Everything posted by Radiogaga
Dual Mass Flywheel
Thanks for the replies, To Skoda2114 the sound mine made wasn't anywhere near like that!, strangely I started the car this morning, when the engine was cold and no noise at all! I'll keep an ear on it.
Dual Mass Flywheel
Thanks for the reply, this morning when the engine was running it was cold, I did some running around in the afternoon and when the engine is at temperature the noise stops, I'm going to leave it for now and see if it develops. Do you think it could still be the flywheel?.
Dual Mass Flywheel
Hi I was cleaning the brake calipers this morning, the engine was running and when I got to the front near side wheel I could hear a very slight rattle, I asked my partner to press the clutch pedal and when she did the noise went. you can only hear it when you are near the front wheel. My question is does the flywheel and clutch need doing immediately, it my have been doing it for weeks / months anyway. The car has only done 71 thousand miles I have never ridden the clutch, TBH it has really ruined my day!.
Octavia 2011 Tdi 1.6 non starting engine and chime sounds when opening drivers door.
- Octavia 2011 Tdi 1.6 non starting engine and chime sounds when opening drivers door.
Wow that's some journey you have been through!, please you have it running again.- Drivers side engine oil leak
Hi Bearing in mind mine is a different engine to yours, you should be able to get to it from the wheel arch, you may have to remove a splash panel to get to the pully, and the wheel, that's what I did.- Drivers side engine oil leak
Looks like it could be the oil seal on the crank shaft behind the bottom pully, mine was leaking not as bad as that but with similar effects.- 2008 radio/headunit
No there isn't a factory default code and don't try to guess the number as you may permanently lock out the head unit, I used to decode car stereos but I have retired now and don't have the equipment anymore. If I remember correctly the head unit came with it's own separate hand book the code may be in there.- 2008 radio/headunit
Here is a example, item number Ebay 304813076708- 2008 radio/headunit
Hi You will need the code, you may be able to do via the serial number, if you look on the internet via a big auction site you may get the code from there, quote the serial number pay a few quid and get the code.- Octavia 2 VRS 170 TDI PD - Fault code P2002
Hi No not a similar problem I was just telling joe10toes about the garage in Sheffield.- Octavia 2 VRS 170 TDI PD - Fault code P2002
Just found out they have moved premises to UNIT 5 WILLIAM HOUSE, DANNEMORA DRIVE, SHEFFIELD, S9 5DF.- Octavia 2 VRS 170 TDI PD - Fault code P2002
Hi I took my car to Tec nick autos in Sheffield, 110 Duchess Road, Deepcar S2 4BL they were very good diagnosed my problem quickly.- Rust on exhaust?
- Rev & Speedo LED replacements help for newbie
If you don't have any knowledge of soldering at all please don't try to do it yourself removing surface mount components is very difficult, I was in the electronics trade for 30 years and still got it wrong occasionally.- Bonnet catch sensor
Although you have cut it open have you checked the circuit board very carefully, mine went faulty and I cut it open and it looked perfect to the naked eye, but with a magnifying glass I could see a small leak from the battery and it had damaged the pcb.- Blower not working 2008 Octavia
Thank you for letting us know the solution, so many times people ask for help and never leave a message to say what the problem was.- Aftermarket head unit won't turn on...or off
On the Android units there is usually a reset button have a look on the front for a small hole that may say something like "rst", if not try disconnecting the unit from the power source to reset it see if that works.- Need help diagnosing faulty alarm
I bought a cheap one from China it did not work even cut it open and it was nothing like the original, do your self a favor buy OEM like I ended up doing and save time and money.- AGM Battery
I think you are right the strange thing is I never saw it said it was with cars that was only stop start! oh well past a few hours on, and I bought the OBDeleven but it should come in handy one day. one day. Thanks for your help.- AGM Battery
No, the car does not have an extra connection on the battery negative pole, it's not stop start, so is it only cars with stop start that have the option of changing the battery details? Thanks.- AGM Battery
Hi I tried to change the adaptation with VCDS but it would not let me it said information wasn't available, so I tried OBDeleven and it was the same there, after spending a long time on the internet I think I know the reason, the car might not have a battery control module as it is NOT stop start could I be right? Thank you.- AGM Battery
Thanks for the link I did do a search for AGM battery's but did not see that,- AGM Battery
Thank you if I can't do it, I'll see if I can find someone to help.- AGM Battery
Thank you for the reply yes, I did change it from an EFB battery I don't have VCDS but I have a friend that has VCDS is it easy to do? Thanks - Octavia 2011 Tdi 1.6 non starting engine and chime sounds when opening drivers door.
