chills
Everything posted by chills
  1. The re-formatting frequency will depend on the number of hours you drive and the size of the card. A 32GB card will require re-formatting 4 times more often than 128gb CARD. The higher levels of Sandisk cards have auto wear levelling software. So I can't see the need for re-formatting every 2-3 weeks unless you are a taxi driver with a 32GB card.
  2. Everyone's cards are less expensive than Nextbase!!! SanDisk are a reliable make, as is Kingstone. Lexar used to be good, now I believe they rent out the name.... However, you do need to make sure you buy from a reliable source. There are many places doing counterfit memory cards. Like insurance, it doesn't matter until you haver a problem, then you need it to work. You don't want to have a crash and find that the memory card was corrupt. It is worth checking the contents every couple of months.
  3. Hi There are several threads on dash cams and in one of them somewhere, someone was complaining at the cost of Nextbase memory cards for their dash cams. They are ludicrously expensive. As a video cameraman and editor, I have used a lot of memory cards and sometimes manufacturers do use custom memory cards. RED were infamous for this. I have done some tests and can confirm that on a Nextbase 322gw these cards work. https://www.amazon.co.uk/dp/B09X7BK27V at £12 for a 128GB card it is a no-brainer. I recommend using the largest card you can fit (128GB in a 322gw) because flash memory has a finite number of write/erase/re-write cycles. So in a dash-cam the larger the card, the fewer of these cycles there will be. If you don't record dual files (low and high-res) just the high-res the card will last even longer. The spec for a dash cam memory card should be U3, V30 and A2. The A2 is a new measure, but it is for continuous write as used in video cameras where the stream has to find random memory blocks to write to on the fly to fill up space The Camera will determine which file to overwrite when the card is full. See (its accurate, by my god her voice is annoying!) https://www.kingston.com/unitedkingdom/en/blog/personal-storage/microsd-sd-memory-card-guide Incidentally, Kingstone are a very good make (I used them in professional video cameras) and are less expensive than the Sandisk on Amazon. I only used Amazon as I wanted next day delivery and was ordering other things or I would have gone with Kingston.
  4. In The RAC website, though, I may have picked up the EU requirements and UK recommendations. However, as noted by @Ootohere fog lamps can indeed stand in for headlights
  5. That may be where the confusion is.... Between headlights and fog lights. I will see what OSRAM come back with. The other interesting thing is for the UK you must carry a warning triangle, high vis jacket, fire extinguisher, first aid kit and a spare headlamp bulb..... As most modern cars have LED headlight clusters, that is a workshop job to replace, or at least not something you can do beside the road in the dark, how the hell do they expect you to carry a spare headlight? A friend of mine has an AA Universal bulb kit to show the police but admits 3/4 of the bulbs won't fit his car (including the headlights) I assume (silly, I know) that the fog lights are bright enough and in the right position (height etc) to act as headlights in this case?
  6. I have a tech support query in with Osram for a UK road legal H8 LED fog lamp for a Karaq that doesn't give a CAN bus error. I will post their, hopefully positive, response here. In the meantime look here https://www.ledperf.co.uk/pack-xenon-effects-headlight-bulbs-for-skoda-karoq-p-39549.html BUT read the small print on "off-road use only" and can bus errors. It is a bit of a nightmare also this supplier is in the EU (France).
  7. As I have only had the car a couple of weeks, since it has been cold and wet and being almost 70, I haven't got into the front wheel arch to confirm if they are LED or Tungsten, they are a yellow-white like the Tungsten bulbs. The thing is, I don't know if that is because they are fog lights, and it is a yellow-white LED or if it is a tungsten bulb. The H8 LED lights come in a range from yellow white to blue white. The problem is due to some strange EU rules (and the UK hasn't changed the rules from when we were in the EU and isn't likely to.) some cars have approved LED lights but on a technicality you can't replace Tungsten with LED unless it is an approved one for that car. IE the sport line? Hence, most of the replacement LED lights having in the small print "for off-road use only" or "not approved". The other problem is the LED bulbs take a lot less current and therefore on the OBD/ECU show up as a lamp error if the car is expecting Tungsten bulb!. So as I would prefer a more powerful whiter LED fog lamp, I am looking for a UK legal LED H8 that won't give a permanent error on the dash. (don't want much, do I ? 🙂) We rarely get fog in the midlands (UK) and a more powerful white light would be more use.
  8. The fog lights are standard on the Karoq (all models?), but they appear to be tungsten bulbs (unlike the headlight cluster above). I was looking for LED replacement bulbs. The manual explains how to replace the fog lights (but only the fog lights!?!), with some comments on safety with tungsten blubs. However, there are no specs for the lights, any lights, in the manual There are many H8 LED fog lights available, but the small print for a lot of them says they are not road legal😞 They also seem to have different shapes and sizes etc.
  9. Hi Does anyone know of any UK road legal LED front fog lights for the Karoq? Preferably, ones that don't give an error warning? I can't be the only person wanting to do this?
  10. chills replied to Cvak's topic in Skoda Karoq
    Mine is in the same state and going to have a wash this afternoon! I note that, on mine, like yours the lower door panels seem to attract a lot more dirt than the rest of the car. (It has a Gen-3 coating) BTW I have the OEM Brimstones on 18-inch wheels and I am looking for a good All Weather tyre. Flip-flopping between a Michelin and a Continental at the moment.
  11. Thanks for that. I assumed week 10 as the update gave week/year (48/3024) rather than month year. It would help if they were consistent! In which case, As I have an October 2024 database and this week 48 update is end of November, is it worth me updating the 29GB of maps, especially as I won't be taking the car out of the UK in the next 12 months? Probably not, I would think. Sorry for the silly questions, I have had Nissan's for the last 30 years, and they last over a decade, So a new 2024 Karoq is a bit of a jump in terminology, technology, and toys 🙂
  12. Looking at the car it says: "Navigation Database 24.10" Which I assume is 2024 week 10? So I should update it with the "CW 48/2024"? It would help if they kept the naming and version numbers consistent
  13. Many thanks for that. I was starting to think that was the case. The map file zip is enormous! 29GB!! Not something I would want to do over the car's internet connection.
  14. I have a Karoq SEL 1.5 manual 2023 mfr WTF is the SD card slot hidden? I can't find it!
  15. Thanks for that. I would assume (silly I know) for a car introduced in 2018 with a known end date of G3 only 5 or 6 years later they would have put in a G4/LTE module, and certainly done so by the 2022 facelift. Having had a look at the wiring and comms manual, the comms unit is an easily replaceable module, so no reason not to update it if it was G3 only. . My 5-year-old iPhone is G3 and G4. Hopefully the G3 warnings are for the older Škoda models that only had G3 fitted, not the Karoq
  16. I hope so. It is just when I renewed the App it said about the G3 shut down and loss of services. However, as my car was made late 2022-2023 (registered April 2024) I assume that as the date for the G3 shut down was well known some time (years?) before 2022 the cars would have a G4/LTE comms module. Any idea how I would find out specifically what is fitted to my car?
  17. Apparently, the Škoda Connect app will stop working at the end of 2025 when G3 disappears in Europe. As this has been known about for a very long time, surely there must be a G4 upgrade for the cars? Škoda can't be the only people using G3 for long term comms? I am sure not just many other carmakers but a lot of other equipment will use G3? Does this also mean the SOS button will stop working as well?
  18. Likewise, I have had Nissan's for the last 20 years. My Karoq is a generation (or two?) on from my last new car and has a different "logic" in the manual. I can't find an option to only unlock the two front doors and nothing else which would be useful as it is usually just me and the wife in the car.
  19. Apparently, I was informed by another forum member when I posted the video in a thread on its own, all this is in the manual! There are some limited settings on what unlocks what, but I didn't find the above in my printed manual, I shall have to re-read it. This reminds me of a forum for some video edit SW I use. I asked for a feature to be added, and a dozen people immediately said that would be the worst feature in the world (ever) We were all surprised when someone else posted to say that feature had been added 5 years ago and explained how to find it! To be fair the manual is over 4,000 pages (yes 4 thousand)
  20. Thanks for that. I am not surprised, but it can be a nightmare digging things out of the manual, assuming you know to look for it in the first place… I certainly missed it as did another owner I sent the link to before posting it here.
  21. Hi All Sorry if this has been posted before, but how to deactivate the KESSY when you leave the car. (Until you unlock with the button on the remote) Video shows a car in Slovenia, but it also works on my UK 2022/3 Mfr Karoq.
  22. In Settings, you can configure the way KESSY works ALso, you might find this useful
  23. Sounds like a Friday Afternoon Car.... 😞 I usually go for a low mileage main dealer demonstrator. So all the problems, if any, have been sorted.
  24. I don't think Škoda, or anyone else, can turn it on for you.
  25. Obviously, I knew that!!!! 🙂 These things are obvious, after someone has pointed them out! Many thanks for pointing it out, It is all becoming clear (bleedin' obvious) now. I do have the Varioflex seats and the mounts are different also the weather the last couple of days is barely above zero. So I am less inclined to stand around outside with the car freezing my nuts off trying to work it out, which I would have done has the weather been warm. My other caveat is this is my first Škoda. I find it takes a while to get into the thinking of the manufacturer, though it is a race against the onset of galloping senility, according to the wife. .
