Brian15
Everything posted by Brian15
  1. Part number is 05E 906 517 A But I can't for the life of me find the part anywhere
  2. Just discovered 'topping off' never heard the term before but something I'm guilty of and no idea it could cause an issue. Cars used for private hire so always filled it past the click without any idea it could cause issues
  3. I've missed the F off the end its P040F Quick Google came up with :
  4. Engine management light came on today, plugged my cheap code reader in and got P040 which is linked to a faulty EGR, would a fault on EGR valve result in the car spluttering in 2 cylinder mode ?
  5. Any idea how long it takes dvla to respond to untaxed car reports ?
  6. This all stems from a noise nuisance dispute we've got ongoing with them , dad and lad are proper knobs , last resort will be to report him for drug driving
  7. 2 of the vehicles are showing expired tax and been reported, but mot's are OK He's a young idiot pot head so doubt the insurance is right Done online chat with GMP so its now in their hands Also reported the pick up truck he uses as one of the tyres is dangerous , tread on the inside has completely gone showing the threads on the inside
  8. Thanks for the reply , askmid does say you can only check your own car, would this be an issue if I was to contact the police ?
  9. If a motor vehicle is in trade it doesn't have to be insured Is this applicable if the vehicle is kept on a public road ? Next door neighbour who i don't get on with has 3 on the street all of which according to askmid are uninsured
  10. It's booked in with 'vw specislist' on wednesday What kind of price range ish would you think I'd be looking at for either of the 2 possibilities you've mentioned ?
  11. Put them all back in now , they looked fine other than oil on plug 1
  12. Oil wasn't burnt , looked fresh
  13. Runs ok except when it goes into eco mode
  14. Changed them approx 3 months ago, car was running fine then , didn't notice anything wrong them , they were just dye a change
  15. Just checked spark plugs, quite a bit of oil on spark plug 1 , other 3 are fine. Is this consistent with engine misfire whilst in 2 cylinder mode ? Also noticed oil around the rim of air intake pipe when reconnecting it
  16. COD ? There's definitely vibration thats not previously been there
  17. Realised on way home today that the misfire/vibration occurs when engine goes into eco mode. This make it any easier to diagnose the actual issue ?
  18. The P0148 code could be one of a few things, would a vcds scan pinpoint more specificly what the problem is ?
  19. So after looking up code B103E1A and it recommending disconnecting negative terminal from battery for 10 mins , which I did and now get the following on starting the car
  20. Had it scanned for codes yesterday it came up with the below , are they likely to be the same issue Is fuel gauge sensor same thing as and just another name for pressure sensor?
  21. Am I missing something in the small print or is this a very good deal ? Is there any questions that need to be asked before going ahead with it ? I know it's ebay so not always the best place for these thing but guy has 100% positive feedback eBay UKVCDS DIAGNOSTIC SCAN SERVICE Fault Codes Read Coding STOC...VCDS Diagnostic Scan Service. Price is £20.00 for a basic vcds scan. VCDS Tweaks. Long Coding. We will provide you with detailed diagnostic report. New Battery Coding. MMI Coding. Module Coding.
  22. Got some pliers at have a go at giving it a wiggle to reseat as suggested, not a chance, ends of the clip i need to get in the pliers are on the blind side of the pipe with the other pipe in the way of getting the pliers in place
  23. It's losing some regularly and keeps being topped up due to leaky pipe, going to have a look today but will probably replace pipe and need to buy some anyway Not the most reliable source of information but after googling is g13 my safest bet for top up and refill ?
  24. My coolant needs topping up, had timing belt done few months back and had it drained and refilled , not a clue what coolant is in it. It's 69 plate 1.5 tsi Is there a particular coolant i should use which would mix OK with whatever is already in it or is complete drain and refill my only option?
