Everything posted by candasm
Octavia 245 vs Superb 280 Engine Comparison
I have a stock 2016 Superb and I never see 40mpg average on my car. Also when I read reports from Stage 3 Octavia VRS owners even lower consumption numbers, I start thing maybe my car is having issues which it doesn't have any errors. where should I look how should I diagnose it? btw: Skoda service mostly says it is in good condition :/
Petrol leaks 280ps
I test it Today. It past the blow air test. I can't blow air through it.
Petrol leaks 280ps
I think I have same issue. I have this strong fuel smell at RR door all the time after I drive. I really didn't care for a long time but I start to get really low milage I think my good average since refuelling is around 18mpg(uk). My car is having around 147k km. I haven't change fuel pump/filter since I bought it was having 117k km. Today I tried to open fuel cap after I stop the car only for check the smell but I observe a fuel pressure there also while I was driving Today I start to hear noises around RR door. I think I might have same issue but again I didn't observe any fuel leak until now. Note: I never saw over 36mpg except highway with 100-90km/h driving.
Opened up Brake Ducts
I think 2 ducts are open only for Australia models. I didn't see on Europe models at all. So I am curious what is the function of the radiators exists behind the ducts?
Bilstein B6 DCC shock absorbers available at last
Hey @Carlston About shorter spring question I checked Eibach website, this is written for Eibach pro kit E10-79-012-04-22: Seems like it should be ok to use with B6 Damptronic. I also read on this blog post the same comment: https://drivetunemedia.com/bilstein-b6-vs-b8-what-is-the-difference/
Hey @Carlston, I am shopping 1st time for shock observers and I am new to this. I don't quite understand the difference but since there are a lot of good reviews about Bilstein monotube tech, I wanted to benefit from it. Yes, I have DCC. Front: 3Q0413031AK, VB0315, Monroe, E4658702 Rear: 3Q0512009AF, Monroe, EM213301 Monroe find my part website: Monroe RideSense Electric Suspension, Front: C2516S, Rear: C1521S Bilstein Product Catalog: B6 DampTronic, Front: 23-254343, Rear: 20-267537 I understand about this but if not going for B16 DampTronic coilovers, this is the option. Also I search on web there are a lot of application with eibach pro kit springs. I want to have nice stance looking as well. but of course without loosing so much comfort basically I don't want to feel my kidney rocks. As I understand drop between standard height and Bilstein B8 is much more than Eibach pro kit, Which I wouldn't want that much of drop.
I am curious how is the difference between monroe dcc and bilstein b6 ride comfort on normal or eco mode. What I want is to get rid of boat feeling but on the otherhand I don't want to loose too much from comfort. Should I go with monroe dcc + eibach pro kit or bilstein b6 + eibach pro kit will be plus in any case? I am driving with original 19" rims.
Bloody Drivers Seat Memory!
Actually obdeleven does the similar but with all the functions seat goes front and up till the end then goes back and bottom. So probably this should work manually as well. I think @j caff you should try what @numskull said. I have read in multiple forums seat memory somehow loses default memory then this thing happens.
My seat memory also stop working but I followed this guide with obdeleven and it started to work again 😊. steps: - go to: control unit driver seat(36) > basic settings > norming - option 1: all axes + start note: don’t sit on the chair while working 😅 source: https://www.vwvortex.com/threads/drivers-seat-lost-memory-function-fix-using-obdeleven.9480814/ I hope this will help.
Front view camera
Anyone achieve to make it work with MIB2?
Adding radio station logos on an Amundsen infotainment system
How did you achieve it? All the instructions through radio > settings > logo update etc. Basically If I will download radio logo pack from update skoda and add all the logos on empty sd card root directory, Can I use system update? Also as I understand these logos are not stored per country right?
Columbus Map Update 2022 (MIB1/2 HIGH)
This was my case. I tried to make sd card from a year and I gave up obviously in time(thanks to apple car play). But after reading SLA1 signature check made my day . Finally I am able to update navigation maps. How come I didn't think about it, I don't know. Hardware : - MIB2 Columbus - mbp 14" 2021 - SanDisk ultra 64gb microsdxc a1 10 Software: - disk utility - keka - CleanMyDrive2 Steps: - Download map files from skoda update portal. - Format sd card with ExFat - unzip map files with keka - copy/paste files on sd card root directory - clean sd card with CleanMyDrive - follow instructors given from skoda to update maps. Thank you guys.
Anyone retrofitted remote start car with OEM FOB?
I am also curious into remote start kit for my car. Did you install it?
Superb 2.0TSI 280 PS won't rev up over 2000RPM after turbo swapM
Wow are you tracking it? I thought you already sold it.
SportLine 2.0 TSI DSG terrible fuel soncumption (20mpg)
What is your secret? I never see those consumption figures with my 280.
Weird noise from a/c superb 3
@Danoid I have tried calibration and I can still hear the sounds.
Did you manage to solve it? I think I have a same sound on my Superb 3
Is this part important to fix?
Any news? I think I am having same issuee 😞
Rear arb / sway bar upgrade
I am also interested to replace my rear arb on my l&k. But I am missing some of information. improve body roll because of I like cornering. 1st - Why don't we replace it as a set with front arb? 2nd - Which thickness should I choose to not give up on comfort? Is there anyone did for their l&k? 3rd- What brand?
Glass roof cracked
Does it helps to avoid cracks? I was thinking to wrap it after change with a new one but only for avoid scratches.
Glass roof cracked
Salut @Andrei_Spataru, I have a same crack as @Redboy has. I have a same model from 2016. Did you bring it to Skoda service? I learn like it will cost somewhere around 3000 lei. But I am also thinking to use black silicon for a while to just avoid rain. Did you repair it?
smartlink doesn’t work but media player does
I have 2016 L&K with Columbus system. When I connect my Iphone 12 from rear usb, smartlink(carplay) doesn’t works but media player works and play songs. Also on the same port when I connect android phone, android car works with smartlink. Idk what is the issue with Iphone/carplay. I can’t see my phone on device list. *I restarted infortainment system. Nothing changed! Anyone encounter this issue?
Canton - noise cancellation
Do "noise cancellation" feature exists at 2016 L&K models as well? As I know there were no option "Acoustic windows" on 2016 for Superb L&K.
