Everything posted by AndySmith1707
New software available version 1989
Exactly, it's an old problem that was resolved around 1941 (version not year). Beyond belief that the fault has been reinstated by this update. Anyway, factory reset seems to have sorted it
That's exactly what mines was doing following the update, factory reset seems to have cured everything.
It's certainly worth doing the reset. It's what you would do if selling the car, it clears all user settings, but most are restored when you log back on as primary user. Skoda should include this step as part of the update procedure?
In fact, restoring primary user and settings was simple, once logged in it remembered radio stations and destinations. The one positive is that i now have a station logo for LBC, a first!
After installing 1989 OTA last Friday my system had a complete meltdown this morning with an almost continuous freeze and reboot cycle. I was reluctant to reset to factory settings because I've had problems in the past setting the primary user, but I bit the bullet and did a reset. Early indications are that it worked, and the primary user set up went ok as well. The reset seems to have fixed the ACC driving on the right issue as well. Finger crossed, and thanks for the suggestion.
Screen washer issue
An update. The dealer had the car for a couple of hours but couldn't work out what was wrong. Is now booked in for 2 days next week....
Btw, mine seemed ok the day after the OTA update, but it started freezing again today. For anyone thinking about installing it - don't!
I'm not going to do a factory reset. Car is booked in next week to see whether dealer can get windscreen washer to work. They can look at it then. Skoda broke it, they can fix it.
Ota. Makes it worse. Skoda have messed up a car that was finally working ok with 1985.
I found out today that 1989 has brought back the issue that makes ACC think the car is in Europe so it refuses to overtake on UK motorways. Unbelievable.
Mine updated to 1989 OTA this morning. Complete mess. System won't leave Android Auto, all buttons freeze including climate hard button. Reboot and it does it again. Worked perfectly with 1985. Nightmare. I really hate this car now, I new I should have bought a Corolla estate.
Screen washer issue
Breakdown man cleared the filter but not fixed, needs an airline to clear blockage in the pipe, so booked into the dealer this week.
Screen washer issue
You're probably right Steve. It's under extended warranty, AA are sending a Skoda breakdown service, will post an update.
Screen washer issue
Pump is running, definitely not a fuse. Before they stopped the washers did a final squirt with a small volume, looked like fluid had run out
Screen washer issue
Hi there. Both front screen washers have stopped working, reservoir full and headlamp and rear screen washers working. Any ideas? Thanks
iV fuel consumption - brilliant or terrible ?
On motorway runs with a flat battery, mpg has never been below 50 for me. A 200 mile round trip starting with full charge will be 60-65 mpg. 30 each way commute is 100 mpg plus. The great thing though is getting 800 plus on a tank when you do short journeys all week. Overnight charging on economy 7 is about 75p.
Wheel white worm
No, just car shampoo. I'll report back, worth a try.
Wheel white worm
Hi. A couple of the wheels on my Sept 2021 car seem to have 'white worm' corrosion, see picture. There's no sign of damage to the lacquer, they haven't been kerbed. The car has an extended Skoda warranty, what are the chances of this being covered? Thanks
iV will not shift to e-drive
I ran an eHybrid Golf for three years and 30,000 miles during which it did this twice. The car decides that for whatever reason the petrol engine needs to run for a certain amount of time and won't let you override it. I don't think it's a fault. Now have a IV SEL estate, much nicer car than the Golf, BTW.
Octavia iV battery size?
I don't think you need to worry, the figure quoted is a prediction best on previous use and (I think) temperature. I ran a PHEV golf with this drivetrain from new, never should more than 30. Now have a 2021 IV estate, gives better mileage than the golf, but prediction is usually 25-29 miles. My journeys always involve 2 or 3 miles of fast A road. I wouldn't be surprised if the people seeing 30 plus are mainly driving in town.
Can I set the charge time every day
The car allows you to set charge start and stop times for each day of the week. Takes about 4 and a half hours for a full charge, you can do it all at cheap rate. It's the only way to run a PHEV.
Unable to log in to Skoda Connect via infotainment system
Will do. Did you go to a dealer?
Hi there, I've got exactly this issue with a 2021 car, did you manage to fix it? Many thanks
2021 Octavia IV on 1896 software
Correction, it's on 1803, not 1896
Hi there. I'm looking at a 3 year old MK4 Octavia that's still on 1896 software. Has a full AA report and all functions are working as they should. Last service was done by a non-Skoda workshop, this maybe why it wasn't updated. It may never have gone wrong, of course. Non-Skoda garage has said in writing that if software problems cause a problem in the first year they will fix it under warranty. The car is a very good price. Am I worrying unnecessarily? I had a bad experience with an early mk8 golf that only behaved when updated to 1941. Any advice would be appreciated.
