Everything posted by LukeG99
- Vibration on motorway
- Title: Droning/Vibration After Driveshaft Replacement – DSG – Skoda (Need Advice)
I rang the garage and they tell me the coupling would of been replaced if they are doing a driveshaft so leads me to belive as I had already suspected to maybe be a transmission bearing or something else. My advice from the gearbox specialist was to just wait until there's more of an obvious noise but it really makes the otherwise relaxing experience of a superb more irritating.
Okay i see. So a few months back I replaced the driveshaft on both sides of the car, (mine is a fwd) with aftermarket shafts because the garage i used said they wouldn’t be much different to oem so could it be the case that I can replace the coupling assembly or would that have been done when I replaced a driveshaft because I dont remember anything mentioned about that?
Hi all, I’m looking for some advice or shared experiences. I’ve got a Skoda with a DSG automatic gearbox, and I recently have been getting a droning noise and noticeable vibration, especially: Under acceleration Around 2,000–2,500 RPM Stronger at 65-70 mph Through the steering wheel and cabin I took it to a gearbox specialist, and after a test drive and inspection on the ramp, they couldn’t find anything obviously wrong apart from a slightly worn dual-mass flywheel. While the car was running on the ramp, there was a very faint humming noise under the engine, but we couldn’t pinpoint the source. What I’m wondering: Could this be due to an aftermarket driveshaft? Could it be incorrect fitment or the driveshaft not seated properly? Has anyone else had a similar issue? It's one of those where you can feel vibration through the wheel as well as noise near the engine How likely is it that a transmission bearing would cause this kind of issue, especially if it began right after a driveshaft change? Is there any advice you could give me as to what the cause of this vibration and droning could be? I don't think stuff like tires and wheel bearings because I know that sound is different.
Window jammed
One of my windows did similar. The window just dropped one night and had to get a new window regulator.
Hi just wanted to provide an update on my superbs issue with steering vibration. I have discovered it to be a few things, first I have a bent wheel which balancing couldn't fix so need to get that repaired. I swapped that wheel to the rear. The main thing however was the driveshaft. I have had to replace the whole thing which has not been cheap even with aftermarket parts but now at 70 -75 mph all I can feel now is just the surface of the road and it's vastly improved!
Columbus head unit issues.
Fixed this issue now! I followed this tutorial: https://paulroberts69.wordpress.com/2015/10/01/upgrading-firmware-and-maps-on-vw-rns-510-satnav/ The link to updated software: https://drive.google.com/file/d/1sHpwduaniYoosbBgt3-4BmMy2LfvJpGG/view I basically burned the iso file from the second link on to a cd (you'll need some software to burn the file to the disc) then with the key out the ignition just pop the disc in and after waiting a bit it should show a message and instructions, it might be worth checking versions etc but tbh I couldn't actually find any other links for other software apart from this version.
No not yet, waiting to hear back from pab546 but will try updating with a disc I found in the car that I believe is a software update.
The Superb II & FL Picture thread
Hi this is my newly acquired superb, its been a bit of a project needing a few bits done but it feels good to drive despite age.
Hi all, just recently happened that my head unit for my skoda superb has started behaving weirdly, its stuck in German and when I try and change the language back it just freezes on loading the language, also the Bluetooth and radio has stopped working, any advice on a good replacement unit for this particular type of car that would work with all the features like parking sensors and steering wheel buttons etc?
Columbus head unit
Hello, do you still offer repairs? My columbus unit had recently developed some issues and could do with someone to fix it before I consider replacing the head unit for an aftermarket one.
SOLD: 2011 Skoda Superb Estate 3.6 v6 4x4 Elegance
This thing looks "superb" I'm very interested in this car, i've really been after a bigger skoda to my fabia and this looks so good. Is there any more information you could provide? Any work needed to be done to it like cam belt or any mot advisories??
Cold start issues
I just got a notification that it's 900 miles till an oil change which means a service could be a good idea so the air filter might be the problem'.ill check.
Cold start issues
What's this emissions thing?
Cold start issues
I've not looked at the airbox but I don't think that's the problem, it's fine 89000 miles and yes when it had a service.
Cold start issues
Yeah recent. It's the 1.6 TDI cayc engine.
Cold start issues
Hi guys, not been on the forum for a while but have got a bit of a concern with my fabia. When it's starting from cold the engine seems to judder a bit and the tachometer moves up and down a bit, any idea what it could be? Im guessing maybe injector or something to do with timing or something i really don't know.. VID_20220513145139.mp4
Droning noise from a rear wheel
Okay thanks, is the hub the drum or is that a different part? Do I change the hub and the drums?
The driverside rear wheel has vibration and the other side has nothing so I think there's the problem
I've jacked the car up and the wheel seems fine, the sidewall is the same on both sides and the actual tire doesn't seem to be out of shape, I tried moving the wheel also and nothing moved so I'm not sure what to do
I'll try those things thanks.
My mistake on the spelling lol. I did mean tyre and it's possible that's happened, I'll Jack it up and have a look. Drums and I'm not sure so might need that checking.
