Robdog10000
Finding my way
Everything posted by Robdog10000
  1. Thanks buddy! Fingers crossed for the airbag light 🤞 is dont see any reason for the light being on, apart from staying on due to the fault with the gateway module... so once reset, hopefully it will stay off 🤞
  2. Let's talk about self levelling headlight sensors.. My car has had a bulb warning light on since I bought the car.. all lights work as they should and when I plugged vagcom in a couple years ago, it said the levelling sensors weren't working properly... I had a quick look at the front sensor today, I unhooked the little arm from the ball joint and then the arm was just flapping around like it had zero resisitance inside the sensor... is the arm meant to have resistance to it, or should it feel like it isn't connected to anything? 🤔 I need to wait for my pal with vagcom (again) to come round and plug it in to figure out which sensor is actually broken...
  3. So, huge update here... ITS FIXED! I recieved the gateway module back this afternoon and put everything back as it should... started the car and everything seems to be working fine again! So it was definitely the gateway module that was knackered. The only lights on the dashboard now are the airbag light and the bulb warning light (i was expecting the bulb warning light as the levelling sensors are knackered) So all seems good now! Just need to try and reset the airbag light and sort the levelling sensors for the headlights, then get her booked in for MOT! HAPPY ROB 😁
  4. Both when you use auto scan and also select car from drop down box, it says function not supported by gateway... I've had vcds connected multiple times in the past without an issue
  5. So we've now removed the BCM and also the gateway module to check them for water ingress etc... The BCM looks brand new inside, absolute zero damage to the circuit board... Just had a look inside the gateway module and with my untrained eyes, i'm unsure if this looks correct or not (photo uploaded) It looks like there's some sort of residue on the silver part of the circuit board... 🤔 With VCDS not connecting to the car and the only message it is displaying is "function not supported by the gateway" we're fully expecting the gateway to be causing all the issues i've been experiencing (Google Gemini is pointing in that direction too, erratic lights on dash, central locking malfunctioning etc...) So i've just sourced another gateway module on ebay... brand new is £477 🤯🤯 And i'll get it cloned then see what happens then!
  6. Yes... multiple people have now looked at the car... 2x auto electrician's 1 self employed mechanic (specialist in JDM cars, rather than VAG) And 1 pal who is quite handy with VAG's All original data pointed towards cluster failure... replaced cluster and no different. Next is to check BCM tomorrow morning Tried keeping costs down to a minimum so far, so haven't booked it into a proper garage yet
  7. So another small update... my pal with VCDS finally came over today... we tried plugging the car in with the aftermarket head unit in and it didnt want to connect at all... disconnected the head unit, then VCDS tried to connect to the car... then it failed to connect... i've attached a photo of the message VCDS said. My other pal is going to come round tomorrow and have a deep dive on the car, he thinks it could be a faulty BCM. We still dont understand why we can't connect to the car though!
  8. Yeah, but could it not block communications between the diagnostic computer and the ECU? The mechanic that looked at it today has spoke to the auto electrician next to his garage today and he thinks it could be the canbus block that's playing up... its starting to get well above my head now!
  9. My dad has just been round, disconnected the battery to reset everything, the windows started working and they're now all closed 👌 car still wouldn't start though. I have a feeling there's a communications fault between the ECU and the cluster... i'm going to get it booked in with a VAG specialist and see if he can sort it. For now I will change the head unit back to the standard head unit and see if that makes any difference for the communications 👌
  10. A matter if fact, yes... I do have an aftermarket head unit... that could be the issue... i'll have to try that! Getting my pal back with his computer could be the next issue 😅
  11. So, I have an update... My pal came round today with his brand new snap on computer... he plugged it in try read the car... it connected to the cluster and it said there was zero codes... but it wouldn't connect to the ECU at all... tried 3 times and it wouldn't connect... so we're currently no closer to finding out what the problem is. I think the next step is definitely get the car booked into the auto electrician's and see what they can do with it. I have a feeling like there's a connection issue between the ECU and the cluster... In the mean time... while my pal was here, he put the drivers window all the way down... now it wont come back up again! None of the windows are working off the buttons on the door... when I hold the lock button on the key fob, the window wont come back up... yet, when you hold the unlock button, the other 3 windows come down... 🤯 so now, I'm currently stuck with the drivers window fully down and the other 3 windows 2inches down 🤦‍♂️ how on earth do I get the windows to close?!
  12. No update yet bud, I've been working today 😢 I'm hoping my pal comes round tomorrow with his snap on computer to see if it will read the cluster and see what its saying... fingers crossed 🤞
  13. Hi pal, yeah, both keys lock and unlock the car off of the fob... the key that I sent away to have the cluster cloned, was the key I used first try and the car started no problem... then a hour later, I tried with my other key and that's when the immobiliser kicked in... I definitely need a diagnostic computer to see if it will read the cluster now (originally the diagnostics wouldnt connect to the cluster, but would connect to the ECU and everything else... hence going the route of cluster cloning) If my pals snap on computer wont connect to the cluster still, I think its definitely needing booked into the auto electrician to see if he can figure it out... luckily, the mechanic I use is in the same yard as the auto electrician... so if he can't figure it out, he'll take it nextdoor
  14. Hopefully the jump pack might make the difference, but I think its highly unlikely... it definitely sounds like the immobiliser has activated and i'm unsure how to reset it (i've locked and unlocked the car a couple times and its exactly the same...) Thanks for your help, but I think its time the auto electrician gets a phonecall 😩 if i didnt like this car so much, i'd have scrapped it by now 😅😅
  15. Ahhh ok, i'm not massively clued up on car electrics, so i'm not totally sure what you mean... but i kinda get what you're saying... I've just spoke to my mechanic friend and he will come round this week to plug his snap-on computer and try and read what its doing... if he can't figure it out, it looks like i'll have to book it in with the auto electrician
  16. I dont have a spare battery at my house, but I do have an older battery at my dad's house which i may be able to try... i'm currently charging my jump pack to 100% and gonna try put it on the battery and see if it will start that way... i'll let you know how I get on
  17. Hmmmm, possibly... i'll have to phone them tomorrow and see what he has to say... the mileage etc all matches my old cluster, so surely he has cloned them? I should have used the same key to determine whether its the key that's caused the immobiliser to kick in 😩😩
  18. I wonder if i made a mistake...? So when I recieved the cluster back today, I tried it with the key (usually my spare key) that I sent away for JCcars to programme the cluster... when I originally tried it with that key, the engine started fine and ticked over no problem, but the cluster was still throwing loads of lights etc... When I decided to take it for a drive, I used my other key (normal key i use daily) and that's when the engine wont start... i just tried my spare key again and the engine is still cutting out (even though it started no problem with that key...) I've uploaded a photo of the lights on the dash...
  19. So I just went back out to the car now... thought i'd take it for a short drive to release the brakes etc... just went to start it... the engine starts up, then 2seconds later it cuts out again... Tried it 3 or 4 times and keep cutting out after 2 seconds 🤔🤔 would that be the immobiliser? Or would the immobiliser cause the starter motor to not work at all? 🤔🤔
  20. Hi pal, so the car has been sat for a couple of months and the battery had fully drained... so put it on charge last week and it was holding around 12.5V after charging it... i've had an auto electrician look at it previously and he thought it could be the battery... so he put a jump pack on the battery and started the car, with the same issues... Yeah, the car starts no problem, so i'm guessing its been coded correctly too... I dont have a multi meter to check if the alternator is working correctly, but all the issues the car has now, all started with the airbag light coming on and the doors constantly trying to unlock... I'm unsure on what to do next, other than get it booked into a garage, which will be £££££
  21. So a little update on whats going on... i just recieved my new cluster from being cloned by JCcars... I just plugged her into the car, connected battery up and started the car... exactly the same issues as before. Loads of beeping, lights flickering on the dash, doors trying to constantly unlock... I dont have a clue where to go from here now 😩😩
  22. Hello, I still haven't contacted JCcars to have the cluster cloned (waiting on payday 😩) I was just wondering, I purchased that cluster with the part number 1Z0920903R off Ebay... While my original part number is 1Z0920903F What exactly does the last letter correspond to? Do you think it will cause any issues when I finally get it sent off to JCcars? Thanks again, rob
  23. Awesome!! Thats the exact thing i was looking for! I'll go ahead and purchase that cluster from Ebay and I will contact JC cars for them to clone the cluster for me 👌 thank you very much! You're a legend 👌👌👌
  24. Awesome! Thank you very much for your help 👌👌 i will go ahead and purchase that cluster and then find a company which will be able to retrieve the codes for me 👌
