Joller79DK
Finding my way
Everything posted by Joller79DK
  1. took it apart today, cleaned it out, no switched in, but copper conductive pcb, with counterparts imbedded in some rubber membrane... brushed them over with a pensil eraser, working fine now, still a little wobly,,,and i know , it is a 5 pound part...just wanted to see it on the inside https://www.aliexpress.com/item/1005009964032028.html?spm=a2g0o.productlist.main.1.72aa37068cDFyU&algo_pvid=07f1f3ec-42b7-498a-867e-d188450ac522&algo_exp_id=07f1f3ec-42b7-498a-867e-d188450ac522-0&pdp_ext_f=%7B%22order%22%3A%229%22%2C%22eval%22%3A%221%22%2C%22fromPage%22%3A%22search%22%7D&pdp_npi=6%40dis%21DKK%21111.36%2133.41%21%21%21116.63%2134.99%21%40211b615317729972738375347e5b36%2112000050704102711%21sea%21DK%212171966432%21X%211%210%21n_tag%3A-29919%3Bd%3A99ac881e%3Bm03_new_user%3A-29895&curPageLogUid=FDxzVdmN91Jk&utparam-url=scene%3Asearch%7Cquery_from%3A%7Cx_object_id%3A1005009964032028%7C_p_origin_prod%3A but thx everyone for replying in my post
  2. Vi. Yes here in Denmark. And i guess other countries aswell. The first model year of the rapid. And the seat version got cheaped out and only got a 2 button driver side switch. It is the switch. It is getting wobbly. And I have to hold in. Certaoway to activate. All other is good
  3. well, title says most.. my 2013 driver side window switch is starting to mess up, hard to roll up, so better replace the switch... my car has 4 power windows, but the driver door only has 2 buttons to control the front doors... is it possible to buy the 4 button version(and facia to mount in) or is it not controled via can network, so i have to get a similar 2 swith one? TIA
  4. Well. Radio received yesterday. Fitment is 100%. Quality. Ok ISH. Manual buttons feel fine. But not the same soft feel like oem. Gps antenne has to mounted with sky above it. Other units i have seen can be with antenna under dash. With 2 gb ram the start up of apps, can be a bit slow. But hey i am a kid that lived with 33.6 modems... Build in radio tuner can be set up to give power to the antenna, so the fakra antenna of the car gets power. But still it has noise in some places, so will try to get a seperate booster. Or just use the android auto. And radio apps. Android Auto auto connect with bluetooth, and delivers great sound, not the low muffled like other units. It can play LOUD. So all in all, I believe the. Heap units has come a long way in the last couple of years.. so for the money. Fine. If the AliExpress Ones are the same, then go for them for half the price. Screen looks fine, have to try in bright sun to check. I might get some matte screen protector to minimize glare, and protect the screen. Power connection to the radio was easy, had to disconnect one 2pin to get it to turn of. After selection of my 2013 rapid. The can works great. Showing doors open, and in the car info. Showing odometer. Coolant temp. And so on.
  5. I just found loads and loads of YT videos with a hidden factory menu in many off these Chinese radios. Where you can select car and can protocol. And loads of other settings. The can part is nice when door opens. Lights on and so on. But if i can't sort it out. I just hardwire to fusebox. If the sound is acceptable Feeling like a child before Xmas.
  6. I have read that some people have issues with the device not turning off. Although they have the canbus decoder. Any ideas on that front?
  7. Oghhh those are cheap. And some have DAB. I keep them in mind. Just i think Ali is hard to make refunds and so on. Temu is more easy in that front.
  8. Rhx for feedback. Yours is a bit more on the costly side. Well i give the temu one a go. Like the oem look and hopefully fitment. And get back to you.
  9. Hi everybody. whats is your experiences with the cheap android radios out there, some reviews says they are ok, some says they are crap, so whivh to choose? i found this on Temu. https://www.temu.com/dk/til-vw-7-tommer-android-13-bilstereo-gps-bilnavigation-wifi-touchscreen-bilradio-med-trådløs-telefon-wifi-mirror-link-fm-rds-radio-g-601099527836359.html?_oak_mp_inf=EMel056m1ogBGiA2Y2I1YzczNzAxMDg0N2JkOWM2ZmFjNDdlNTU5NTM3NCDHo%2FjEjTI%3D&top_gallery_url=https%3A%2F%2Fimg.kwcdn.com%2Fproduct%2Ffancy%2Fcf4fafed-a5e3-4cc2-b104-7458a7c7075d.jpg&spec_gallery_id=4041431192&refer_page_sn=10009&refer_source=0&freesia_scene=2&_oak_freesia_scene=2&_oak_rec_ext_1=NTcxMTk&_oak_gallery_order=1523201912%2C1231758996%2C1017322244%2C513538914%2C1620274288&search_key=Skoda android uto&refer_page_el_sn=200049&_x_sessn_id=n56bakvn22&refer_page_name=search_result&refer_page_id=10009_1721621157974_gqze8234bt and will give it a go, i havethe 2013 rapid withthe blues radio, so i will loose the compartmentunder the radio. i will leave feedback here when it has been installed..
  10. mine creaked every winter, when high humidity.. fixed it last week, took the bushes of, cleaned them an the torsen arm, and their mounting points... then put some bearing grease on them, and now, no creaking..
  11. hi, did you find the solution, i have a similar issue, but the water is not getting in the tailgate it self, but it creeps around the gasket/rubberseal, and then gets drops on the bottom left
  12. well. had a long time with no big issues, but now after a long wet Fall, and Spring is also rainy, the car fogs up quite a lot. discovered a little water on boot rubber at bottom left, and liner on trunklid, was a bit wer.... took it of to dry, no water in trunk, so has to come from the rubber gasket thingy. today is raining heavyli, so put the rear seat down, and could see the rubber gets moist from about the middle on left side, and then drops forming inside bottom left... might be an adjustment of trunk, or new gasket, but it is still soft... my back doors also holds a bit of water, only in the front part/holes, rear holes not glocked up, and car is holding nose up in driveway. , so i just cut the gasket of till number 2 clip that holds it(2 inches i guess).... why oh why do we get all that misting.. trunk footwell is bonedry, the sidesalso, and flootmats too...
  13. old thread i know. but i discovered today, my 2013 rapid also gets wet around the rubber like yours, mine is not a spaceback though.. it is raining heavy today, so took of the truk lid coves(was a bit wet on the left), and sat in the car, could see the rubber got wet, and water creept in at bottom left. might need and adjustment of trunklid... any ideas?
  14. Thx for the checkup. And goof to see I am not the only with leaves and dirt there. I did get the Grill i front Mounted. But I don't believed it holds water out more then when it is not installed
  15. Water in b pillar? How would that get there well I have to see when I get the time or it gets worse!!
  16. Thx for the reply. Yeah, they are pretty much the same.. mine has the manual ac though.... bought 2 of those anti condensation thingies yesterday, today there was no moist, maybe the interior is just filled with moist from the weather, and then when raining, the blower cant keep up...... but i will investigate further anyway.... well update, or not, took the wiper assembly off, took all the rustpreserver of(sticky stuff) flushed water with hose on windscreen, no way near the air inlet.... time will tell if it gets worse this vinter, or else when i find the time, i will take apart footwell trim inside of the car and see if there are any signs of water there.... but the anti condens bag helps so far
  17. Thx for the reply. Yeah, they are pretty much the same.. mine has the manual ac though.... bought 2 of those anti condensation thingies yesterday, today there was no moist, maybe the interior is just filled with moist from the weather, and then when raining, the blower cant keep up...... but i will investigate further anyway..
  18. Sorry if I miss explIned my self. I Only use ac to dry the moist. And I'm hot weather only use i briefly. I have tried have it running while parked to see how much I dripped,. But never saw a pool under the car, like under other cars
  19. Asking, because i never had a pool of water under the car,
  20. Will take it apart this weekend, the dirt is just old sticky rust protection
  21. I took it out last week, so not there i am afriad... but made me think , where is the ac drain exit on the car? Over heatshield?
  22. Looking closer. I might think. The marked part would be the one I need. But I can't see that flap on my car. Any rapid owners who would look at theirs??
  23. Hi. Yes. That was the mesh i mentioned I got. But stil on many other VAG cars there are som sort of splash guard.
  24. Thx for the reply. Yes car is all dry. If it was wet it would damp when parked in sun. I just think it is wierd it gets misted when raining. How does your air-intake look Like? I will get those moist damp traps. Or make some with the crystal cat litter 😂 Picture of air duct
