VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: TMBBG7NE3K0145182 License Plate: PY19VEO
Mileage: 80087km-49763mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 20 42 44 4B 52 5F D6 D7
VIN: TMBBG7NE3K0145182 Mileage: 80087km-49763miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DGTE) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 HT HW: 04L 907 445 G
Component: R4 1.6l TDI H01 6591
Revision: 22102001
Coding: 01254832432501090000
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ECM16TDI03004L906056HT 004006
ROD: EV_ECM16TDI03004L906056HT_AU37.rod
VCID: 06546A76B8A4B27A357-8052
VINID: 91D4925C77950DB001105048084C90878B
1 Fault Found:
23913 - Particulate Trap Bank 1
P2002 00 [100] - Efficiency Below Threshold
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 79562 km
Date: 2023.05.01
Time: 08:15:37
Engine RPM: 1413.00 /min
Normed load value: 0.0 %
Vehicle speed: 74 km/h
Coolant temperature: 88 °C
Intake air temperature: 29 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.679 V
Unlearning counter according OBD: 40
Exhaust mass flow of low-pressure EGR: calculated: 57.6 kg/h
Differential pressure ratio: low-pressure EGR: 1.678
Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 35.1 mbar
Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 36.7 mbar
Exh.recircul.valve 1 bank 1: pos.feedback - Actual value: 99.25 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Actual value: 100.00 %
Exhaust recircul.2: different.press.sens.1 bank 1: dyn. offset: 2.5 mbar
Readiness: N/A
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 043 E HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1603
Revision: 00005008 Serial number: CU501901266503 CVN: A8376DEB
Coding: 0014
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW26.rod
VCID: 392ED18AB9DA0D82085-806C
No fault code found.
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 ED HW: 5Q0 614 517 BM
Component: ESC H45 0107
Revision: 00000000 Serial number: 60269000002168
Coding: 24078A91102409714078060860C5242451089002600624723041F070D0024B0B0000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 77AA17B2CF4EDBF23E1-8022
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5E0 907 044 AQ HW: 5E0 907 044 AQ
Component: Climatronic H04 2002
Revision: 00001K00
Coding: 0111010400211001100500480010102A
ASAM Dataset: EV_ACClimaBHBVW37X 006147
ROD: EV_ACClimaBHBVW37X_006_SK37.rod
VCID: 74B020BEDE38B0EA1B3-8020
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001903101082 Dataset Number: V03935287LZ 0001
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 7CA0089EF668F8AA533-8028
Wiper motor control module:
Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 181223 051 0916
Serial number: 887253F0401835702353
Coding: 1E4DFD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SAY19M02D04H20M46S19
Coding: 00885D
Anti-theft alarm system sensor:
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY182843M84
Alarm horn:
Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Component: Sirene, DWA 005 0314
Serial number: 00002856223982650587
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 B HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000017121808491061
1 Fault Found:
262912 - Sensor for Anti-Theft Alarm System
B1330 F5 [008] - Alert Emergency Activation Stage 1
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 151
Mileage: 79539 km
Date: 2023.04.30
Time: 21:38:13
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 13.0 V
Outside temperature: 14.0 °C
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419619031 Dataset Number: V03935274DU 0001
Coding: 0601050011
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: EV_EPHVA14AU3700000_009_AU37.rod
VCID: 4ACC9E46EC3C961A91F-801E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Dataset Number: V03935269HY 0001
Coding: 3300608141FFC728949C810500400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D0B07ECE18406A6B3-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2P0HMN42 Dataset Number: V03935283UZ 0001
Coding: 98CCC000000000005C5400CC008800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0B425B42A3C6CF126A9-805E
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 001 801 19
Component: SideSensor_Df 008 0887
Serial number: 357000000002130D3835
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 454 002 301 19
Component: SideSensor_Pf 008 0887
Serial number: 358000000005146C973K
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 454 802 401 19
Component: SideSensor_Dr 301 0148
Serial number: 351001E437D17000000G
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 454 801 601 19
Component: SideSensor_Pr 301 0148
Serial number: 3520022708C170000006
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 454 801 912 18
Component: FrontSensor_D 304 0149
Serial number: 35500C879EF16000000%
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5E0 920 951 G HW: 5E0 920 951 G
Component: KOMBI 312 2700
Coding: 27A502082980860001886B011001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2B02FBC24386AF128A9-807E
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4367
Revision: -------- Serial number: 0009102873 Dataset Number: V03935289UD 0001
Coding: 030100045F087300EB00024A1C0F00010001070000000000000000000000
Shop #: WSC 31000 790 00234
GVL: 01463C0000000100400C80000000C80000000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_VW37.rod
VCID: 6E8432D6B0149A3AED7-803A
Generator:
Component: 0-00-00-00-00
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E
Component: E221__MFL-PR6 H03 0170
Serial number: 000000000C2724210119
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 7588600300190124245B
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 57A 857 511 HW: 3G0 857 511 G
Component: FLA H10 0010
Revision: AA001001
Coding: 0404010700000100000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 688844CE92F0440AA7B-803C
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000363487848 Dataset Number: V03935292LE 0001
Coding: 00110020D001020000001100
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
VCID: 48C8A44EF230640A87B-801C
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000026970765
Coding: 1D0200
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1082
Dataset Number: V03935289WB 0001
Coding: 81170000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 31011910522458 Dataset Number: V03935283ZQ 0001
Coding: 000000070900046600003D01010000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: 3536DDBA95C2E9E2ECD-8060
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000361633478 Dataset Number: V03935292LG 0001
Coding: 00110020DC01020000001100
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
VCID: 47CAA772FF2E6B728E1-8012
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000026917811
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 C HW: 5Q0 035 874 C
Component: MU-S-ND-ER H41 0480
Serial number: SKZAZ2W0253750 Dataset Number: V03935311CB 0001
Coding: 03730101FF00000041111201008800002F0208C601200500CF
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 3430E0BE9EB8F0EADB3-8060
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5E0 919 605 M HW: 5E0 919 605 M
Component: ABT_Std-2_Nav H52 8130
Serial number: SKZ6ZHW0340171
Data carrier:
Subsystem 2 - Part No SW: V03 959 809 G HW: -----------
Component: ECE1 2022/23 --- 1810
Serial number: --------------------
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7EA40296E074EABA7D7-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
End----------(Elapsed Time: 01:29, VBatt start/end: 12.4V/12.3V)-----------
