Aakayamy
Everything posted by Aakayamy
  1. If your getting cp protection coming up then you will still need someone with Odis to recheck and possibly reprogram the bcm unit again. Wher did you guy the replacement bcm unit from?
  2. When you got your bcm installed did you get a matching bcm unit? And once you get a bcm unit replaced you need someone With Odis to reprogram it.
  3. Hi everyone. Need some help. I’ve searched the forum and kind of have some answers I’m looking for but need some additional information. I’ve got VCDS & ODB11. I’m looking for part number for this coolant pump charge pressure cooler. Skoda weren’t helpful when I rang them to order the part as they said they need a part number. I’ve had my mechanic check the wiring and they seem to be good. Only problem is I never asked him for the part number when the car was on the ramp. Any help would be appreciated
  4. Do you get squeaks on 1st, 3rd, 5th, reverse gears? If Yes you may need to get the clutch pack replaced. I had this issue nearly two years ago
  5. I’d have helped you with vcds as I have my own cable but I’m based in Glasgow.
  6. My guy used Odis. Do you have vcds? If yes you can get your bcm part number from there. If no then you will need someone with vcds or maybe odb11 and get you the part number so you can buy on eBay. Once you have that you will need to find an independent VW/skoda/audi/seat specialist who can install the new bcm unit and program this. by any chance has your stereo and speedometer lights gone dim? Also your interior lights won’t work?
  7. I found a specialist in Glasgow. I bought a 2nd hand BCM with same part number off eBay for £40 and Took it to a specialist who charged me £280 for installing it and programming it. so total was £320. Skoda quoted me £1000. where is it you stay?
  8. Hi guys I have a Skoda Octavia mk3 2019 1.6 diesel DSG. I am trying to activate cornering lights to come on and followed the instructions and changed the first two adaptions. I still can’t get cornering lights to work. I did have cornering lights activated two years ago but I recently had a replacement BCM UNIT installed and updated by a specialist and got component protection removed. Since I’ve not got the cornering lights activated anymore and really would like to have this on my car again. any help would be much appreciated.
  9. Hi can anyone tell me if I’m on latest firmware or if anything newer is available please thanks
  10. Hi is there any new updates than this current one I have if anyone can help. Thanks
  11. My older brother said he hasn’t had any further issues on the car since I removed the red wire and put the fuse back in as normal. Strange thing is that the red wire as showing in the picture above was also joined to the glovebox interior lights switch wire. I removed it completely from the switch so the fuse. that stopped the car from showing and beeping the check starter service message and ESC message.
  12. I’ve managed to remove that red wire. Glovebox and all other interior lights were still working so just put the fuse back in and cleared all codes on vcds. Check starter service/beeps and ESC message no longer flash on the speedometer.
  13. According to Skoda fuse box diagram it’s connected to fuse 34 I’ve also noticed car speedometer also flashes up saying Electronic Stability Control If i pull that fuse out I hope that wont blow the bcm unit as i had that issue on my own Skoda Octavia with interior lights and radio/speedometer going dim.
  14. So I’ve inspected and followed the red wire and I’ve noticed the glovebox light switch has a black wire connecting to the red and that’s what is connected to the 7.5 fuse.
  15. My question is what is that 7.5 fuse used for on the car?
  16. Well I inspected that red wire and it’s connected to a black wire with tape around it and as far as I can follow the black wire it goes above somewhere on top of that section at the top of the glove apartment. I didn’t want to remove that wire in case that causes any issues with the bcm unit.
  17. Hi guys my older brother has recently bought a Skoda Octavia 2019 1.6tdi DSG Automatic from someone private. Everytime you unlock the car on the speedometer it says check starter service and it beeps. Same thing after switching car off he gets same message and beeps. I’ve checked using vcds and no fault codes appear. I’ve inspected the glove box and noticed a red wire in between a red 7.5 fuse. Not sure if that is the culprit. Any ideas?
  18. 2nd hand BCM plus installing and programming in cost me no more than £300 from an independent specialist Skoda wanted £1000 Inc vat.
  19. No I never leave anything plugged in to on port. I got a replacement 2nd hand BCM Unit from online and got an independent garage to change this for me today and also update via Skoda servers. All working good now.
  20. Would you recommend that I change the boot switch and lock mechanism? And then try vcds to clear the component protection?
  21. Boot handle still works as normal. No I never changed the head unit or anything else on the car. Problem only started with the drips of screen wash in the rear wiper motor.
  22. Everything was working fine and issue started when my speedometer started flashing and beeping saying boot is open. Once I inspected the boot I noticed few drops of screen wash fluid on the boot lock mechanism wiring. That’s when the interior lights all went off and radio and speedometer lights went very dim. I got a new rear wiper motor installed in and used contact cleaner on the wiring for the boot lock mechanism. That never helped too. Spoke to Skoda and few other independent specialists who all say bcm unit has failed.
  23. I’ve disconnected the battery but still the same. I’ve managed to find a guy who has access to the servers. I would imagine he has Odis. I’ll report back next week with an update as that’s the earliest he can book me in. I appreciate your help.
  24. Anyone care to have a look at my vcds scan please and share any thoughts.
  25. On the boot lock wiring it there was only a few drops of washer fluid on it but enough to get the boot lock wiring connection wet. here is my vcds scan Tuesday,10,December,2024,18:37:20:14836 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4 Data version: 20240715 DS356.3 www.Ross-Tech.com VIN: TMBBG7NE3K0145182 License Plate: 101224 Mileage: 155814km-96818mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: NE-SK37 (3Q0) Scan: 01 02 03 08 09 10 13 15 17 19 20 42 44 4B 52 5F D6 D7 VIN: TMBBG7NE3K0145182 Mileage: 155814km-96818miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 20-High Beam Assist. -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 4B-Multifunc. Module -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 D6-Light Ctrl Left 2 -- Status: OK 0000 D7-Light Ctrl Right 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-DGTE) Labels:. 04L-907-309-V1.clb Part No SW: 04L 906 056 HT HW: 04L 907 445 G Component: R4 1.6l TDI H01 6591 Revision: 22102001 Coding: 01254832432501090000 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_ECM16TDI03004L906056HT 004006 ROD: EV_ECM16TDI03004L906056HT.rod VCID: 06546A76B8A4B27A65F-8052 VINID: 91D4925C77950DB001105048084C90878B No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb Part No SW: 0CW 300 043 E HW: 0AM 927 769 E Component: GSG DQ200G2_M H05 1603 Revision: 00005008 Serial number: CU501901266503 CVN: A8376DEB Coding: 0014 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_TCMDQ200021 001001 ROD: EV_TCMDQ200021.rod VCID: 392ED18AB9DA0D8258D-806C No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: None Part No SW: 5Q0 614 517 ED HW: 5Q0 614 517 BM Component: ESC H45 0107 Revision: 00000000 Serial number: 60269000002168 Coding: 24078A91102409714078060860C5242451089002600624723041F070D0024B0B0000000012121212B835351919323200 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007 ROD: EV_Brake1UDSContiMK100IPB_038_AU37.rod VCID: 77AA17B2CF4EDBF26E9-8022 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5E0 907 044 AQ HW: 5E0 907 044 AQ Component: Climatronic H04 2002 Revision: 00001K00 Coding: 0111010400211001100500480010102A Shop #: WSC 73430 031 00063 ASAM Dataset: EV_ACClimaBHBVW37X 006147 ROD: EV_ACClimaBHBVW37X_006_VW37.rod VCID: 74B020BEDE38B0EA4BB-8020 Fresh air blower control module (front): A/C pressure/coolant temperature sensor: Air quality sensor: 2 Faults Found: 65544 - Button(s) or Switch(es) in Operating Device B1312 07 [00001001] - Mechanical Failure Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 215 Mileage: 155272 km Date: 2024.12.07 Time: 15:41:04 Voltage terminal 30: 14.0 V Outside temperature: 9.0 °C Pressing a button-Defrost: Not operated Pressing a button-Recirculating air: Not operated Pressing a button-Rear window defogger: Not operated Pressing a button-AC: Not operated Pressing a button-Left heated seat: Not operated Pressing a button-Right heated seat: Not operated Pressing a button-OFF: Not operated Pressing a button-Parking heater: Not operated Pressing a button-AUTO: Not operated Pressing a button-SYNC: Not operated Pressing a button-Menu: operated Pressing a button-Footwell air distribution: Not operated Pressing a button-Upper body vent air distribution: Not operated Pressing a button-Air distribution up: Not operated Pressing a button-AC MAX: Not operated 1048835 - Functionality limited due to Engine Control Module P1719 00 [00001000] - - [PTC-Reduzierung durch MSG] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 3 Reset counter: 4 Mileage: 155790 km Date: 2024.12.10 Time: 09:39:43 Voltage terminal 30: 14.0 V Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3 Auxiliary heater: in stages-Act.val.: 0 Auxiliary heater: in stages-Target value: 3 Auxiliary heater: in stages-Specified value for control: 3 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF Component: BCM MQBAB M+ H38 0273 Serial number: 00001903101082 Dataset Number: V03935287LZ 0001 Coding: 000000000000000000000000000000000000000000000000000000000000 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_BCMMQB 019001 ROD: EV_BCMBOSCH_019_VW37.rod VCID: 7CA0089EF668F8AA03B-8028 Wiper motor control module: Subsystem 1 - Part No SW: 5E2 955 119 A HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB Component: WWS371 181223 051 0916 Serial number: 887253F0401835702353 Coding: 1E4DFD Rain/Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB Component: RLHS 052 0107 Serial number: SAY19M02D04H20M46S19 Coding: 00885D Anti-theft alarm system sensor: Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171 Component: Sensor, DWA 005 0316 Serial number: 000000000ZY182843M84 Alarm horn: Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605 Component: Sirene, DWA 005 0314 Serial number: 00002856223982650587 Steering Column Switch: Subsystem 5 - Part No SW: 5Q1 953 507 B HW: 5Q1 953 549 Component: J527 SMLS MQB 004 0060 Serial number: 00000017121808491061 2 Faults Found: 262912 - Sensor for Anti-Theft Alarm System B1330 F5 [00001000] - Alert Emergency Activation Stage 1 Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 10 Reset counter: 2 Mileage: 155272 km Date: 2024.12.07 Time: 15:45:54 Terminal 15 status: OFF Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: Not operated Position lamps: Not operated Automatic high beam assist: operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: no cause for fault protection Voltage: 13.2 V Outside temperature: 9.5 °C 15360512 - Component Protection U1101 00 [00001001] - Active Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 215 Mileage: 155272 km Date: 2024.12.07 Time: 15:41:04 Terminal 15 status: On Terminal 50 status: OFF CAN-Bus_aktiv: On Status Bremslichtschalter (HW): OFF Status Bremslichtschalter (CAN): OFF OFF: Not operated Position lamps: Not operated Automatic high beam assist: operated Low beam: Not operated Parking light left: Not operated Parking light right: Not operated last_wakeup: Pin A54 Klemme S Voltage: 14.4 V Outside temperature: 9.0 °C ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb Part No SW: 5QA 919 283 C HW: 5QA 919 283 Component: PDC 4 KanalH07 0050 Serial number: 000308419619031 Dataset Number: V03935274DU 0001 Coding: 0601050011 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_EPHVA14AU3700000 009037 ROD: EV_EPHVA14AU3700000_009_SK37.rod VCID: 4ACC9E46EC3C961AC17-801E No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A Component: ACC BOSCH MQB H11 0682 Dataset Number: V03935269HY 0001 Coding: 3300608141FFC728949C810500400600000000000000000004 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_ACCBOSCHVW416 002008 ROD: EV_ACCBOSCHVW416_002_VW37.rod VCID: 44D0B07ECE18406A3BB-8010 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM Component: Airbag VW21 006 0720 Revision: -------- Serial number: 003Z2P0HMN42 Dataset Number: V03935283UZ 0001 Coding: 98CCC000000000005C5400CC008800000065 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_AirbaVW21TS6VW48X 001014 ROD: EV_AirbaVW21TS6VW48X_VW37.rod VCID: 0B425B42A3C6CF123A1-805E Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 454 001 801 19 Component: SideSensor_Df 008 0887 Serial number: 357000000002130D3835 Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 454 002 301 19 Component: SideSensor_Pf 008 0887 Serial number: 358000000005146C973K Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 454 802 401 19 Component: SideSensor_Dr 301 0148 Serial number: 351001E437D17000000G Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 454 801 601 19 Component: SideSensor_Pr 301 0148 Serial number: 3520022708C170000006 Coding: 2D2D2D Crash sensor for front airbag: driver side: Subsystem 5 - Part No SW: ----------- HW: 454 801 912 18 Component: FrontSensor_D 304 0149 Serial number: 35500C879EF16000000% Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 5E0 920 951 G HW: 5E0 920 951 G Component: KOMBI 312 2700 Coding: 27A502082980860001886B011001000080000000 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_DashBoardVDDMQBAB 009068 ROD: EV_DashBoardVDDMQBAB_009_VW26.rod VCID: 2B02FBC24386AF12DA1-807E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C Component: GW MQB High 442 4367 Revision: -------- Serial number: 0009102873 Dataset Number: V03935289UD 0001 Coding: 030100045F087300EB00024A1C0F00010001070000000000000000000000 Shop #: WSC 31000 790 00234 GVL: 01463C0000000100400C80000000C80000000000000200000000000000000000 ASAM Dataset: EV_GatewNF 013025 ROD: EV_GatewNF_VW37.rod VCID: 6E8432D6B0149A3ABDF-803A Generator: Component: 0-00-00-00-00 Multifunction steering wheel control module: Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E Component: E221__MFL-PR6 H03 0170 Serial number: 000000000C2724210119 Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J Component: J367-BDMConti H03 1051 Serial number: 7588600300190124245B 1 Fault Found: 15360512 - Component Protection U1101 00 [00001001] - Active Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 23 Reset counter: 218 Mileage: 155272 km Date: 2024.12.07 Time: 15:41:04 Terminal 30 power supply: 14.1 V Terminal 15: On ------------------------------------------------------------------------------- Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb Part No SW: 57A 857 511 HW: 3G0 857 511 G Component: FLA H10 0010 Revision: AA001001 Coding: 0404010700000100000000 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_HighBeamAssisAU33X 001019 ROD: EV_HighBeamAssisAU33X_VW37.rod VCID: 688844CE92F0440AF73-803C No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F Component: TSG FS 006 0246 Serial number: 0000363487848 Dataset Number: V03935292LE 0001 Coding: 00110020D001020000001100 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005 ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod VCID: 48C8A44EF230640AD73-801C Rear Driver Side Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_DRV 006 0007 Serial number: 00000000000026970765 Coding: 1D0200 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA Component: EPS_MQB_ZFLS 131 1082 Dataset Number: V03935289WB 0001 Coding: 81170000 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_SteerAssisMQB 015157 ROD: EV_SteerAssisMQB_015.rod VCID: 74B020BEDE38B0EA4BB-8020 No fault code found. ------------------------------------------------------------------------------- Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C Component: FCM MQB Low 002 0345 Serial number: 31011910522458 Dataset Number: V03935283ZQ 0001 Coding: 000000070900046600003D01010000000000000000000000000000000000 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_MultiModulContiVW48X 002006 ROD: EV_MultiModulContiVW48X_002_VW41.rod VCID: 3536DDBA95C2E9E2BC5-8060 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F Component: TSG BFS 006 0246 Serial number: 0000361633478 Dataset Number: V03935292LG 0001 Coding: 00110020DC01020000001100 Shop #: WSC 73430 790 00063 ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005 ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod VCID: 47CAA772FF2E6B72DE9-8012 Rear Passenger Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_PSG 006 0007 Serial number: 00000000000026917811 Coding: 050200 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb Part No SW: 5Q0 035 874 C HW: 5Q0 035 874 C Component: MU-S-ND-ER H41 0480 Serial number: SKZAZ2W0253750 Dataset Number: V03935311CB 0001 Coding: 03730101FF00000041111201008800002F0208C601200500CF Shop #: WSC 131071 1023 2097151 ASAM Dataset: EV_MUStd4CTSAT 001022 ROD: EV_MUStd4CTSAT_VW26.rod VCID: 3430E0BE9EB8F0EA8BB-8060 Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5E0 919 605 M HW: 5E0 919 605 M Component: ABT_Std-2_Nav H52 8130 Serial number: SKZ6ZHW0340171 Data carrier: Subsystem 2 - Part No SW: V03 959 809 G HW: ----------- Component: ECE1 2022/23 --- 1810 Serial number: -------------------- No fault code found. ------------------------------------------------------------------------------- Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A Component: LED1L H06 0005 ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003 ROD: EV_LED_PLUS_L_KEBODAVW416.rod VCID: 7EA40296E074EABA2DF-802A No fault code found. ------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A Component: LED1R H06 0005 ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003 ROD: EV_LEDPLUSRightKEBODVW416.rod VCID: 7EA40296E074EABA2DF-802A No fault code found. End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.1V)-----------
