Steinrawr
Finding my way
Everything posted by Steinrawr
  1. My only reason for nut suspecting that, is the fault codes on the flaps. My reasoning was "if the heater matrix or silica is bad, then the flaps wouldn't give a fault code". But i am only guessing.
  2. Short update, will try to get a better look at the car this weekend. I sometimes get hot air on the passenger side too, but it seems random. It has happened two times the last week, car is in use daily.
  3. I was a little to late to edit the post, here's some additional info: I've also cycled all different settings a few times. Airflow seems normal in all wents, but cold on the passenger side. After clearing codes I started the car and tried calibration again, codes went away after a DTC clear, but it still blows noticable cold on passenger side.. I swapped a faulty blower motor 6 months ago, if that's relevant in any way. Read codes again after running it for a while, and they came back.
  4. Hello dear friends. I'm posting in hope of any help with the following. Suddenly my Skoda Octavia 2016 2.0 TDI 4x4 Scout with 300.000km on it started blowing cold air on the passenger side, no matter what temp it was set to. I tried the calibration trick in hopes of it just being a calibration issue, but 10-15 calibrations later, its still stuck. I've read out the following fault codes with VCDS: 329477 - Motor for Fresh Air / Recirculated Air Flap B108B 54 [00001001] - Missing Calibration / Basic Setting and 329479 - Position Sensor for Fresh/Recirculated Flap Motor B109B 15 [00001000] - Open or Short to Plus I've tried reading about this, but what I've found indicates the whole flap assembly needs replacing and a lot of the dash has to come out to remove it? Do you have any suggestions for me to try?
  5. Any other suggestions to this? I haven't used the car a lot so there's hasn't been any lights lately, As far as I can tell, It tends to light the warning lights when just started cold, or after an hours time when warm. Coils and plugs are as stated above just recently changed. I will do a fuel filter replacement soon too, but i doub't thats my perpretrator. I have a suspicion towards the intake manifold having a large carbon build up, but I can't really tell for sure without actually removing it.
  6. I am in Norway @Ootohere, our fuel is unleaded 95 octane E10. Anything else is practically impossible for me to get my hands on. Considering doing a workshop visit, but diagnosing this would likely be very expensive. I tried doing a compression test, but I think my test Gauge is faulty, as it wouldn't move at all, on any cylinder, or my snowblower 😂
  7. short update to this problem. I could seemingly drive for half an hour without anything happening, but suddenly today, EPC and Engine Warning Light came on and the car was bogging a lot. No warning, just suddenly seemed to start misfiring. I've looked fairly thourougly for vacum leaks, but I can not hear, see or feel any, and I tried spraying start gas around all vacum connectors without any results. I had one leak suspicion and sealed it properly (plastic had a crack, just taped it up). Did a new readout of codes now after the fault came back again, and this is what it reads: It's usually only cylinder 1 this happens on. I've previously also tried swapping coils and spark plugs with no different result. I've also been reading everything I can find about theese 1.4 TSI engines, and it seems like carbon buildup on the intake is a common problem. Is there any point in trying to add injector cleaner to the fuel? Could vaccum cause misfires on only one cylinder? Any suggestions would be greatly appreciated.
  8. So. heres an update. The "only" problem here was a corrupt VIN in the instrument cluster. The Key Tech coded the Instrument cluster back in with correct VIN, and it solved all the problems that occured half a year ago. Two Skoda Dealership Workshops overlooked this (Even when told a key programming had induced the faults) and two other workshops also overlooked this. Simple fault, and fooled to look in all the wrong places as the instrument cluster did not give ANY fault codes at all. Finally..
  9. EPC light comes on now and then, sometimes also the yellow engine warning light with it. Engine gets jerky but drivable, but a stop and start usually clears it and I can drive normally. This has happened with both warm and cold engine, with full throttle, on low throttle and in everything from -20 to +25 degrees Celsius. I had a similar problem this winter (though car just barely could go forward when EPC light came on), but it stopped after swapping the coils. So all four coils are just 6 months old, I've barely used the car, and they've been used maximum 5000km.. After the problem reappeared i changed all the spark plugs. This is todays fault code readout after a few shorter trips. I cleared all codes a few days ago. I don't think the 4729 - Steering Effort Control Module is relevant as I have some other issues with the car that aren't relevant (read more on ross-tech). Do you have any idea on what I can do? codes:
  10. So, I'm going down the road of troubles with my Octavia. Now the only thing remaining is the diesel heater, but it has a few fault codes and wont start. I've read up on a bit of info, and as far as I understand, the heater should be unlocked in VCDS, I think I'm able to figure out that part. But as far as I can understand, the circulation pump is the problem, but I cannot find the heater and parts in the engine bay. I think I've found some used parts that might fit, is this the correct pump? Any help is appreciated. I might be so lucky it's just a fatigued cable, but I really can't find it.
  11. And update: Replaced front sensor, and everything is OK and no fault codes. Lights work like they're supposed to as far as I can tell.
  12. Update: so I just went with it, and everything was a nice fit, completely identical to oem, but included 6 connecting bolts where not correct for my car, only the larger hub axle bolt was compatible. For anyone with the same questions. There doesn't seem to be any difference between 6 and 7 speed DSGs in regards of the CV axles.
  13. Hi all. I'm very confused about the drive shafts for my 2015 Octavia. I'm in Norway and ordered aftermarket drive shafts for both front sides. BUT, the shop I ordered from stated it was for "automatic" with little else info. but now as i got the parts (and couldn't actually tell them apart without googling) i noticed one of them says 7 speed gearbox on the product page for GSP. But upon a little ressearch I can not figure out what lenght driveshaft it actually should be, as it seems every manufacturer has their own definition of length. So, I'm terribly confused. Will both theese fit? I have theese two front axles in hand, and I am definitely NOT taking out anything until I KNOW it will for certain fit my car. 1: front left: Dr!ve+ DP2110.10.2265 2: Front right: GSP 201893 Both front axles inner joints are bad, and the car shakes like a paint bucket mixer. There's so much play in the joints I can move the inner joint on the axles by hand, so theese really need to be swapped ASAP. Also, I'm far from home on vacation, so if the parts above are not compatible, I might have to leave my car here.
  14. Start stop works great, and the battery is fairly new. I have no suspicions towards battery or generator. The low voltage might indicate corrosion on the terminals?? Yes, I think the new sensor will be here in a day or two, so will take a new assessment after installing it. It's just a little Weird that it's worked (with a broken lever) until now, but the electronics might just finally have failed.
  15. Hello. I have a fault code related to the Automatic distance regulator on my Skoda Octavia Scout 2.0 2015. The car display warns me with a error message for Adaptive lights. Are theese fault codes related, and is there something else than the ride height sensor that can be the culprit? This is the readout from VCDS. Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D Component: ACC Bosch MQB H05 0304 Serial number: 27111403210095 Dataset Number: 5e0114t____ 0006 Coding: 00081A00FE0739 Shop #: WSC 73430 031 00063 ASAM Dataset: EV_ACCMRRBoschVW372 001015 ROD: EV_ACCMRRBoschVW372_VW26.rod VCID: 382924B7C2DB246AAF3-806C 1 Fault Found: 1043 - Automatic Distance Control B10E7 F0 [00001000] - Disconnected [FAULT_CIS_TSK_IRREV_FAIL] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Reset counter: 37 Mileage: 291970 km Date: 2024.07.05 Time: 20:11:16 Control Module temperature: 30 C Voltage terminal 15: 11.3 V Vehicle speed: 0.00 m/s Acceleration: 0.00 m/s I also know one of the level sensors on the car is bad, and have this fault code that can be related. The front left sensor is broken, so i think it might be the one causing this fault: 1 Fault Found: 5275409 - Supply Voltage for Vehicle Ride Height Sensor C107F 11 [10001001] - Short to Ground MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 3 Reset counter: 2 Mileage: 292553 km Date: 2024.07.08 Time: 09:37:53
  16. Hi. I've gotten som help diagnosing my 2014 Rapid 1.4TSI, and the workshop has concluded the ABS control module is dead. I'm looking at what my options are, and as I understand it. This module is integrated into the ABS hydraulic pump assembly, right? I think that should be part number 6R0 614 517 BF. Can someone please point me in the right direction here? I know it must be coded when changed, and I think I have control of that part of the process .
  17. Thanks, gives me hope it can be solved. But certainly not by me, as it seems like the steering angle module must be taken out and reloaded with software. Mine also seems to be completely empty, like the one linked on Ross-tech.
  18. Specialized locksmith. I drive a tow truck, several of my collegues with 15+ years of experience also testified to this shop being the best place to go with any car key related problems. When I told them what happened, they had never heard of or experienced anything similar (And my work also use them often). Also a plus that they're about 10-20% cheaper than any dealer workshop. I've never seen or heard negative reviews of them (And I've looked thoughly), they've been in the business for the good part of 20 years, I practically cannot find anyone with same issues online. I have no reason to doubt them, and they are helping to get it fixed, I'm just impatient and want my car available. This is in Norway btw. But that wasn't really what I'm here for feedback on, do you have any suggestions?
  19. Skoda rapid 2014 1.4TSI DSG. 260.000km Ok, so I got a spare key coded in, and it works. But... Now the steering wheel angle module (or something like that) went completely haywire. Done by a professional shop, which explained that this happens with one in a thousand, and that it needs to see a shop with login codes etc. They will cover the cost, but I'm seeking help to see if I can fix it myself earlier, as I can't really be without the car for long, and i expect it to be at a shop far away for long. Car drives, but lamps are blinking and abs/tcs/esp etc is not working at all. I went to a vag-garage close to my home, but they were a little short on time and couldn't take a deeper look. They told me they tried deleting fault codes, and reset the coding on the affected module as well as doing a factory reset, but didn't succeed in removing the issue. I don't know the name of the system the key-tech used, but it was a large apparatus with obd contact, screen and a key reader/slot. Is there anything I can do myself with VCDS? I've read fault codes, and module 04 - steering wheel angle does not at all communicate with the diagnosis tool. Monday,25,March,2024,18:28:54:35578 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64 VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4 Data version: 20231027 DS351.0 www.Ross-Tech.com VIN: TMBET6NH1E4523977 License Plate: Mileage: 252380km-156821mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: NH-SK25 (6N0) Scan: 01 02 03 04 08 09 10 15 17 19 25 2E 37 44 56 61 69 0B VIN: TMBET6NH1E4523977 Mileage: 252380km-156821miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 69-Trailer -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb Part No SW: 03C 906 016 GD HW: 03C 906 016 GD Component: 1.4l R4 TSI H01 4583 Revision: LPH01--- Serial number: CVN: F291B5BC Coding: 00250032002401000000 Shop #: WSC 73430 031 00016 ASAM Dataset: EV_ECM14TFS01103C906016GD 001003 ROD: EV_ECM14TFS01103C906016GD.rod VCID: 678BB7CBDFE57B928E9-8032 VINID: 91D4959067980551050832471CDA5CE923 No fault code found. Readiness: 1110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 0AM-927-769.clb Part No SW: 0AM 300 062 M HW: 0AM 927 769 D Component: GSG DSG AG7 431 6561 Revision: 00043014 Serial number: CU501401155558 Coding: 0000020 Shop #: WSC 51729 001 1048576 VCID: 36352A8FC44FD21AC5F-8062 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-614-517-TRW460.clb Part No SW: 6R0 614 517 BK HW: 6R0 614 517 BK Component: EBC 460 ESP H08 0004 Serial number: A00ICBD Coding: 4129481489B300B7825012D991A700504B0800 Shop #: WSC 73430 031 00021 ASAM Dataset: EV_Brake1ESPAEntryTRW 002011 ROD: EV_Brake1ESPAEntryTRW.rod VCID: 7DA7F5A3AD79C142445-8028 2 Faults Found: 0360 - Steering angle sensor B1168 54 [10001001] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear 0405 - Incorrect Vehicle Type U10D9 00 [10001001] - - [CHASSINF_CAR_TYPE_MISMATCH] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 1 Fault Frequency: 1 Reset counter: 34 Mileage: 252381 km Date: 2024.03.25 Time: 18:06:47 DTC: 00 01 95 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl Part No SW: 5JA 907 044 HW: 5JA 907 044 Component: Climatronic H04 0106 Revision: A1001000 Serial number: 1311191A-0046 VCID: 78A9E4B782DBE46A173-802C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb Part No SW: 7H0 937 090 B HW: 7H0 937 090 Component: BCM PQ25 Max4 H74 0712 Revision: B9074001 Serial number: 0571 018140590 Coding: 62980B0000010000000801306E0B0DD00EC0400F608E0040020000004000 Shop #: WSC 73430 790 00021 VCID: 2D0705E33D1991C2B45-8078 Subsystem 1 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F Labels: 3C8-959-537.CLB Component: E221__MFL-PR6 H04 0130 Serial number: 000000000B0626240114 Coding: 820000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5JA-919-475.clb Part No SW: 5JA 919 475 A HW: 5J0 919 475 A Component: PARKHILFE 3K H11 0005 Revision: -------- Serial number: 32901401600160 Coding: 110103 Shop #: WSC 73430 031 00021 ASAM Dataset: EV_EPHVA14SK25X0000 001002 ROD: EV_EPHVA14SK25X0000.rod VCID: 44D140478E13708A4BB-8010 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 34D 959 655 B HW: 34D 959 655 B Component: AirbagVW20 004 0365 Serial number: 003K7R02TEU3 Dataset Number: 5JA003t____ 0013 Coding: 88CCC00000000000540000C8000000000065 Shop #: WSC 73430 790 00021 ASAM Dataset: EV_AirbaVW20SMEVW253 001108 ROD: EV_AirbaVW20SMEVW253.rod VCID: 34311087DEB3C00AFBB-8060 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 480 411 801 14 Component: SideSensor_Df 003 0148 Serial number: 349651A016EB02A48D9U Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 480 411 801 14 Component: SideSensor_Pf 003 0148 Serial number: 350651A0119A0D543C35 Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 480 411 801 14 Component: SideSensor_Dr 003 0148 Serial number: 351651A0146C4F02CFAQ Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 480 411 801 14 Component: SideSensor_Pr 003 0148 Serial number: 352651A0119C89234FAK Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 5JA 920 840 D HW: 5JA 920 840 D Component: KOMBI H04 0709 Serial number: 00000000000000 Coding: 111E01 Shop #: WSC 73430 031 00021 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod VCID: 3B233BBBF3ED0F723A1-806E No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 7H0 937 090 Component: GW-K-CAN TP20 H74 0712 Revision: B9074001 Coding: 932200 Shop #: WSC 73430 790 00021 VCID: 70B9DC97EAABBC2ADF3-8024 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0709 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6A8DCEFFCCF746FA917-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665752742 Coding: 030100 Shop #: WSC 73430 790 00021 VCID: 2B030BFB030D9FF2AA1-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb Part No SW: 5JA 035 192 J HW: 5JA 035 192 J Component: RNS315-EU H76 0410 Serial number: SKZAZ2P0041600 Coding: 040004010207000001000002 Shop #: WSC 73430 031 00021 ASAM Dataset: EV_RNS315EUV2UDS 001705 ROD: EV_RNS315EUV2UDS.rod VCID: 3E2532AFE0FF1A5A1DF-806A Data carrier: Subsystem 1 - Part No: 3AA 919 866 Component: EUR_W_V5 0055 2 Faults Found: 1048632 - Antenna 1 for Radio B1119 13 [00001001] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 5 Fault Frequency: 1 Reset counter: 34 Mileage: 252381 km Date: 2024.03.25 Time: 17:52:57 1048636 - Digital Radio Antenna B1103 13 [00001001] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 5 Fault Frequency: 1 Reset counter: 34 Mileage: 252381 km Date: 2024.03.25 Time: 17:52:57 ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb Part No SW: 6R1 909 144 R HW: 6R1 909 144 E Component: EPS_TRW_ALow 311 3111 Serial number: CE1V0003 Dataset Number: 5JJ074t____ 0009 Coding: 0003 Shop #: WSC 57209 005 104857 ASAM Dataset: EV_SteerAssisUDSTRW 011021 ROD: EV_SteerAssisUDSTRW_011.rod VCID: 46D55A4FB82F429A55F-8012 4 Faults Found: 1094656 - Steering angle sensor B1168 54 [10001001] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 34 Mileage: 252381 km Date: 2024.03.25 Time: 18:18:06 1091584 - invalid data record B2005 00 [00001001] - - [DEM_INVALID_DATASET_FAULT] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 34 Mileage: 252381 km Date: 2024.03.25 Time: 18:18:06 1073664 - Steering End Stops Not Learned C10AC F0 [10001001] - Unknown Error Elaboration [DEM_LEFT_ENDSTOP_NOT_KNOWN] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 34 Mileage: 252381 km Date: 2024.03.25 Time: 18:18:06 1073920 - Steering End Stops Not Learned C10AC F0 [10001001] - Unknown Error Elaboration [DEM_RIGHT_ENDSTOP_NOT_KNOWN] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 34 Mileage: 252381 km Date: 2024.03.25 Time: 18:18:06 ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7H0 907 534 HW: 7H0 937 090 Component: Batt.regelung H74 0712 Serial number: 0571 018140590 Coding: 032B7A64 Shop #: WSC 73430 790 00021 VCID: 6B83CBFBC38D5FF2EA1-803E Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E Component: J367-BDM H08 0181 Serial number: 51007K09162031593138 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb Part No SW: 1K0 907 383 F HW: 1K0 907 383 F Component: Anhaenger H09 0100 Revision: 3A001001 Serial number: 00008200034725 Coding: 410D000100000000 Shop #: WSC 73430 790 00021 VCID: 30391C972A2BFC2A9F3-8064 No fault code found. End----(Elapsed Time: 01:32, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)----- 25.3.2024 kl 1830.txt
