Lukas_2611
Everything posted by Lukas_2611
  1. So to avoid damage to the original LED i changed to a brighter LED with the correct resistor ... tests look amazing.. First Pic original Skoda.. second with new LED..
  2. My Armrest makes creaking noises when i lean my arm on it.. Is there any solution to fix it? Thanks for any help!
  3. The whole unit costs 12 Euros at my local skoda dealer.. A lower resistor is just letting more through to the LED and it will glow brighter.. The original light was way too low for me so .. i will leave it this way..
  4. So.. almost done.. switching polarisation made the LED glow white.. To make the original LED brighter i switched the resistor from 8000 Ohm to 1000 Ohm.. now its nice and bright .
  5. So Ive made an adapter taking it from the usb c lightening.. it is working perfectly.. but.. two different OEM Version came in red.. The red light isnt really visible.. and i want it in white.. looking for a solution..
  6. It is for testikg from the skoda factory to see if the car is waterproof and the sealment correct. There is no more use.. you could remove it.. Its not a reciever or antenna..
  7. Not yet, tried to find out by myself what is the problem but no success till now.. and you?
  8. Yes, mine is also from 03/2024, latest software..
  9. I am having also probems with the gps since a week.. dont know why.. everything was working over a year.. The arrow moves, but kilometers away where i am.. than suddenly its working again.. as normal.. very strange
  10. I made an adaper .. catching the light from the USB C Supply :) Didnt test it yet in the car but i am sure it will work. I will post pictures after testing.
  11. @Giannis20 Do you know how the glovebox lightening works? is there a switch? I bought the original 5E0919173A LED light for 20€.. it fits perfectly in the hole.. now i am thinking where i can put the LED on.. maybe glove box light? You have an idea? Thanks!
  12. Where did you exactly put them?
  13. My brake pedal also made some noises.. I have sprayed some lube on this spots and its way better now You can also check if the pedal clonks back at this spot..
  14. You can try to remove the side like on in this post described. The next trim should also be removable. Maybe you will get there.
  15. I am trying to do the LED light at the central vent OEM style.. I ordered the unit for 20€ and will make a harness. Just thinking where to put it on.. maybe glove box light, but i have to investigate how the switch works..
  16. No, not that hard :) Its a but tricky to put the unit into the cover but the rest is quite easy..
  17. Haha okay thank you.. same as mine.. they messed up at the production ;-)
  18. There is a sign on the light unit.. 015 E 12345 or something like that. On my running lights it was upside down.. so when installed wrong pposition
  19. @Giannis20 is your E Sign in the correct position? :)
  20. I broke this little part 4x times.. on the originals and on the new ones.. xD .. So I ordered new running lights... they are on the way.. The running light units where also a little damaged on the edge.. so I hope the new ones are better.. I also recognized that the E sign was wrongly made.. so how its called.. upside down? Are yours in the right position? Thanks for the pic.. I started at the edge.. so on the outer part.. maybe that was the mistake..
  21. I mean to dissamble the indicator unit out of the cover..
