Changing Swing for RCD330
Hi all,
Wondering how many of you changed their swing in their facelift fabia 2's for the RCD330/RCD330+. Is it an easy job or does it require adapters etc?
I decided that using my xav-ax1000 from my previous car would be a lot of messing about so wanted to go for a more OEM look.
I've only seen one thread on here that was a success where others had problems but they were all prefacelift. Is it a straight swap with the facelift models
We swapped ours for an Amundsen+ RNS-315. They're around €350 on eBay. Almost plug and play, just a bit of cable routing work needed for the GPS antenna and microphone (for Bluetooth).
Super easy! Here is a video I made installing a RNS310 (older version of 315) but its exactly the same as a 330/330+
Shows you where to mount the GPS module too.
Edited by JGrindel
Thank you, I'll most likely be using Carplay most of the time but I might as well install that gps module too
Not sure if the 330+ actually uses one in hindsight.
either way its a really easy install.
Car play is great until you have no signal for waze.
  • 5 months later...
On 16/07/2020 at 06:17, ruida_silva said:
Hi all,
Hello
I have a Skoda Fabia 2013 Sportline and I changed the radio (Swing) to RCD330 Plus.. Works perfectly.. mm well, I just have a problem with the rear camera, because when I put reverse, the screen radio turns black.. I don't know how to fix that yet.
