omeromeryigit
Finding my way
Everything posted by omeromeryigit
  1. Hello, we've found a new solution for the multimedia issue. I believe this problem is caused by liquid getting into the touchscreen or moisture accumulating there. If you can remove the screen, clean the touchscreen with isotopic alcohol. Wipe the power button and volume bar thoroughly. I haven't experienced any issues since May 2025. The power button and volume bar work perfectly.
  2. I cleaned it with cotton.
  3. The problem was resolved after the cleaning, it's been 10 months.
  4. unscrew all marked screws and remove the metal cover
  5. Let the multimedia be open 👍
  6. Bravo; how will this sound bar be disassembled? Can you share a video or picture?
  7. I've never done anything like this before. Using the plastic separator handles, it came out easily when I lifted it from one end. You can do it too.
  8. When removing the specified film cable, the vehicle ignition must be on and the multimedia system must be running. From now on, the multimedia system will remain running every time the ignition is turned on.
  9. Congratulations, I'm glad you made it.
  10. I will re-record a video for you at a convenient time and send it to you. But I don't know when I will send it.
  11. do the same for the power socket, (black socket)I regretted not taking any videos or pictures while repairing the multimedia, I don't want to open it or disassemble it again. My wife uses it actively during the day, but I tried to help you with the pictures I found. If I find a suitable time, I promise I will take a video.
  12. There were also those who cut the metal protection. Those who cut the area in the picture and removed the socket. Try that and see.
  13. Enerji soketide bu şekilde yap , (Siyah soket)
  14. remove the vedas in these pictures, the metal protection should be released, while the power cable is connected, remove the audio socket. then check.
  15. When you unplug the connection cable, make sure multimedia is open, the on button will be disabled.
  16. I dismantled it using these tools,
  17. Hello, I removed the connection cable socket of the multimedia sound touch bar. I only control the sound from the steering wheel.
  18. Hello, I removed the connection cable socket of the multimedia sound touch bar. I only control the sound from the steering wheel.
  19. problem solved. I was controlling the volume button from the steering wheel 👍
