Jono
Everything posted by Jono
  1. Hi everyone! Now Skoda have un****ed my DSG (see post linked at bottom) and I'm keeping the car for a while, I'm fixing it. I have a slow coolant leak, and have observed it leaking inside the charge air cooler and nowhere else. Before I cry a little over spending a hard-earned grand from my decade-long paycut , I want to make sure it couldn't be anything cheaper! Is there any chance it could be a leaky connector or gasket etc? Does anyone have any suggestions for me? There's pics of the inside of my charge air cooler here. As a bonus question - how do I go about making sure I have the correct part number revision? and/or does anyone know how I might go about sourcing a used part? Thanks in advance! Skoda DSG update ****ery here:
  2. Hi All. It's been some time since I updated. The DSG has been flashed back to how it was before the 23AX update. Finally my car is un****ed. Fuel economy and DPF regen frequency appears to be back where it used to be - although I'm wary of drawing too many conclusions from limited data. Skoda have offered a £200 without prejudice voucher for servicing/parts/accessories, but offered no candid explanation or apology. Based on the wasted trips, time and angst this has caused and in the absence of a meaningful apology I feel that it's a bit of an insult really, but we have reached an impasse. Taking it any further would now require me to go to the motoring ombudsman - I have no idea if this will be worth the time and effort, or if I just move on.
  3. I've always wondered - If you trickle charge via a 12v accessory socket, does this bypass the batteries control unit? or does it know whats going on?
  4. Hi All, Minor update. Skoda customer services have arranged with dealer to flash my DSG back to pre-update software next week. I shall report back. On one hand, positive news, on the other, it's taken a lot of time, stress, and sadness to get to here and I don't want to count my chickens yet.
  5. Not that they need doing yet, but soon I'll need new brake pads. and then debate over replacing discs or not will rear it's head. What are people's thoughts on skimming the disks and going through 2 sets of pads before replacing discs? My rears disks are a bit scored/pitted and it seems like sacrilege to mate new pads to a mucky surface. I've seen places that will skim with the rotors still mounted to the car, rather than take them off and lathe them. Is this a worthwhile thing? I cant work out if it spins up the discs or is just a precision bit of kit that machines them flat. If spinning up the discs, is it doable with 4WD Haldex vehicles?
  6. Yeah, we are both on the same page. Lets not let solutions at a cost to me get in the way of the fact its totally unacceptable, should never have happened and should be taken on the chin and resolved by Skoda.
  7. If working as intended - quite wedded. If unfixable, less so. Why do you ask? Third party tuner fix is likely cheaper that the cost-to-change and really I'm a few years away from wanting to change. I object to spending a grand to put my car back to how it should be, and if Skoda cant resolve my family wont ever be buying VAG again.
  8. Well, it's been "escalated" AGAIN, but I keep getting the same not-answers to my questions from Skoda Technical. Your questions: Was the 23AX update intended in any way to change the behaviour of the DSG gearbox? Did the 23AX update change software in the ECU alone, or the ECU and DSG? Does the attached handbook picture, and my description above (Edit – see below) , accurately describe how the DSG should behave – i.e., Sport mode selecting and holding lower gears than Drive and Economy modes? My pre and post-update ECU software version number and pre and post-update DSG software version number. The response we received is below The campaign was to: On the affected vehicles the software of the engine control unit must be updated and on vehicles with dual clutch also the gearbox control unit.must be updated.The software update reduces emissions The software update does not have any negative effects on fuel consumption, CO2 emission values, engine performance, maximum torque, noise emissions, the durability of the engine or exhaust gas after treatment system. The engine and gearbox ECUs were updated, there is no information other than the above. The hand book does not give a detailed description as to how the gear box should behave . I would suggest the customer visits the local retailer for a like for like comparison with another vehicle" This statement is junk as both the Skoda website here: https://www.skoda-auto.com/world/range-driving-modes And my handbook unambiguously states: "In Mode S , the forward gears are shifted automatically up and down at higher engine speeds that mode D" and "In mode E , the forward gears are shifted automatically up and down at lower engine speeds than mode D" I recently drove 3 similarly aged VW/Audi 2L DSG cars, and they have a Sport mode that actually does things... I'm still gathering data, but it looks like my DPF regen frequency is now in the 200s rather then 300s of Km. It's been theorised that the update makes it deliberately burn rich and cool to reduce nitrogen oxides, at the expense of more soot. I'm so ****ed off...
  9. Thought that might be the case. Thanks for the sage advice.
  10. I have a slow coolant leak, confirmed to be inside the charge air cooler using a borescope. I'm wary about using K-seal and clogging up my heater matrix etc, but seeing that the CAC circuit is mostly separate, I wondered if using a smaller quantity of it directly into that circuit is a potential plan? I'm planning to keep the car for some time yet, so not after a quick bodge that'll cause more bother down the line. Can anyone suggest how best to get some K-Seal into the CAC circuit and/or if this is a daft idea?
  11. Did you solve this yet @stig1? My experience is here:
  12. Woohoo (Kinda) My coolant loss issue is now diagnosed as about the least-bad of the remaining possibilities. Finally got around to getting an endoscope inside the charge air cooler (thanks to @T07 for the helpful pics above). I got the engine hot and spent a bit of time on boost - presumably as that drove charge-air into the coolant, pressurising it more than heat-alone, then went in the IAT and saw it fill up before my very eyes... So, at least it's not the EGR Cooler, or a cracked head... Photos below for interest. Anyone got any tips or wisdom for getting the Charge Air Cooler replaced? I'm assuming a used one is a false economy? I'm losing about half a ml a mile of coolant, so not a huge deal for me to keep pouring it in until the car is next in a garage*. Is it worth hanging on until timing belt and water pump gets done next year dya think? *Which unless Skoda sort the 23AX update that ****ed up my DSG behaviour swiftly, my family won't set foot in a VAG garage for the rest of my life... My coolant is greeny-yellow rather than pink, thanks to the fluoroscein UV dye in there.
  13. Well, I'm hoping that VW/Skoda will resolve this in a mutually acceptable fashion. They appear to be acting in good faith at this time.
  14. Car booked in for routine service and DSG oil change. Told on arrival about 23AX emissions update. Queried what it entailed and if there were any potential downsides. Given the Skoda blurb on what it did - emissions, protecting the catalyst etc. Asked the service manager directly about any potential downsides. SM said that "there were none, it had been done to loads of vehicles and there were no reported problems, Skoda were doing this update for a good reason and to protect my vehicle. He would do it if it were his car." Absolutely *zero* mention of affecting gearchanges or behaviour of gearbox modes. Did I consent to the update - Yes Was my consent based on misleading information - Yes So - Did I give *informed consent* - Emphatically, NO! I accept that the dealership were given incomplete information by Skoda. Thats fine. I'm very salty about being told there is nothing wrong with the function of the DSG, the removal of the different modes, and that I drive funny. @toot I don't know exactly who's handling the complaint, but it's via the VWUK Executive Office rather than a random callcentre.
  15. Thanks @varooom. Next step is awaiting another convo with Skoda customer services to see what they say. I cant see how they should be allowed to make such a big change without the informed consent of owners. Obviously I feel that I *shouldn't have to* spend time and money to go to a third party or tuner to fix my car. Knowing that it might just take an ECU fix, not DSG too is good news. A bit of looking at Dutch/German forums suggested that the 23AX is particularly brutal on Euro6 non-adblue engines like mine. I believe such engines are actually very rare as there are only a few months of manufacture of Euro 6, before adblue was included. They also made the point that nitrogen oxides and soot are 2 sides of the same hot/cool burn coin. Cooler burning and richer mixes inevitably gives more soot - which I find annoyingly plausible 😞
  16. So... I've just driven ~5 year old 2 litre TDI DSG Passat, Tiguan and Audi Q5s In all cases, engaging "S" mode via the gearlever almost always prompts a downshift. I'm now 100% certain that something is wrong. I simply don't understand how the dealership can think it is ok. I have reached an impasse with the dealership, who I think are aggrieved because I have already opened a case with Skoda. A hamper of goodies arrived from Skoda today - which is a nice gesture - but not a good substitute for my car working properly... I think this now boils down to 1) Something was done wrong but will not be acknowledged by dealership - and can be fixed elsewhere or 2) Update makes car behave as intended by Skoda - a change which I did not give informed consent to, and therefore want rolling back.
  17. Could do, but the problem being they are all significantly later models. I accept that it's possible that newer vehicles DSGs behave in a particular way - say for emissions testing reasons - that the 23AX update might have changed my car to. That doesn't alter the fact that my car used to behave entirely differently. I'll be test driving some older 2 litre diesel DQ250 DSG cars in person. In fact, if anyone is near Nottingham with one and likes to be paid in homebrew it'd be great to take a video whilst you demo...
  18. Frustrating update: "Basic gearbox adaptations" have been redone and after several hundred miles of driving there has been no change or improvement in how the DSG behaves. E, D, S modes have no perceptible difference in gearchange points and engaging Sport mode on a trailing throttle at low/tickover revs does not prompt the downshift that it used to. e.g. for engine braking, overtake preparation or for appropriate gear for proper vehicle control around a roundabout. Page 128 of my car handbook helpfully states: "In Mode S , the forward gears are shifted automatically up and down at higher engine speeds that mode D" and "In mode E , the forward gears are shifted automatically up and down at lower engine speeds than mode D" My car no longer does this, yet I'm told my car behaves just like all the other cars. It seems the dealer and I have reached an impasse and I'm advised to take it up with Skoda. Any thoughts? Videos of engaging sport mode and a drop in gear would be particularly helpful.
  19. Wasn't directing a comment at you buddy. Interestingly though, I'd contend that you don't necessarily have the right approach... but it's all situational and in the case of motorbikes, you have a lot more spare power. In an ideal world, you wouldn't be closing swiftly with the car in front in case they have to brake at an inconvenient time. You pick the right gear, pull out, get a good view, then decide if the overtake is on or not.
  20. Same issue. I believe you can get a borescope into the charge cooler, I can't track down the post RN though.
  21. Yeah, I default to the same individual mode setup. I'd engage Sport to be in the correct gear, *before* initiating an overtake rather than pulling out, then stamping on the throttle and waiting for the DSG to get it's **** together. I'm aware most drivers would be close and closing on the car in front before even pulling out, but the motorcyclist in me has long been trained out of this. I'd often move to sport for engine braking and correct gear around a large roundabout for proper vehicle control. I hate eco upshifting to 4th gear as you roll around the roundabout before dropping to 2nd or 3rd and unsettling the car as you accelerate off the roundabout.
  22. To update you all... It was back in the dealers for a "Basic adaptation of gearbox settings" so now I'm to go away again for 500 miles to see if it fixes the problem. No change in the first hundred miles, I'm not hopeful. It's still being suggested that I drive funny and nobody else ever engages "Sport" on the DSG to drop a gear to prepare for an overtake or for engine braking. The car handbook helpfully states. "In Mode S , the forward gears are shifted automatically up and down at higher engine speeds that mode D" and "In mode E , the forward gears are shifted automatically up and down at lower engine speeds than mode D" - Except not anymore it seems... my 3 main DSG modes are indistinguishable (Offroad mode *is* a bit different however) The service manager tried some other DSG cars off the forecourt and suggested none of them routinely downshift if you are at low revs/high gear and engage "sport". Sadly I don't have loads of cars sitting around to test this myself and have to rely on your anecdotal reports.
  23. I had my Haldex stop working. No warning lights or error codes. I had to identify it by pulling away uphill on slippery surfaces and the front wheels struggled to pull it away fast from wet junctions whilst turning. My first haldex service was an oil change only - and at that time they didn't realise a new filter was needed too (duh...) Reading around I discovered that clogged filters were common, and Haldex didn't sent error codes to the ECU very well. New filter, oilchange and whatever electronic reset they do sorted it.
  24. My money is on people not understanding that the DSG coasting =/= depressing the clutch in a manual. There are circumstances where low revs= oils starvation, but I doubt that in modern engines designed for it. I don't buy that it means more torque being demanded at low revs means more harm, it'll drop down a gear if it needs to. The italian-tuneup idea - sometimes engines need a thrash - that's not ad odds with being in eco mode most of the time. You could argue equally that a lower life-time total of cycles/revolutions would make for a longer lasting engine
