TheUltraRunner
Members-
Posts
1,179 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by TheUltraRunner
Push this stalk away from you and the total milage should appear in the bottom of your digital instrument cluster. The one in front of you, behind the wheel.
Hi, Do you have digital instrument cluster? If yes, you need to disable ACC by pushing ACC stalk away from you. By doing this, instead of ACC icon total milage will be displayed. ACC enabled ACC disabled
Wool / foam cover in the driver's footwell
TheUltraRunner replied to santr's topic in Skoda Octavia Mk IV (2020 > )
It's the same on my car. 1st owner. Doesn't look anything out of the ordinary to me. Regarding the OBD port, as far as I know it needs to be uncovered and easily accessible by the law. -
Exhaust replacement 2.0tsi VRS?
TheUltraRunner replied to DutchVRS's topic in Skoda Octavia Mk IV (2020 > )
@Aarond It's not custom. It's a DTH Exhaust, made in Germany. https://www.dth-turbo.de/ShopEC2/product_info.php?products_id=105 -
"Haldex" service on a front WD RS
TheUltraRunner replied to StuNZ's topic in Skoda Octavia Mk IV (2020 > )
Hi, This is exactly what they mean, yes. Would be much better if they use "differential" terminology than "Haldex". -
Start and stop disable permanently
TheUltraRunner replied to Dinho90's topic in Skoda Octavia Mk IV (2020 > )
This cable goes in between the original connectors under the plastic behind the handle for opening the hood? Correct? -
Finally installed! A TUV approved exhaust with active flaps. 😎 -
Manual vs automatic makes a ton of difference. With manual you have a lot more control over this function since the engine shuts down only when you have your gearbox in N and clutch is released. With auto, engine shuts down every time the car stops moving. Sometimes even a little bit before the car totally stops. -
I was told that the car should pass the inspection even without the OPF. At least here in Slovenia. I don't know how strict is the inspection in Estonia. Sprot cat should be fine. Race cat I doubt it.
@Mario_Delgado Found another one. This one makes a lot more sense since it also includes Drive Mode memory module. https://www.active-sound.eu/en/memory-module/drive-select-memory-modul-dsm-modul-mqb-evo-with-ssa-touchbutton -
I was told by my mechanic that even if the engine light comes on (because of opf delete), it's totally fine to drive the car. Sport cat vs race cat. Race cat is less restrictive than sport cat. Air intake + muffler delete + downpipe with OPF delete + complete exhaust, all these mods are stage 2 ready, which can give you between 350 and 380 KM. Depends on the tune and other factors. Of course for Stage 2 remap, a bigger intercooler is strongly recommended. Also oil change every 7500 to 10000 km is highly recommended.
Yeah I know. Would wish that they would make a stand alone module for only SS. And a bit cheaper. -
@Mario_Delgado There is another option. A bit more expensive. But it's made in Germany and not in China. Video is in German though. https://asr-component.de/de/597-octavia-iv-alle-modelle -
Sound deadening project
TheUltraRunner replied to Jorgeminator's topic in Skoda Octavia Mk IV (2020 > )
The crash clip was vibrating when listening to the radio. Even at mid volume. I think it didn't vibrate while only driving and not listening to any music. -
My dealer called in January to tell me there is a TPI available for my car for upgrading from 1788 to 1941. Told me the factory is trying to upgrade all the cars with version lower than 1896 to the latest so cars will be able to get major updates over OTA.
I have a 3 years and 3 months old TSI RS with DCC with around 50k miles and no issues with the dampers.
6.5x17" rim with 205/55 tire is the smallest approved tire for the mk4 TSI RS Octavia with 340mm brake discs. These are homologation approved dimensions from factory:
Hmmm are you sure? M1 etc is shown only when you are driving in manual mode. And it's the same in all driving modes. We all wish that. 😁
Octavia VRS Virtual Speedo numbering
TheUltraRunner replied to Canders's topic in Skoda Octavia Mk IV (2020 > )
Yeah, physical speedos are normally linear since (I guess) it's not that easy to make it move in different increments? But on digital speedos I guess anything is possible. -
Wiper Blades octavia phev vrs
TheUltraRunner replied to Col_m999's topic in Skoda Octavia Mk IV (2020 > )
I checked and on the box it says only Octavia Combi. -
I just measured the original front ones and the Bosch A102S and the lengths of the rubber blades are the same. -
I don't know that unfortunately. -
DCC or Electric Leather/Alcantara Seats on VRS?
TheUltraRunner replied to bdavbdav's topic in Skoda Octavia Mk IV (2020 > )
Sorry, I don't quite understand how the taxation works in the UK. But if I would need to choose between the DCC and the el. seats, I would probably choose the DCC. -
I bought these two for my estate Front: Bosch A102S Back: Bosch A331H
