Everything posted by scotthugh3s
Considering getting rid of my 2020 SE L in favour of a 2023 VRS...
The car in question is diesel and an automatic, as opposed to my manual petrol SE L. If I was to go for it, it would be the first time I'd ever owned a diesel car in 30 years of driving, and the first auto I'd ever owned too. Just wondering for those with experience, if there's anything in particular I should look out for or be wary of? It's a fairly low mileage example with a supposed full service history, so in theory everything should be in good shape... Although as we all know, when it comes to the Mk4 any kind of theorem is little more than just a guess Appreciate any input, it's just an idea at present but interested in people's thoughts
How are your EFB batteries holding up?
If you tell me how / where to find them, I'll take a look
My battery almost died at around 4 years old, set off a flood of warning lights, all of which I could clear using OBD11 barring one, the airbag light, which needed the module software updating to remedy that. Tried simply charging it using the CTEK first of all, and whilst on paper (so to speak) that brought it back up to voltage, it still seemed to under perform, start / stop never functioning, the odd random warning light etc So I tried the Recond mode and ever since it's worked almost flawlessly. Start / stop functions as it should and warning lights are a thing of the past (touch wood) Now I hook it up on a trickle if I'm ever plugging OBD11 in for any reason, other than that I intend to use the Recond mode once a year, as is suggested by CTEK. I still have the battery in question, this happened almost a year ago now
The CTEK worked wonders for me. The Recond mode gave my battery a completely new lease of life
Buy yourself a CTEK MXS 5.0 Battery Charger Run it on the Recond option. Brought my battery back to life after suffering similar issues to your own, and it's worked flawlessly since
- Apparent stalling
Engine sounds like old transit van after timing belt change --- 2020 Octavia 2.0 TDI ( DSTA / EA288 EVO )
Mine in December of the same year (31st, missed out on being 2021 registered by one day lol)
Octavia MK4 Firmware Update
Shouldn't it have SK in the name not VW?
How to lock keys inside?
App doesn't offer this functionality on older mk 4's, mine from 2020/21 isn't supported
Remove tailgate interior
They don't come as standard on the mk4, well maybe on the VRS model they do but not below as far as I'm aware (I have SE L which doesn't have one) They were an available option though I believe so some mk4 hatch's will have them
High-pitched whining noise from the engine bay – Octavia iV
Is it not just the turbo whistling?
KESSY issue since update to 1985
Sorry I can't help you with that, I've only ever encountered an issue when it's wet. It's a known issue with a fix that involves replacing the door handle (off it concerns you that much anyway) Have you tried searching through the forum for threads/posts marked KESSY?
Does it mostly happen when it's wet outside?
GPS Drifting
When you say only wanders when using AA, can you not just use google maps through AA? I get it, it's frustrating when the inbuilt nav drifts, mine has lapsed into it on a couple of occasions but has thankfully righted itself quite quickly. May be a silly question but have you tried performing a factory reset on the infotainment unit? Will require you to sign in again as primary user afterwards, but it can help with small bugs like these
Hazards when locked.
Had your alarm been triggered by any chance?
Android auto not working
Factory reset on your infotainment would be my first step
Configuration function missing
I have the older Mk4 Octavia, so unfortunately I can't help you. But I wanted to add that disappearing functions from the infotainment menu is a problem which is suffered in the Mk4 too. Skoda really need to invest in some decent software techs
Bluetooth MP3 compatibity
There's coding available so that you can code your infotainment to recognise 2 phones at the same time, perhaps that would help with this issue too?
Dealer Or No Dealer?
A bit of a journey, although not too far (I travelled further to see him) But I'd highly recommend giving @East_Yorkshire_Retrofits a shout. He can do everything we've talked about here, and much more.
@Tried5UserNames Where abouts are you based mate?
Look for an independent who specialises in VAG motors, there are some out there who can service your vehicle and update the service log just as the dealership would
New software available version 1989
I don't have that particular issue with things disappearing from the infotainment, but I did have one myself... It was the ability to switch Laura's voice from male to an actual female lol The setting appears very briefly in the relevant screen, but then quickly disappears for some reason. Took me a while to be quick enough to hit it before it went, but I did manage to change it I'm sure other options went too, although I'm unsure of which ones. Gotta love the bugs on these Skoda's....
- Issues with Mk 4 1.5 TSI
