Everything posted by Kelly_Heroes
Battery light coming on and off
The noise just sounds the same and the belt was changed last year no slipping. Exciter wire is that the big thick black wire?
I will check this and have a look thanks What's the way to check this is good or bad? Thanks
This week my battery light started to come on and off. I have a brand new battery holding a good charge. The alternator charging at 14.5v which is all good. Just seeing what other things it could be? Skoda fabia 1.4 tdi. Thanks.
Skoda fabia engine fuel pipe or fuel inlet part leaking
I've also noticed a bit more power now so that very small leak makes a big difference.
I've fitted the new fuel pipe and the leak stopped now good news.
Does anybody know what this fuel inlet does? Does it have any seals or gaskets? I'm just asking this as I will be changing the rubber pipe but also in case it could be this part as well.
Thanks I've order some pipe fuel hose pipe on the way.
Hello I've noticed a small black fuel hose pipe getting damp. I've cleaned it up and it seems to be leaking from that small pipe. These pipes can you still buy them? The fuel inlet part do these leak at all much? Skoda fabia 1.4 tdi Thanks
Front driver seat belt fraying replacement needed
I'm looking for a front driver side seat belt due to it fraying and the material starting to come of on the edges. There don't seem to be many driver side front seat belts around for sale skoda fabia mk1. I had the same problem on my peugeot but managed to change that one.
- Uneven tire wear
Front brake backplate corrosion.
1 of my front plates started making a noise the next thing few of down the road. I went to have a look and it got flatten over a few times. The both sides are missing now but makes very little difference.
Battery sizes skoda fabia
What a amazing difference in starting the car now in cold and warm weather. The battery was worth it in the end plenty of power.
Aircon connector ball bearing filler
So can the connection be removed or cleaned? I'm only repairing it my self as the cost of paying to repair not worth it and the job easy to do.
There a further 5% discount using the code Salvage5 before the offer runs out. I used that to get my discount on a good price battery I'm collecting today.
I fixed the wires near the gearbox common fault and it fixed the windows and charging properly 12 months ago now. The battery on the way out so I'm going for this one now https://www.tayna.co.uk/car-batteries/exide/ea640/
Hello I've notice the aircon connector where you refill the ball bearing part with gas has small air bubbles coming out. So is there anything good I can use to clean the ball bearing filler? The next option can you detach the filler part from the metal pipe and are there any replacements? Thanks
Skoda fabia tyre size
Hello I've gone from the original steel wheels 13inch to alloy wheels 15inch now that came with 195 55 15 tyres. I'm thinking of getting 195 50 15 these should fit ok? Thanks
Skoda Fabia cigarette lighter socket wires
Thanks for the help all wired up and working now thanks
Cool Thanks for that. I just have a new socket with 2 connections so I can leave the smaller wire blanked of? Thanks
Hello I'm trying to sort out my Skoda Fabia cigarette lighter socket. It's faulty so the socket needs changing . I'm needing to know there 3 wires coming out just trying to work out what the 3 connect to - + and the 3rd. 3 Wires Large size There brown? Large Black and white? Smaller purple and white? Thanks
Electric windows not working
I fixed the window problem I must of forgot to post back on here. I checked the loom in front of the gearbox there was 1 or 2 wires broken frayed against the gearbox. So I cut the wires and re joined with a wiring block then insulation tape over it. I then had spare pipe insulation for copper pipes on a house. I cut a small piece of this and put it around the connection to keep it cover more and to stop it rubbing against the gear box. This fixed the window problems and it also solved the charging problem now charges at 14.5v it used to jump about before. It' been 5 months and the charging and windows work fine now. Thanks for the help all down to these small wires in front of the gearbox.
Skoda Octavia mk2 Vrs tdi pd 170
The octavia vrs cr do they all have the dsg gear boxes or some without? The dsg gearboxes are these better then the standard gearboxes and is there much difference? Thanks
The CR that engine a common rail diesel engine? Do the CR engines have dpf or add blue? I didn't know there was a CR common rail diesel rail version that's a big bonus to know that for sure. Thanks
The Skoda Octavia mk2 Vrs tdi pd 170 these engines reliable, easy to fix and service? What sort of mpg people getting with there cars? What things do you need to look out for on these cars problems wise? I still have my skoda fabia 1.4 tdi and peugeot 306 hdi. I'm looking for anther 3rd car something to maybe join these more refined sports upgrade diesel. Thanks
Octavia MkII rear fogs not working
Hello have you checked all the fuses to make sure none have blown.
