then if I decide I don’t like them I’ll switch them back haha. I’ve not put the standard headlights and fogs for sale just yet
Thank you for that, I could try doing it myself but if I have all of these diagrams I could always ask someone to sort it for me. Need to sit down and look at the them properly before I begin any work
There is a very good thread on Team Bhp of someone who did this exact thing but their full beams didn’t work at all. I might have to have another look at their wiring diagrams and figure it out but thought someone else had a straight forward idea on how to make them work. What matters is that the shutters do work when the headlights are on thankfully
Yeah I got them purely for style, prefer the black background
True, would just be nice to have haha. I’ll have to figure it out at some point
It does yes, also, had the wife check and turns out both full beams work as long as the headlights are on, if they're just on sidelights/DRLs then I can't even flash them
Monte Carlo headlights high beam do not work
Old thread I know but I’ve just realised this myself and it turns out my full beams do work and flash but only if the headlights are on, it won’t work if it’s just on sidelights/DRLs. Do you know what was done? How much did Škoda charge to sort them? Thanks
Hi all, Retrofitted some Monte Carlo headlights on my Elegance model, I did have a search around before doing it but only downsides I found were light output was poor and nothing else. It wasn't until I fitted them that I thought to search about the full beams and came across a post saying they need to be wired differently (typical). Hopefully I made this title universal enough so that other people find it easily without having to think of trigger words such as "full beam monte carlo" ettc. Currently the driver's side headlight does work somehow and I can hear the shutter activating but the passanger's side headlight doesn't. Is this just a case of comparing both plugs and replicating it on the driver's side or do I have to do something else? Thanks
1.6 TDi Intercooler
Excuse me resurecting this old thread. How did you manage to fit it? Did you just take it to Darkside for them to do it? I'm picking one up at some point and was interested in doing it myself. Thanks
Lowering a MK2 Fabia
Thanks Damian, would I have to change anything else or is it just remove old, fit new kit and take it for alignment?
I've used the search bar but nothing quite answers my questions and concerns. I'm thinking of lowering my 1.6 TDI Elegance with 40mm KONI shocks and springs from DPM Performance. it's not a VRS or Monte so it's the highest ride height a fabia could be, however I do have the 17 inch Gigaros from the VRS on my car My questions are: - Is 40mm too much/too low when I've already got 17 inch wheels? - I've heard I may need to change drop links, top mount and bearing, is this right for a shock and spring kit? I've considered using 40mm lowering springs but my car is on 104k miles and they'll just ruin the current shocks so may as well get a whole proper kit. For the £400 budget, I won't be able to get decent coilovers hence why I picked the KONIs linked below https://www.dpmperformance.co.uk/car-parts/skoda/fabia/koni-40mm-strt-lowering-springs-shocks-suspension-kitfabia-5j-12tsi-14tdi-16tdi-19tdi-032007 Thanks
Changing Swing for RCD330
Hi all, Wondering how many of you changed their swing in their facelift fabia 2's for the RCD330/RCD330+. Is it an easy job or does it require adapters etc? I decided that using my xav-ax1000 from my previous car would be a lot of messing about so wanted to go for a more OEM look. I've only seen one thread on here that was a success where others had problems but they were all prefacelift. Is it a straight swap with the facelift models Thanks
